Gigabyte EX58-UD4P X58 Motherboard
Packaging & Appearance
Search Reviews
As with the Gigabyte EX58-UD5 (reviewed here), the UD4P is packaged in a white box with a holographic weave effect. The front of the box is plastered with emblems and advertisements of the features of the motherboard. Taking pride of place though is the Ultra Durable badge informing the prospective buyer that the EX58-UD4P has 2oz of copper in the PCB, Japanese solid capacitors Lower RDS(on) Mosfets and Ferrite core chokes. Flipping the box over we see that the features are explained in greater depth. Despite the UD4P being a mid range board it's as feature packed as any high end board on the market at the moment.
Box Front box back
Removing the outer sleeve and opening the plain white reinforced box we come to the accessories of the motherboard. Gigabyte include an I/O shield, 4x SATA cables, e-SATA cables, IDE and floppy cables as well as a small (dual) and large (triple) SLI bridge. Aside from the obligatory driver CD and manual, Gigabyte also include 3 other manuals for you to peruse should you need further instruction on setting the motherboard up for the first time.
accessories manuals
I/O shield SLI
The motherboard itself is very similar to the UD5 but there are a few discreet differences. The colour scheme is the much improved blue/white affair but Gigabyte have still seen fit to throw a little extra colour into the mix with couple of orange PCIe slots. The only other ports that really stick out like a sore thumb are the USB ports. It's a crying shame that the whole board could not be matched up to one colour scheme as the blue/white is very attractive, spoilt only by the orange and yellow ports. Still this is a far cry from the days of the rainbow coloured Gigabyte boards of old so they are to be applauded for that.
board front board back
The CPU socket area is very cluttered thanks to the 12 Phase power delivery. All of the chokes are ferrite core ensuring stable clean power is supplied to the CPU even under the highest load conditions, this along with solid capacitors should also ensure that the motherboard will still be going strong long after the socket has become obsolete. The six memory slots support triple channel DDR3 up to a maximum of 24GB.
socket area memory slots
Onto the PCIe area and we find that from top to bottom there are: PCIex1, PCIex4, PCIe 2.0 x16, PCI, PCIe 2.0 x16, PCI and PCIe 2.0 x8. All of the 16/8x PCIe slots are CrossfireX/SLI compatible and both the blue slots will provide the full 16 lanes. However, when a third card is added to the bottom slot then the second blue slot along with the orange slot drop down to 8 lanes. At present this has very little effect on todays GPUs as there is no requirement for 16 lanes on PCIe 2.0. 8x PCIe 2.0 provides roughly the same bandwidth of PCIe 1.1 x16 so this is a bit of a none issue. Perhaps only the dual GPU cards would be hindered by 8 lanes but as these cards can't be run in Tri configuration this is a none issue.
The UD4P is missing 2 SATA parts that it's bigger brother has however, as they are on the Gigabyte SATA2 controller I doubt they will be missed too much, especially as the board still has 6 SATA ports on the Intel ICH10R controller and a further 2 on the Gigabyte SATA2, not to mention the eSATA ports available.
 PCIe SATA
The I/O area of the boards has plenty (8) USB ports, a single Gigabit LAN port, 7.1 audio courtesy of 6x 3.5mm jacks, S/PDIF, Firewire and 2 PS/2 ports. There's also a handy CMOS reset button allowing the user to reset the BIOS should the settings create instability. Toward the bottom of the board there are two USB sockets and a further two fire wire ports. The motherboard header area is colour coded to ensure ease of connection but sadly no quick connector is provided. Above these is an IDE port that while rapidly becoming obsolete is still frequently used by those with older hardware.
I/O shields USB
The UD4P features 2 BIOS chips that can recover a corrupt flash with the redundant BIOS chip re-flashing the corrupt one should the need arise. Next to these chips is a floppy drive port. While the floppy port is rarely used for anything other than a BIOS flash these days, some people swear by this method of BIOS flashing and are reluctant to try any other method. To the top right of the board is a power on/off and reset switch. I would liked to have seen the reset switch be something more than a tiny little button as it can be fiddly to use. Never the less it's great that Gigabyte have considered those who run motherboards out of the box so to speak.
Dual BIOS LED's
Removing the Aluminium heatpiped which snakes along the motherboard was a relatively simple affair with the two Mosfet coolers being a push pin design and the QPI (NB) and Southbridge held fast by spring loaded screws. This design ensures that there is a near perfect mount and thanks to the generous amount of paste used the mount was indeed very good. The Mosfets transfer heat by the means of thermal tape which again is the perfect material for the uneven surfaces of the Mosfets.
Power Northbridge
Sadly, one area which has seen a budget restraint is the heat sink cooler. On the surface, the gun metal grey looks attractive enough but the Aluminium material used is not as good as copper for transferring heat. Hopefully this won't have too much of an effect on the cooling of the motherboard as the thick finned cooler certainly does not have as much surface area as the more expensive Gigabyte boards.
southbridge cooler
So there you have it, a very attractive motherboard with only a few discreet differences between it and the UD5. The packaging could be improved, especially in the way the accessories are packaged as they are simply separated from the motherboard  by a loose layer of cardboard. This is packaging at its most basic and something Gigabyte would do well to change as they are slowly falling behind in this area when compared to other manufacturers. Beauty is only skin deep though and thankfully there has not been too much cost cutting where it counts, the motherboard itself.
Let's take a look at the brains behind the board, the Motherboard Intelligent Tweaker (M.I.T) section of the Gigabyte EX58 - UD4P's BIOS...
16-04-2009, 05:50:06
w3bbo
The EX58-UD5 impressed us in our last Gigabyte review. Can the UD4P, the UD5's cheaper brother, make an equally strong impression? Find out in our latest review...
http://www.overclock3d.net/gfx/artic...132933275s.jpg
Read the full review HERE
16-04-2009, 08:45:35
zak4994
Orange? Orange!?
WTF man.
16-04-2009, 09:13:43
OmegaStalker
Lol i have the UD5 and its extreamly similar looking and believe me when i say its uglier in real life... Saying that i Picked up my UD5 from Novatech for like £205 for some reason that was the price so i clicked add to basket ... The UD5 is a great board...
17-04-2009, 04:02:45
Luigi
Nice review
The link from the front page is broken though :S
17-04-2009, 06:32:07
Bungral
Good review. Always enjoy reading ya mobo reviews.
Just a shame none are really pulling away from the pack. I'm sure on prevoius generations you would always get at least 1 or 2 that would be a little bit apart from the others.
17-04-2009, 06:49:35
Jim
Originally Posted by name='Luigi'
Nice review
Works fine here :\
17-04-2009, 06:51:58
w3bbo
Originally Posted by name='Jim'
Works fine here :\
Here too?
Yeah I must agree with that point. Previous generations were always a mixed batch though with 780i, P45 and X48. All the boards for i7 we have tested thus far are all X58 and so have the same QPI bus and ICH10R controller.
Hopefully P55 won't be too far away so we can throw them into the mix.
17-04-2009, 07:15:42
Luigi
Comments in the top right hand corner?
I think Gigabyte have done really well on the x58's, certainly catering for those on a budget...
17-04-2009, 07:41:09
PeterStoba
Nobody going i7 is on a budget
17-04-2009, 08:06:40
Rastalovich
Correct. Really there isn't that much of a point, especially if ur on a budget.
Think we're all a little harsh on the color scheme. Particularly as it's low score for slot coloring brings the average down to such an extent.
Got another of these gigabyte mobos on wednesday, and I'm getting more and more impressed with them the more I use them.
As a sidenote, I don't think we'll see P55.
Onboard stuff for these mobos across the spectrum could do with more scrutiny. The ALC889A seems to be a damn good audio setup in it's own right. A few design flaws for my liking, but for a 1 pc setup it's pretty impressive. Nics are offering teaming and carry with them some bios testing features.
17-04-2009, 11:11:28
w3bbo
The score for the presentation was not simply just for the slots but for the overall package. The gigabyte boards are not the best packaged boards in the world with the contents placed ontop of a cardboard divider. A thin sliver of foam is all that separates the motherboard base from the box itself. Compare this to the way Asus package there boards or indeed DFI and you can the appreciate why the Gigabyte score low in this department. It's saving grace are the included accessories.
Overall though I recommend it as it's the contents that matter and the UD4P certainly performs well enough and is priced such to earn the recommended award.
17-04-2009, 17:29:18
OmegaStalker
The UD5 Was packed poorely too but lol the box was nice and shiny and it did come with a fair bunch of goodies...
17-04-2009, 18:30:22
w3bbo
Gotta be worth the extra 0.5 mark .
It also has an all in one heatsink via heatpipe
