Gigabyte Z77X-UP4 TH Review
Up Close
Search Reviews
Up Close
Externally the UP4 is reminiscent of the rest of the Gigabyte range of motherboards, the white box leaving no doubt as to the model number you have in your hands, nor the features that are contained within. Although the addition of the TH for Thunderbolt moniker must have some people saying "Fourth? I don't remember a third". Inside we have the standard few accessories, IO shield, SLI bridge and SATA cables alongside the always excellent Gigabyte documentation.
Gigabyte Z77X-UP4 TH Review     Gigabyte Z77X-UP4 TH Review
The board itself is probably best described as functional, at least in terms of the heatsink design. It just lacks those few moments of flair. All black except a dark grey to differentiate the memory channels and two white SATA ports, it's a far cry from the blue and black we're used to seeing from Gigabyte.
The bottom corner is pretty tidy, with the CMOS battery easily accessible and the front-panel header nicely placed. We're not big fans of the half-shield on the chipset heatsink. It looks too much as if they ran out of aluminium. Considering how nice, albeit utilitarian, the rest of the UP4 looks this is disappointing.
PCI Express slots are well spaced ensuring good airflow around even an twin-GPU setup. The move of the mSATA port to above the top PCI Express 3.0 slot means it's not somewhere you'll be able to access too readily once a GPU and the CPU cooler are in place, but it's out the way for the majority of us who will never take advantage of it.
The CPU area is clean and tidy, with fan headers handily placed to save the long tangle of 4 pin cables or any need for extensions. The heatsinks are, as we've said, a bit bland. Functional enough but nobody is going to be wowed by them. Probably the biggest surprise in terms of the design is the lack of power control buttons on the UP4 itself. We're so used to them appearing on everything, from ITX boards to the very top of the range models, that to find them absent was eyebrow-raising.
SATA ports are two 6Gbp/s ones (white) and four 3Gbp/s ones. Round the back everything is where you'd expect to find it with the normal wealth of USB headers and display options. The big change with the Z77X-UP4 TH is the inclusion of the two Thunderbolt ports between the LAN tower and the Audio outputs. We're not sure if they can be stacked, but it would help tidy things up if they were.
«Prev 1 2 3 4 5 6 7 8 9 10 11 Next»
20-08-2012, 10:40:49
tinytomlogan
http://www.overclock3d.net/gfx/artic...113842857l.JPG
Today we have the latest Gigabyte Z77X UP4 TH on our test bench. How does it perform?
Continue Reading
20-08-2012, 13:10:52
dugdiamond
you get what you pay for
and for the £££££'s this fairs well
22-08-2012, 04:19:15
dotems
I'm curious are the heatsinks one solid piece or can you remove the grey and blue strips a separate part of metal and if so how are they connected. It would be awesome if you could take them off and paint the grey strips yourself yourself.
04-09-2012, 09:43:43
Ylaana
Are there any plans to review the UP5 TH?
30-12-2012, 07:10:09
noproblem
Thanks for the review Bryan!
I am seriously considering buying this board; however, I am little concerned about the height of the heat sinks that surround the CPU socket.
I have bought a Thermalright Archon SB-E and due its’ 155mm length, it will overhang / foul the very top heat sink.
The clearance from between the base of the cooler to the first fin is 42.55mm. Does anyone know the height of the top two heat sinks on the board?
Does the Thermalright Silver Arrow SB-E used in the review overhang the heat sinks (length 147mm)? If so, I might be in the clear because the Silver Arrow SB-E has a height of 40.87mm.
Any reply would be very much appreciated!
