Gigabyte Z77X-UP4 TH Review
3D Mark
3D Mark Vantage
Performance in Vantage is better, considering that the main 'boards ahead of the UP4 are the much pricier Gigabyte Sniper 3, ASUS Maximus V Extreme, and, Gigabyte D3H?!
3D Mark 11
Finally 3D Mark 11, and although the D3H again steals the limelight, all of the Z77 boards are in the same ballpark.
«Prev 1 2 3 4 5 6 7 8 9 10 11 Next»
20-08-2012, 10:40:49
tinytomlogan
http://www.overclock3d.net/gfx/artic...113842857l.JPG
Today we have the latest Gigabyte Z77X UP4 TH on our test bench. How does it perform?
Continue ReadingQuote
20-08-2012, 13:10:52
dugdiamond
you get what you pay for
and for the £££££'s this fairs wellQuote
22-08-2012, 04:19:15
dotems
I'm curious are the heatsinks one solid piece or can you remove the grey and blue strips a separate part of metal and if so how are they connected. It would be awesome if you could take them off and paint the grey strips yourself yourself.Quote
04-09-2012, 09:43:43
Ylaana
Are there any plans to review the UP5 TH?Quote
30-12-2012, 07:10:09
noproblem
Thanks for the review Bryan!
I am seriously considering buying this board; however, I am little concerned about the height of the heat sinks that surround the CPU socket.
I have bought a Thermalright Archon SB-E and due its’ 155mm length, it will overhang / foul the very top heat sink.
The clearance from between the base of the cooler to the first fin is 42.55mm. Does anyone know the height of the top two heat sinks on the board?
Does the Thermalright Silver Arrow SB-E used in the review overhang the heat sinks (length 147mm)? If so, I might be in the clear because the Silver Arrow SB-E has a height of 40.87mm.
Any reply would be very much appreciated!Quote
