Gigabyte EX58-UD4P X58 Motherboard
Test Setup
Published: 16th April 2009 | Source: Gigabyte | Price: £206.99 |
Test Setup
To ensure that all reviews on Overclock3D are fair, consistent and unbiased, a standard set of hardware and software is used whenever possible during the comparative testing of two or more products. The configuration used in this review can be seen below:
Processor: Intel Core i7 920 (2.66Ghz)
Motherboard: Gigabyte EX58-UD4P
Memory: 6GB Corsair DDR3 @ 8-8-8-24 1600Mhz
Graphics Card: NVidia GTX280
Power Supply: Gigabyte Odin 1200W
CPU Cooling: Stock Intel Cooling
Hard Disk: Hitachi Deskstar 7K160 7200rpm 80GB
Graphics Drivers: Geforce 180.60 CUDA
Operating System: Microsoft Windows Vista Ultimate x64 SP1
During the testing of the setup above, special care was taken to ensure that the BIOS settings used matched whenever possible. A fresh install of Windows Vista was also used before the benchmarking began, with a full defrag of the hard drive once all the drivers and software were installed, preventing any possible performance issues due to leftover drivers from the previous motherboard installations. For the 3DMark and gaming tests a single card configuration was used.
The memory spacing was ample and should not prevent over sized coolers being fitted. The Gigabyte EX58-UD4P features a multitude of mini LED's that all have a purpose. The Blue LED's near the DDR3 slots signify CPU Frequency with no LED's lit meaning stock - I managed to light all 5 up! Just above these LEDs are 5 green, 4 yellow and 4 blue LED's all in a row. These LED's highlight the amount of CPU Phase Load. Again I managed to load them all up. There are also phase LED's for the memory, Northbridge and South bridge. Below right you can see the NB voltage indicator which cycles through green (safe), yellow (moderate) and red (Thermo-nuclear?). The over sized QPI (Northbridge) cooler meant these LED's were slightly obscured, revealing just the green LED, looking from the side however, showed that the colour was actually red. Maybe it's time I donned that radiation suit!
These little LED's are a nice little touch, especially for those who are insistent on using AUTO voltages when overclocking as they give and indication of the level of voltages being used for any given overclock. The majority of these LED's can however, be turned off should you prefer.
To guarantee a broad range of results to best evaluate the motherboards performance, the following benchmark utilities were used:
Synthetic CPU Test
• Sisoft Sandra 2009
• PassMark CPU test
• SuperPI 1m, 8m, 32m
Memory Test
• Everest 4.60
File Compression & Encoding
• 7-Zip File Compression
• River Past ViMark
Disk I/O Performance
• HDTach 3.0.4.0
3D / Rendering Benchmarks
• Cinebench 10
• 3DMark 05
• 3DMark 06
• 3DMark Vantage
3D Games
• Crysis
• Far Cry 2
• Call of Duty 4
Overall System Performance
• PCMark Vantage
• PassMark CPU test
Memory Test
• Everest 4.60
• River Past ViMark
• HDTach 3.0.4.0
• Cinebench 10
• 3DMark 05
• 3DMark 06
• 3DMark Vantage
3D Games
• Crysis
• Far Cry 2
• Call of Duty 4
• PCMark Vantage
Power Consumption
Power consumption is an aspect often forgotten when it comes to enthusiast motherboards but in todays climate, with rising utility bills special consideration needs to be taken when choosing you components as over a period of time, one components can prove to be much more expensive than another over its lifetime. Power consumption was measured at the socket using a plug-in mains power and energy monitor. Idle readings were taken after 5 minutes in Windows. Load readings were taken during a run of 3DMark Vantage.
The Gigabyte EX58-UD4P was exceptional in this department using the lest power when idle and when under load conditions. No software utilities were used either which, thanks to the 6-Gear utility of Gigabyte could lower power consumption even further by altering the power phase of the motherboard.
Overclocking
Here's a couple of the obligatory CPU-Z screenshots at stock:
Using a respectable Vcore of 1.40v set in the BIOS, the remainder of BIOS voltage settings were left in their stock state to ensure equality throughout the testing. Here's what I managed out of the motherboard:
Not a bad showing by any means! 4200MHz was the maximum I managed out of the Gigabyte UD5 and despite the UD4P being a slightly cut down version of that board it has managed the same overclock regardless. Vdrop/droop was nothing too much to worry about with a maximum 0.012v droop recorded during testing (loadline enabled). It wasn't all plain sailing though as the stock BIOS gave some pitiful results maxing out at 3.5GHz. However, a BIOS update to the official F7 allowed the overclock above with relative ease. BIOS recovery was mediocre, sometimes it was fine, others, it was not. Memory Multi overclocking tended to result in none boot scenarios which only a CMOS clear would rectify. CPU clocking on the other hand recovered with relative success. Once you have your favoured settings, the Gigabyte BIOS allows you to back it up by creating a settings profile (F11) and returning to this profile at a later date and time should you wish by simply pressing F12.
Returning the Gigabyte EX58-UD4P and the CPU to their stock settings I then ran the standard suite of benchmarks and compared the boards performance to a number of other X58 motherboards. Let's see how it got on...
Orange? Orange!?
WTF man.
WTF man.
Lol i have the UD5 and its extreamly similar looking and believe me when i say its uglier in real life... Saying that i Picked up my UD5 from Novatech for like £205 for some reason that was the price so i clicked add to basket
... The UD5 is a great board...
... The UD5 is a great board...Nice review
The link from the front page is broken though :S
Good review. Always enjoy reading ya mobo reviews.
Just a shame none are really pulling away from the pack. I'm sure on prevoius generations you would always get at least 1 or 2 that would be a little bit apart from the others.
Originally Posted by name='Luigi'
Nice review
![]() The link from the front page is broken though :S |
Originally Posted by name='Jim'
Works fine here :\
Just a shame none are really pulling away from the pack. I'm sure on prevoius generations you would always get at least 1 or 2 that would be a little bit apart from the others. |
Hopefully P55 won't be too far away so we can throw them into the mix.
Comments in the top right hand corner?
I think Gigabyte have done really well on the x58's, certainly catering for those on a budget...
I think Gigabyte have done really well on the x58's, certainly catering for those on a budget... |
Originally Posted by name='PeterStoba'
Nobody going i7 is on a budget
Think we're all a little harsh on the color scheme. Particularly as it's low score for slot coloring brings the average down to such an extent.
Got another of these gigabyte mobos on wednesday, and I'm getting more and more impressed with them the more I use them.
As a sidenote, I don't think we'll see P55.
Onboard stuff for these mobos across the spectrum could do with more scrutiny. The ALC889A seems to be a damn good audio setup in it's own right. A few design flaws for my liking, but for a 1 pc setup it's pretty impressive. Nics are offering teaming and carry with them some bios testing features.
The score for the presentation was not simply just for the slots but for the overall package. The gigabyte boards are not the best packaged boards in the world with the contents placed ontop of a cardboard divider. A thin sliver of foam is all that separates the motherboard base from the box itself. Compare this to the way Asus package there boards or indeed DFI and you can the appreciate why the Gigabyte score low in this department. It's saving grace are the included accessories.
Overall though I recommend it as it's the contents that matter and the UD4P certainly performs well enough and is priced such to earn the recommended award.
Overall though I recommend it as it's the contents that matter and the UD4P certainly performs well enough and is priced such to earn the recommended award. |
Gotta be worth the extra 0.5 mark
It also has an all in one heatsink via heatpipe
. It also has an all in one heatsink via heatpipe
http://www.overclock3d.net/gfx/artic...132933275s.jpg
Read the full review HERE
