Gigabyte EP45-UD3P (P45) Motherboard
Packaging and Appearence
Published: 17th November 2008 | Source: Gigabyte | Price: £135.69 |
Packaging and Appearance
Gigabyte are not widely known for their quality packing, and there is nothing really to shout about with the packaging of the EP45-UD3P either. Being the usual white glossy box, it could quite easily be mistaken for one of its lesser stable mates were it not for its name being emblazoned across the front of the box. This is in stark contrast to our previous review of the Gigabyte EP45-Extreme, which was among one of the best motherboard packages we have seen to date.
The actual package we received was damaged, with the box being torn across the front, so I was quite concerned that the motherboard could have also been damaged. Luckily, the accessories are hidden behind the box front, which appeared to have cushioned/deflected the blow somewhat. Presuming you have a delivery person who has an ounce of pride for the work he does, then the box itself should be enough to protect things from any unforeseen damage. Still, I would like to see an improvement in the way Gigabyte package their products nonetheless.
The rear of the box goes on to describe how the extra copper in the PCB increases the motherboards potential performance along with the numerous other Ultra Durable features of the motherboard. The accessory list is a standard affair, customary with other Gigabyte boards from the EP45 range.
The motherboard itself is very bright and, as per usual of Gigabyte, the colour scheme is somewhat reminiscent of Joseph's dream coat. This time, however, Gigabyte have added some funky heat sinks to the board. The Southbridge and Top Mosfet cooler are anodised blue aluminium while the Northbridge and side Mosfet coolers are gunmetal grey with blue aluminium tops added for aesthetics. The appearance of the board would be quite appealing were it not for the clashing red/yellow memory slots and other randoms colours splattered about the board. The layout of the board is excellent with all the connectivity ports around the edges save for the SATA ports, but these will not be obstructed by a dual slot cooler as we found with the EP45 Extreme.
The CPU socket is not overly cramped and most if not all coolers should fit with relative ease. Gigabyte still use a 6 phase power design for the CPU which, coupled with the low resistance PCB, should be enough to provide the CPU with a clean, stable power supply. The memory sockets may look the same as most other Gigabyte DIMM's, but these officially support scorching 1366mhz DDR2 speeds which, at the time of writing is the highest officially supported speed of any DDR2 motherboard. While there are no DDR2 modules capable of running this speed at stock, the excess speed available could be attained with overclocking, so it's nice to know Gigabyte do support such speeds should you have the memory capabilities.
The PCI layout is logical and well laid out, with two PCI Express 2.0 x16 slots, three PCI Express x1 slots and two PCI slots for backwards compatibility on this board. Crossfire can be enabled on this board, but the two cards will be restricted to eight lanes each as the P45 chipset does not have enough PCI Express lanes to do x16 + x16. There is plenty of scope for storage with the UD3P, as there are a total of 8 SATA ports on board with 6 on the Intel controller and the remaining two utilising the Silicon Image controller. With an IDE port as well as a floppy port still available, the connectivity of the UD3 caters for both new and old hardware alike.
The I/O area of the board contains 8 USB 2.0 ports, an IEEE1394a and an IEEE1394b port, two Gigabit RJ45 jacks that allow the board to support LAN Teaming, and a PS/2 port for both Keyboard and mouse. It is nice to see Gigabyte still holding a candle for the technology of yesteryear, but I can't imagine anyone still persisting with PS/2 technology now that USB is so abundant. Rounding off the I/O area is the audio. For this, Gigabyte have chosen to use the Realtek ALC889a chip which feeds the 7.1 3.5mm jacks as well as S/PDIF Coaxial and Digital Out ports.
Removing the heatsink assembly was very easy. Only the Northbridge sink had screw fixings, which was disappointing, while the Mosfet and Southbridge used the plastic push-pin method of attachment. Even so, the mounts were fine with good contact throughout and no sign of excessive TIM being used, which is always a bonus. Sadly, there was no copper in sight this time around, with the whole heatsink assembly being aluminium. I guess the PCB took all the copper reserves!
The CPU socket area is much cleaner without a heatsink in place and has the same size hole spacing around the mosfets as other Gigabyte P45 boards should you wish to add your own cooling instead of the bright blue Gigabyte affair.
Good mounts were found on the Northbridge, testament to the screw/spring fixings ensuring an even mount, while the Southbridge, which doesn't get too hot anyway, has a thermal pad instead of paste to form contact with the heatsink.
So then, a board that has the qualities to become something special while carrying the trademark features of other EP45 boards. Let's take a look at the BIOS...
Nice review Webbo.
It's a tricky judgement to make on this mobo, one of the many they have.
They seem to have done a 'good' job of making a ddr2 mobo, from a ddr3 chipset, and it sorta holds it's own with the competition. Doesn't particularly beat anything out-of-the-water, and neither does it drop way-way back on anything. U see it drop on something and in the next stat it's up again. Average it out and it does 'good'.
I struggle to understand why they bother bolting it down from ddr3, and not just stick with the ddr3 mobos. It could be argued they have both types already, in both 3 and 4 series, so I'm stumped further.
It does a great job in the 3d department, so ur gaming isn't going to suffer in anyway. If ur a Gigabyte fan, it won't exactly let u down and u can drag that ddr2 with u.
Not exactly an eyebrows-raiser, but ok it does 'good'. £115 - yeah ok, it's amongst the competition there too.
Curious about the bios.
Thanks for the feedback as always Rasta
. The BIOS is pretty easy to use as with all Gigabyte boards but as with the EXTREME, scrolling through the BIOS is jerky. Not an issue if you only use it once or twice but it can become irratating if your constantly using it.
. The BIOS is pretty easy to use as with all Gigabyte boards but as with the EXTREME, scrolling through the BIOS is jerky. Not an issue if you only use it once or twice but it can become irratating if your constantly using it.Ah thnx for the tip
I gotta rip open an EP35-DS4 tonite
Not noticed it with the P35's tbh, just the P45's. Like I said it's not a biggie, just something worth mentioning.
Jeez, felt I had to report back. Installed the EP35 DS4 and frankly it's a great mobo. I have no idea of the benchies or anything, but I've installed it in a mATX style case that takes ATX mobos, with a wifi, 3 drives, and hopefully 4 OSes. It's gonna be my util pc, easy to move about.
(had to get this model cos of its SATA port arrangement and the 8 usb ports on the io plate)
Just about got a 8800GT in the case, Q9400, 4 gig, blah blah.
Put an Intel Extreme cooler on the cpu, and simply changed 2 things in the bios. Memory to 2x 333 base (from 2.4 auto), and cranked up the fsb to make the cpu 3g. Piece of cake, idles at under 30 - which I was amazed at.
One special bonus was the ALC889A, dts and the drivers seem to work in Vista 64bit !
With a fsb 1600 also, I will be recommending this mobo for it's ease.
Great to hear
One great thing about the Gigabyte boards is it's ease of use. You can make it as complicated or as easy as you want and it's something I will be emphasising more on in future reviews.
.One great thing about the Gigabyte boards is it's ease of use. You can make it as complicated or as easy as you want and it's something I will be emphasising more on in future reviews.
One BIG issue I do have is the lack of fan control via the bios. Dunno if there's something for me to discover, but I like the fact ABit chose for a long time to allow u to vary ALL the fan headers with the temps of 4 different things. Thus far I can only see a cpu one via software, although there is a fixed yes/no option in the bios - not very helpful. I introduced a spare Akasa 3pin pot to stop the rear fans sounding like an aeroplane.
Tell me more about this – is this really important?
BTW, others are free to comment.
I would like to know because maybe I can assist with this!
Well, at least I can find out.
Afaic, I consider myself spoilt to have over the years had some great ABit mobos with all the glory that went along with it.
*cough* excuse the sentimentality *cough*
Being serious tho, in conjunction with the uGuru, their mobos, as far back as the amd k6 afaik, have allowed u to manipulate ALL of the 3 pin fan headers on the mobos against either cpu/sys and latterly pwm avg/pwm max also.
Now from an enthusiast pov, in particular - mine, this breaks open so many options in terms of pc cooling, that sure can be covered by purchasing overpriced fan controllers. But put on top of that, the ability to quieten the pc to absolute silence when ur not using it fully.
To give an example of Abit's last carnation, although it's true for the 35/38/48:
Invariably 6x 3 pin headers (1 being 4 on the cpu designated).
Each of them can select a low voltage % or volt, also the high.
Couple with that, the option of the low/high temps to span this over.
Then the option to change each of the 6 to compare the temps of cpu/pwmAV/pwmMax/sys.
(further changes, level wize, can be made by FanEQ in uGuru)
(another +ve is that it doesn't make fan control windows specific, as u dont have to rely on the mobo manufacturers util prog to control it)
This means u can have the fan on ur drives quiet as they only spin faster if,e.g., the SYS temp rises.
The cpu fan, or fans (ofc u can turn the likes of a ninja into a 2 fan-ed device with this mobo) varying with the cpu temp.
Ram cooler, notoriously winey small noises, but not when u vary it's speed with the pc's temp.
Additionally, as on my 38 & 48, u can have a tiny fan on ur pwm/nb/sb that varies similary.
This being said. At the end of the day u can have 6 sets of fans in ur case and not have all of them sounding like tornados. It kinda negates some of the cooling things other case or mobo manufacturers add to their setups in terms of quiet-cooling cos u can stick with the age-old fan system without being noisy.
I don't know that ASUS/MSI/DFI/etc dont do something exactly the same, as tbh I've not been interest whilst ABit were at the fore-front, but looking to the future I will have to make some decisions on who to pip for. To this point the Gigabyte P35-DS4 covers everything I need, except for the fan options above. I believe it does standard cpu control and something else. Outside of that it is a very capable mobo. Overclocking on it was a 3 step process of crazy simplicity.
(Only other issue with the mobo is that it wont boot past the cpu post, kinda hangs displaying the 2nd "M" of "memory", if I have a mouse plugged in the usb port of the Apple aluminum keyboard - not a fault I imagine)
was planning on using this board in my next build, this review sealed the deal for me
http://www.overclock3d.net/gfx/artic...164426793s.jpg
