Gigabyte Z77X-UP4 TH Review
AIDA64
Published: 20th August 2012 | Source: Gigabyte | Price: £150 |
AIDA64
Don't let the AES result fool your eye into thinking the rest of the scores are that significantly behind. Although we're not hitting the heights seen on the Maximus V Extreme, the UP4 is incredibly close to the results we obtained from the much pricier Sniper 3.
Memory scores are middling, with the stock result being a little concerning, but the overclock gaining much of the deficit back.
CPU Benchmarks
Memory Benchmarks
and for the £££££'s this fairs well
I am seriously considering buying this board; however, I am little concerned about the height of the heat sinks that surround the CPU socket.
I have bought a Thermalright Archon SB-E and due its’ 155mm length, it will overhang / foul the very top heat sink.
The clearance from between the base of the cooler to the first fin is 42.55mm. Does anyone know the height of the top two heat sinks on the board?
Does the Thermalright Silver Arrow SB-E used in the review overhang the heat sinks (length 147mm)? If so, I might be in the clear because the Silver Arrow SB-E has a height of 40.87mm.
Any reply would be very much appreciated!
Today we have the latest Gigabyte Z77X UP4 TH on our test bench. How does it perform?
Continue Reading
