DFI X48 UT-T3RS Motherboard
Hard Drive Benchamrks
HDTach is a free hard disk benchmarking program from SimpliSoftware. This benchmark is not only capable of producing results on hard disk access times but also CPU usage required during disk access. The "Long bench" was run a total of 5 times with the highest and lowest results being omitted and an average calculated from the remaining 3 results.
 Burst speed
Read Speed
Random access
CPU Utilization
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
Read index
Results Conclusions
It is apparent that the Intel chipsets are still a little behind the NVidia chipsets when HD performance is concerned, although the gap has closed somewhat of late. Having said that the DFI can still holds its own in this department scoring well across the range of tests.
«Prev 1 2 3 4 5 6 7 8 9 10 11 Next»
27-08-2008, 15:39:13
w3bbo
"A premium chipset paired with DFI's overclocking prowess - an enthusiasts wet dream? We put DFI's latest motherboard, the Lanparty X48-T3RS, through its paces to satisfy your loins."
http://www.overclock3d.net/gfx/artic...203719426s.jpg
Read the full in-depth review HERE .Quote
27-08-2008, 15:59:47
nepas
nice review mate as always.you sounded a bit unhappy with the fact that you dont get quick and dirty clocks with the DFI,I treat that as one of their trademarks if anything(the bios on a DFI can be a pretty scary place compared to others).Nice to see that it broke the record anywayQuote
27-08-2008, 16:29:14
Rastalovich
Nearly bought this board ...
Today I received an Abit IX48 GT3, and have to modify a scythe ninja (trim 4 fins) in order to get past the skycraper of a nb cooler!
What is the deal with all these cokey coolers ? Why we want a wad of heatsink sticking out the back of the case ? Why we want big arse tower things ?
Just give us an oustanding board with decent cooling... most of the hardcored guys take them off anyways.Quote
27-08-2008, 17:12:52
FarFarAway
I'm sorry Rast, that boards cooling is simply gorgeous. Unless you're watercooling you won't need to replace it.
Great review. As always, DFI's are nail-biting, scream-inducing overclocking nightmares but if you fiddle long enough they hit the spot big time
Originally Posted by webbo
- EZ Clear switches don't ALWAYS clear CMOS.
- EZ Cear switches look basic in comparison to other boards.
Stretching the mediocre points a little I feel, I've not met an EZ Clear CMOS switch that works every time yet to be honestQuote
27-08-2008, 17:51:16
w3bbo
I had that X38 a couple of weeks before I sold it to you m8 and tbh that was pretty similar. I just felt that although the overclock was better than the rest the time it took to get even a half decent (3.6ghz) overclock took alot more effort than with other motherboards and taking into account the numerous (my fingers actually got sore pressing the EZ-Clear switches) BIOS resets it became a frustrating affair rather than a joyous one.
It IS an outstanding board and it has THE best cooling setup on any board I have ever used, add a thermalright Ultra extreme and you have perhaps the best aircooled solution around - certainly the best looking!
I guess it comes down to your point of view. Overclocking has never been so easy with other boards, maybe that takes some of the fun out of it or maybe it relieves the stress of endlessly rebooting, stress testing resetting BIOS etc.
Point taken over the switches, I was just peeved while writing the conclusion as I was stupidly running the chip at 3.9ghz( I'm always one to push things as far as possible lol) and had a BSOD when the conclusion was almost complete. The board then wouldn't reboot (again) without a jumper switch. Grrrrr
That said there's simply no doubting it's one hell of a clocker and providing you have the patience, as the review showed, the overclocking results can be astounding.Quote
27-08-2008, 18:18:40
Ham
I wish more companies would adopt the digi PWM. the socket area is just so much cleaner.
Just cries out 'insulate me!'
Fantastic job as ever webbo!Quote
27-08-2008, 20:01:50
Bungral
Wow... It's so flat and clean it reflects logos that aren't actually there
http://www.overclock3d.net/gfx/artic...131911733l.jpgQuote
28-08-2008, 03:17:09
JN
Ahh damnit, looks like webbo forgot to remove the oc3d logo stuck to the lens of his camera for that shot. Quote
28-08-2008, 04:56:53
Luigi
haha
Either that or DFI engraved it specially Quote
28-08-2008, 09:28:47
Bungral
Ha that would be quite funny actually...
Quote
28-08-2008, 09:32:41
Rastalovich
Even funnier if the image was reversed and upsidedown Quote
29-08-2008, 12:05:24
w3bbo
Stops the scumbags from stealling my 1337 photography skillsQuote
