Gigabyte EX58-UD3R X58 Motherboard
Published: 5th May 2009 | Source: Gigabyte | Price: £146.04 |
Gigabyte were one of the first motherboard manufacturers to take advantage of Intel's latest X58 chipset with the formidable (and current editors choice) EX58-UD5. Along with the range topping Extreme (which is a clone of the UD5 but with fancy cooling) and the mid-range EX58-UD4P we reviewed here, Gigabyte also have a budget board in the form of the EX58-UD3R which we have for review today.
The UD3R is aimed toward the entry level of the market and despite costing a pint of lager over £150, the UD3R is certainly one of the cheapest X58 motherboards out there today. As with the UD4P, the UD3R is a stripped down version of the flagship motherboards, each having less features as we slip down the scale. That isn't to say the UD3R isn't a capable motherboard, far from it. Being Crossfire compatible as well as having RAID capabilities, 8 SATA ports, twin 16x PCIe 2.0 slots, 8 USB ports (expandable to twelve), things are not quite as clear cut as you may think. Budget board maybe but it's certainly not lacking in features.
Sporting a similar Dynamic Energy Saver to it's high end brother, the UD3R has hardware based dynamic four-gear switching as opposed to the UD5's 6 Gear switching. The UD3R also features the confidence building 'Dual-BIOS' technology which automatically recovers BIOS data when the main BIOS has crashed or failed a flash due to improper BIOS updating. For those who do not like to delve into a motherboards BIOS, Gigabyte also include EasyTune6 which allows the monitoring and tweaking of system components in a windows environment.
Here's what Gigabyte had to say about there entry level motherboard:
The EX58-UD3R is the latest X58 Series motherboards of GIGABYTE, designed from the ground up to unleash the awesome power of Intel’s new Core i7 processors. Equipped with a host of new features including the new QPI interface, 3 channel DDR3 support, CrossFireX™ support, Ultra Durable 3 (Classic) technology and the industry’s most extensive range of overclocking features, the EX58-UD3R is bringing excitement back into the high performance motherboard industry.
Specification
The following specification was taken directly from the Gigabyte website:
CPU
Support for an Intel® Core™ i7 series processor in the LGA 1366 package
Go to CPU Support List for the latest CPU support )
L3 cache varies with CPU
QPI
4.8GT/s / 6.4GT/s
4.8GT/s / 6.4GT/s
Chipset
North Bridge: Intel® X58 Express Chipset
South Bridge: Intel® ICH10R
Memory
4 x 1.5V DDR3 DIMM sockets supporting up to 16 GB of system memory (Note 1)
Dual/3 channel memory architecture
Support for DDR3 2100+/1333/1066/800 MHz memory modules
(Go to Memory Support List for the latest memory support list.)
Audio
Realtek ALC888 codec
High Definition Audio
2/4/5.1/7.1-channel
Support for S/PDIF In/Out
Support for CD In
2/4/5.1/7.1-channel
Support for CD In
LAN
1 x Realtek 8111C chips (10/100/1000 Mbit)
Expansion Slots
2 x PCI Express x16 slots, running at x16 x16
(the PCI Express slots conform to PCI Express 2.0 standard.)
1 x PCI Express x4 slot
2 x PCI Express x1 slot
2 x PCI slots
2 x PCI slots
Storage Interface South Bridge:
6 x SATA 3Gb/s connectors (SATA2_0, SATA2_1, SATA2_2, SATA2_3, SATA2_4, SATA2_5) supporting up to 6 SATA 3Gb/s devices
Support for SATA RAID 0, RAID 1, RAID 5, and RAID 10
GIGABYTE SATA2 chip:
1 x IDE connector supporting ATA-133/100/66/33 and up to 2 IDE devices 2x SATA 3Gb/s connectors (GSATA2_0, GSATA2_1) supporting up to 2 SATA 3Gb/s devices
Support for SATA RAID 0, RAID 1 and JBOD
iTE IT8720 chip:
1 x floppy disk drive connector supporting up to 1 floppy disk drive
IEEE 1394
T.I. TSB43AB23 chip
Up to 3 IEEE 1394a ports (1 on the back panel, 2 via the IEEE 1394a brackets connected to the internal IEEE 1394a headers)
T.I. TSB43AB23 chip
USB
Integrated in the South Bridge
Up to 12 USB 2.0/1.1 ports (8 on the back panel, 4 via the USB brackets connected to the internal USB headers)
Internal I/O Connectors
1 x 24-pin ATX main power connector
1 x 8-pin ATX 12V power connector
1 x IDE connector
8 x SATA 3Gb/s connectors
1 x CPU fan header
3 x system fan headers
1 x power fan header
1 x North Bridge fan header
1 x front panel header
1 x front panel audio header
1 x CD In connector
1 x S/PDIF In header
1 x S/PDIF Out header
2 x USB 2.0/1.1 headers
1 x IEEE 1394a headers
1 x serial port header
1 x power LED header
1 x chassis intrusion header
1 x clearing CMOS jumper
1 x IDE connector
1 x CPU fan header
1 x CD In connector
Back Panel Connectors
1 x PS/2 keyboard port
1 x PS/2 mouse port
1 x coaxial S/PDIF Out connector
1 x optical S/PDIF Out connector
2 x IEEE 1394a port
8 x USB 2.0/1.1 ports
1 x RJ-45 ports
6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone)
1 x PS/2 mouse port
2 x IEEE 1394a port
1 x RJ-45 ports
I/O Controller
iTE IT8720 chip
iTE IT8720 chip
H/W Monitoring
System voltage detection
CPU/System/North Bridge temperature detection
CPU/System/Power fan speed detection
CPU overheating warning
CPU/System/Power fan fail warning
CPU/System fan speed control (Note 2)
BIOS
2 x 16 Mbit flash
Use of licensed AWARD BIOS
Support for DualBIOS™
PnP 1.0a, DMI 2.0, SM BIOS 2.4, ACPI 1.0b
2 x 16 Mbit flash
Unique Features
Support for @BIOS
Support for Q-Flash
Support for Dual BIOS
Support for Download Center
Support for Xpress Install
Support for Xpress Recovery2
Support for EasyTune (Note 3)
Support for Dynamic Energy Saver Advanced
Support for Time Repair
Support for Q-Share
Support for @BIOS
Support for Q-Flash
Support for Q-Share
Bundle Software
Norton Internet Security (OEM version)
Operating System
Support for Microsoft® Windows Vista/XP
Form Factor
ATX Form Factor; 30.5cm x 24.4cm
As you can see, Gigabyte have only very slightly trimmed some of the excess fat from the UD3R's bigger brother, the UD4P. The most significant difference is the omission of two DDR3 ram slots. Having just 3+1 ports might affect those wishing to utilise huge amounts of DDR3 but for the average user 6+GB is ample.
Let's take a closer look at the motherboard itself...
Nice review mate.
If I were to get the inkling to go I7, this board would probably make the shortlist. Performance at a good price is always a winner.
Teehee £158 for "budget"...
*wanders off muttering to self about what the motherboard market has come to*
*wanders off muttering to self about what the motherboard market has come to* |
Considering the kind of systems u can still buy with 775 and get an equal terms use out of it. Performance on a par.
Nice mobo, but u can get an EP45-DS5 for around £120 (at least I did), and clock the eff out of whatever proven cpu. And that's a ddr2 option. Heck get urself 8g of nothingness whilst ur at it and u still have cash left, from what u didn't buy the I7 kit with, to buy a GTX260/275/280/285 to build a rig not to be sniffed at.
Prices of motherboards have been rising for a long time now. You are always going to pay top dollar for cutting edge technology. Take SSD's for example: for a 30GB SSD you could have 2TB of standard drives in raid 0!
Aye w3bbo - I'm just reminiscing of the old days, in 939 and the like, where £150 would buy you the best board out there
You just cant do that with I7 mobos.
EVGA Classified - £380
Gigabyte UD3R - £150
Less than half the price?
X58 boards are expensive yes, but it's fair to say that there's a reason why. The X58 chipset as such is not exactly basic with the sheer number of PCI-E lanes, triple channel memory controller and as I understand the power regulation on these boards must have to be fairly strong for these 130W TDP CPU's. Combined with the fact that Intel is well aware that there is no true Core i7 competitor that they are free to price their CPU's and Chipsets accordingly. That being said, I don't believe that the overall i7 adoption cost is so bad these days with the price of respectable DDR3 kits taking a nose dive and more "budget" friendly i7 boards like the EX58 UD3R making an appearance.
I see prosser13's argument with regards to AMD boards and I do recall my legendary DFI LanParty UT nF4 series motherboard that at £90 would reach high base HTT's in excess of 300MHz but the AMD nForce boards were historically cheaper than Intel equivalents like for like. I remember the Canterwood 875P boards sitting around the £100 mark but that was ever so long ago and ever since I recall the higher end 925XE, 955X, 975X, X38/48 boards all exceeding £175. The X58 is no exception.
I do however like what this £160 motherboard acheives and think it's a fantastic buy if you believe that you can take advantage of the perks from the Core i7 platform but have a restricted budget. Excellent review W3bbo
I see prosser13's argument with regards to AMD boards and I do recall my legendary DFI LanParty UT nF4 series motherboard that at £90 would reach high base HTT's in excess of 300MHz but the AMD nForce boards were historically cheaper than Intel equivalents like for like. I remember the Canterwood 875P boards sitting around the £100 mark but that was ever so long ago and ever since I recall the higher end 925XE, 955X, 975X, X38/48 boards all exceeding £175. The X58 is no exception. I do however like what this £160 motherboard acheives and think it's a fantastic buy if you believe that you can take advantage of the perks from the Core i7 platform but have a restricted budget. Excellent review W3bbo ![]() |
)Quote:
As for SSD, I can't see me ever buying a current day SSD. I'm confident enough to allow quote-age on that.
BTW, this board DOES support SLI and the warranty will NOT be affected.
It's just a BIOS (F5) update - that is it!
Maybe other brands will void the warranty, but not Gigabyte.
And well done for picking up our new EZ-Share technology
Allowing you to share and safe profiles.
You should receive a prize for that
Ah cool.
So will Gigabyte be stopping production of the UD3R - SLI then?
Ah cool.
So will Gigabyte be stopping production of the UD3R - SLI then? |
Gigabyte UD3R - £150 Less than half the price? |
Originally Posted by name='GigaMan'
No, the UD3R - SLI will go ahead, we think that it will just make sense and will create less confusion in the market.
BTW, welcome to the forums GigaMan. It's always nice to have company reps give feedback and add info as appropriate
.Review updated and score ammended to reflect the fact that this motherboard now supports SLI with the latest BIOS update. Well done Gigabyte!
Its a good thing all these companies make so many different models of boards, chips, graphics, chips,, etc... as it means we can still get our hands on a wide variety of performance parts
I mean otherwise the only places that would be seeing these i7 and quad cores would be corporate and buisness sectors!!
i do think they should get some sort of regulations about newer products should always be significantly more powerful than older model's and the improvement % should be equivalently higher!!
as every1 knows : you do get headaches upgrading all the time!!
Just to put that side of ur mind at rest, I work at one of the biggest corporations in the country and nation-wide they use 10s of 1000s of pcs, mostly p4 with a large sprinkling of c2d. Very small % of 45nm.
... and tbf they do their job.
http://www.overclock3d.net/gfx/artic...162023939s.jpg
Read the full review HERE
