DFI X48 UT-T3RS Motherboard
Search Reviews
LanpartySummarising this review is not going to be easy. While on the one hand, the DFI is clearly a very accomplished board with a very thorough and complex BIOS resulting in some fantastic performance, on the other hand, there are now boards out there that can achieve similar performance without all the stress, grief and mountains of patience required. While on the A64 platform the DFI was king of the overclockers, the Intel market has seen Asus, Abit and Gigabyte make leaps and bounds in the enthusiast market, so now the lead DFI had is all but gone.
It has been a while since I had a play with a DFI board and this is my first outing on an Intel DFI so I was particularly interested in if DFI had changed its approach to overclocking compared to my old DFI Ultra-D. Thankfully it has not. The numerous amount of options and tweaking available on this board are second to none. IF you know what you are doing and IF you are an accomplished overclocker then I can wholeheartedly recommend this board. You will simply be blown away with the sheer power that is available at your finger tips and if you can bare the frustration involved in getting to grips with those options then you will have found a new best friend.
If however, you are new to the dark arts then this board will scare you (and no doubt your components) witless. It's all very well having all the options in the world at your fingertips but unless you have some form of understanding of what 'those buttons do' then the end result could quite easily be a doomed overclock or worse, fried hardware.  I wouldn't let my 3 yr old drive my car, much the same I wouldn't advise a novice to buy this board.
I am still unsure as to whether I love the board or hate it. The motherboard on test broke our current best clock for our test Q6600 but the amount of frustration that went with it has tainted the glory somewhat. 'No Pain - No Gain' so they say but call me lazy, I'm actually getting quite used to achieving some quick and easy overclocks.
The Good
- Supreme overclocking.
- Thermalright cooling.
- Funky colour scheme.
- Removable Northbridge section.
- Digital PWM.
- Solid caps all round for durability.
The Mediocre
- EZ Cear switches look basic in comparison to other boards don't ALWAYS clear CMOS..
- BIOS scrolling. Input method could be better.
- Bernstein Audio. Good but not great for a £200 motherboard.
The Bad
- Poor recovery from a bad overclock.
- BIOS update procedure tedious.
- CMOS clear with dual slot crossfire cards will be impossible without removing the lower card first.
Overclock3D Performance Award
Thanks to DFI for providing the X48-T3RS for review. Discuss this review in our forums.
«Prev 1 2 3 4 5 6 7 8 9 10 11 Next»
27-08-2008, 15:39:13
w3bbo
"A premium chipset paired with DFI's overclocking prowess - an enthusiasts wet dream? We put DFI's latest motherboard, the Lanparty X48-T3RS, through its paces to satisfy your loins."
http://www.overclock3d.net/gfx/artic...203719426s.jpg
Read the full in-depth review HERE .
27-08-2008, 15:59:47
nepas
nice review mate as always.you sounded a bit unhappy with the fact that you dont get quick and dirty clocks with the DFI,I treat that as one of their trademarks if anything(the bios on a DFI can be a pretty scary place compared to others).Nice to see that it broke the record anyway
27-08-2008, 16:29:14
Rastalovich
Nearly bought this board ...
Today I received an Abit IX48 GT3, and have to modify a scythe ninja (trim 4 fins) in order to get past the skycraper of a nb cooler!
What is the deal with all these cokey coolers ? Why we want a wad of heatsink sticking out the back of the case ? Why we want big arse tower things ?
Just give us an oustanding board with decent cooling... most of the hardcored guys take them off anyways.
27-08-2008, 17:12:52
FarFarAway
I'm sorry Rast, that boards cooling is simply gorgeous. Unless you're watercooling you won't need to replace it.
Great review. As always, DFI's are nail-biting, scream-inducing overclocking nightmares but if you fiddle long enough they hit the spot big time
Originally Posted by webbo
- EZ Clear switches don't ALWAYS clear CMOS.
- EZ Cear switches look basic in comparison to other boards.
Stretching the mediocre points a little I feel, I've not met an EZ Clear CMOS switch that works every time yet to be honest
27-08-2008, 17:51:16
w3bbo
I had that X38 a couple of weeks before I sold it to you m8 and tbh that was pretty similar. I just felt that although the overclock was better than the rest the time it took to get even a half decent (3.6ghz) overclock took alot more effort than with other motherboards and taking into account the numerous (my fingers actually got sore pressing the EZ-Clear switches) BIOS resets it became a frustrating affair rather than a joyous one.
It IS an outstanding board and it has THE best cooling setup on any board I have ever used, add a thermalright Ultra extreme and you have perhaps the best aircooled solution around - certainly the best looking!
I guess it comes down to your point of view. Overclocking has never been so easy with other boards, maybe that takes some of the fun out of it or maybe it relieves the stress of endlessly rebooting, stress testing resetting BIOS etc.
Point taken over the switches, I was just peeved while writing the conclusion as I was stupidly running the chip at 3.9ghz( I'm always one to push things as far as possible lol) and had a BSOD when the conclusion was almost complete. The board then wouldn't reboot (again) without a jumper switch. Grrrrr
That said there's simply no doubting it's one hell of a clocker and providing you have the patience, as the review showed, the overclocking results can be astounding.
27-08-2008, 18:18:40
Ham
I wish more companies would adopt the digi PWM. the socket area is just so much cleaner.
Just cries out 'insulate me!'
Fantastic job as ever webbo!
27-08-2008, 20:01:50
Bungral
Wow... It's so flat and clean it reflects logos that aren't actually there
http://www.overclock3d.net/gfx/artic...131911733l.jpg
28-08-2008, 03:17:09
Jim
Ahh damnit, looks like webbo forgot to remove the oc3d logo stuck to the lens of his camera for that shot.
28-08-2008, 04:56:53
Luigi
haha
Either that or DFI engraved it specially
28-08-2008, 09:28:47
Bungral
Ha that would be quite funny actually...
28-08-2008, 09:32:41
Rastalovich
Even funnier if the image was reversed and upsidedown
29-08-2008, 12:05:24
w3bbo
Stops the scumbags from stealling my 1337 photography skills
