Gigabyte Z77X-UP4 TH Review
BIOS
Search Reviews
BIOS
The UP4 comes with the Gigabyte 3D BIOS, which looks great in pictures and is useful for allowing people who are unfamiliar with BIOS adjustments to understand what is affected by each tweak, or to adjust small things such as boot orders without being fearful they will put 2v through their CPU. Although it's obvious to us what does what, you can never underestimate the importance of teaching the next generation.
Gigabyte Z77X-UP4 TH Review     Gigabyte Z77X-UP4 TH Review
The initial options are all fairly standard things we've seen a thousand times before.
The M.I.T provides the main place we're interested in. Every item is clearly labelled and you can make as many or as few adjustments as you feel necessary.
Thunderbolt options are few, but we're sure as the technology matures this will become as fully populated as the USB options are now.
«Prev 1 2 3 4 5 6 7 8 9 10 11 Next»
20-08-2012, 10:40:49
tinytomlogan
http://www.overclock3d.net/gfx/artic...113842857l.JPG
Today we have the latest Gigabyte Z77X UP4 TH on our test bench. How does it perform?
Continue Reading
20-08-2012, 13:10:52
dugdiamond
you get what you pay for
and for the £££££'s this fairs well
22-08-2012, 04:19:15
dotems
I'm curious are the heatsinks one solid piece or can you remove the grey and blue strips a separate part of metal and if so how are they connected. It would be awesome if you could take them off and paint the grey strips yourself yourself.
04-09-2012, 09:43:43
Ylaana
Are there any plans to review the UP5 TH?
30-12-2012, 07:10:09
noproblem
Thanks for the review Bryan!
I am seriously considering buying this board; however, I am little concerned about the height of the heat sinks that surround the CPU socket.
I have bought a Thermalright Archon SB-E and due its’ 155mm length, it will overhang / foul the very top heat sink.
The clearance from between the base of the cooler to the first fin is 42.55mm. Does anyone know the height of the top two heat sinks on the board?
Does the Thermalright Silver Arrow SB-E used in the review overhang the heat sinks (length 147mm)? If so, I might be in the clear because the Silver Arrow SB-E has a height of 40.87mm.
Any reply would be very much appreciated!
