Gigabyte EX58-UD3R X58 Motherboard
Media Encoding & Compression
Search Reviews
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
ViMark is the latest addition to the OC3D motherboard testing process and a relatively new benchmarking application in general. Designed to take the inaccuracies and guesswork out of measuring the time taken to encode video files, ViMark produces easily comparable and consistent results for encoding raw video into Windows Media, Quicktime and Gif formats. As always, a total of 5 benchmark runs were performed with the highest and lowest scores removed and an average calculated from the remaining 3 scores.
7-Zip is an open source Winzip-style file compression utility that has the ability to compress and decompress many file formats including its own .7z compression scheme. 7-Zip also comes complete with its own benchmarking utility for gauging the compression and decompression speed of the system that it is installed on.
Results Observations
Again, there was little to separate all of the motherboards on test. The UD3R did however score towards the higher end of the leaderboard in the encoding tests but slipped back during the compression/decompression tests.
Let's move on to our 3D Benchmarks...
05-05-2009, 04:18:20
w3bbo
Budget does not always mean a comprimise on performance. Gigabyte's entry level X58 motherboard might just throw up a few surprises in our latest motherboard review...
http://www.overclock3d.net/gfx/artic...162023939s.jpg
Read the full review HERE
05-05-2009, 08:30:17
Ham
Nice review mate.
If I were to get the inkling to go I7, this board would probably make the shortlist. Performance at a good price is always a winner.
05-05-2009, 10:56:45
prosser13
Teehee £158 for "budget"...
*wanders off muttering to self about what the motherboard market has come to*
05-05-2009, 14:21:49
djw746
This isn't that outrageous for the "next" Intel board. We just got used to new 775 being in $100 range... New means long time til mainstream for cheapness... but very sad if you want the best. Stupid Best/New tax
05-05-2009, 14:29:18
Rastalovich
Agreed. It's still outrageous.
Considering the kind of systems u can still buy with 775 and get an equal terms use out of it. Performance on a par.
Nice mobo, but u can get an EP45-DS5 for around £120 (at least I did), and clock the eff out of whatever proven cpu. And that's a ddr2 option. Heck get urself 8g of nothingness whilst ur at it and u still have cash left, from what u didn't buy the I7 kit with, to buy a GTX260/275/280/285 to build a rig not to be sniffed at.
06-05-2009, 14:50:44
w3bbo
Prices of motherboards have been rising for a long time now. You are always going to pay top dollar for cutting edge technology. Take SSD's for example: for a 30GB SSD you could have 2TB of standard drives in raid 0!
06-05-2009, 14:59:33
prosser13
Aye w3bbo - I'm just reminiscing of the old days, in 939 and the like, where £150 would buy you the best board out there
06-05-2009, 15:08:57
Ham
The point being the 2TB drives are there as an alternative though. Or you can just buy one 500GB drive and save loads.
You just cant do that with I7 mobos.
06-05-2009, 17:18:12
w3bbo
EVGA Classified - £380
Gigabyte UD3R - £150
Less than half the price?
06-05-2009, 17:25:48
Mul.
X58 boards are expensive yes, but it's fair to say that there's a reason why. The X58 chipset as such is not exactly basic with the sheer number of PCI-E lanes, triple channel memory controller and as I understand the power regulation on these boards must have to be fairly strong for these 130W TDP CPU's. Combined with the fact that Intel is well aware that there is no true Core i7 competitor that they are free to price their CPU's and Chipsets accordingly. That being said, I don't believe that the overall i7 adoption cost is so bad these days with the price of respectable DDR3 kits taking a nose dive and more "budget" friendly i7 boards like the EX58 UD3R making an appearance.
I see prosser13's argument with regards to AMD boards and I do recall my legendary DFI LanParty UT nF4 series motherboard that at £90 would reach high base HTT's in excess of 300MHz but the AMD nForce boards were historically cheaper than Intel equivalents like for like. I remember the Canterwood 875P boards sitting around the £100 mark but that was ever so long ago and ever since I recall the higher end 925XE, 955X, 975X, X38/48 boards all exceeding £175. The X58 is no exception.
I do however like what this £160 motherboard acheives and think it's a fantastic buy if you believe that you can take advantage of the perks from the Core i7 platform but have a restricted budget. Excellent review W3bbo
06-05-2009, 17:37:26
PeterStoba
Exactly what I was going to say (you said it better )
06-05-2009, 17:38:51
Rastalovich
I object to the term "cutting edge" being used on I7
As for SSD, I can't see me ever buying a current day SSD. I'm confident enough to allow quote-age on that.
07-05-2009, 10:05:17
GigaMan
BTW, this board DOES support SLI and the warranty will NOT be affected.
It's just a BIOS (F5) update - that is it!
Maybe other brands will void the warranty, but not Gigabyte.
And well done for picking up our new EZ-Share technology
Allowing you to share and safe profiles.
You should receive a prize for that
09-05-2009, 07:29:36
w3bbo
Ah cool.
So will Gigabyte be stopping production of the UD3R - SLI then?
13-05-2009, 12:45:11
GigaMan
Ah cool.
No, the UD3R - SLI will go ahead, we think that it will just make sense and will create less confusion in the market.
13-05-2009, 12:57:47
limpkorn
Agree, this is a great price for an X58 mobo, and if it overclocks well it's kind of pointless to go with the 775 mobo unless you're trying to build a budget system.
13-05-2009, 13:49:59
w3bbo
Ah ok.
BTW, welcome to the forums GigaMan. It's always nice to have company reps give feedback and add info as appropriate.
19-05-2009, 17:09:01
w3bbo
Review updated and score ammended to reflect the fact that this motherboard now supports SLI with the latest BIOS update. Well done Gigabyte!
19-05-2009, 18:52:03
sammytomjohn
Its a good thing all these companies make so many different models of boards, chips, graphics, chips,, etc... as it means we can still get our hands on a wide variety of performance parts
I mean otherwise the only places that would be seeing these i7 and quad cores would be corporate and buisness sectors!!
i do think they should get some sort of regulations about newer products should always be significantly more powerful than older model's and the improvement % should be equivalently higher!!
as every1 knows : you do get headaches upgrading all the time!!
19-05-2009, 18:57:32
Rastalovich
Just to put that side of ur mind at rest, I work at one of the biggest corporations in the country and nation-wide they use 10s of 1000s of pcs, mostly p4 with a large sprinkling of c2d. Very small % of 45nm.
... and tbf they do their job.
