DFI X48 UT-T3RS Motherboard
3D Gaming Benchmarks
Published: 27th August 2008 | Source: DFI | Price: £200.00 |
Quake 4 is a game built on the Doom 3 engine. Benchmarking was performed using Quake4Bench and a custom timedemo recording along with 0xAA, 0xAF settings at a resolution of 1024x768. The benchmark was set to run a total of 5 times, with Quake4Bench automatically calculating an average result at the end of the run.
F.E.A.R. is a game based on the Lithtech Jupiter EX engine. It has volumetric lighting, soft shadows, parallax mapping and particle effects. Included in the game is a benchmark facility that taxes the entire PC system. This benchmark was run a total of 5 times, with the highest and lowest results being excluded and an average being calculated on the remaining 3 results.
Bioshock is a recent FPS shooter by 2K games. Based on the UT3 engine it has a large amount of advanced DirectX techniques including excellent water rendering and superb lighting and smoke techniques. All results were recorded using F.R.A.P.S with a total of 5 identical runs through the same area of the game. The highest and lowest results were then removed, with an average being calculated from the remaining 3 results.
Results Conclusion
Here the DFI had less of an advantage and split the pack straight down the middle. I found it strange that the DFI performed near the top of the pile in the synthetic benchmarks yet could reproduce those same results in the gaming arena. That's not to say the DFI didn't perform well as it clearly did, especially in Bioshock but I would have thought that, taking the synthetic benchmarks into account, the gap would be higher. Still, an all round good performance from the DFI mainboard.
Today I received an Abit IX48 GT3, and have to modify a scythe ninja (trim 4 fins) in order to get past the skycraper of a nb cooler!
What is the deal with all these cokey coolers ? Why we want a wad of heatsink sticking out the back of the case ? Why we want big arse tower things ?
Just give us an oustanding board with decent cooling... most of the hardcored guys take them off anyways.
Great review. As always, DFI's are nail-biting, scream-inducing overclocking nightmares but if you fiddle long enough they hit the spot big time
Originally Posted by webbo
- EZ Clear switches don't ALWAYS clear CMOS.
- EZ Cear switches look basic in comparison to other boards. |
Originally Posted by name='nepas'
nice review mate as always.you sounded a bit unhappy with the fact that you dont get quick and dirty clocks with the DFI,I treat that as one of their trademarks if anything(the bios on a DFI can be a pretty scary place compared to others).Nice to see that it broke the record anyway
Originally Posted by name='Rastalovich'
Nearly bought this board ...
Today I received an Abit IX48 GT3, and have to modify a scythe ninja (trim 4 fins) in order to get past the skycraper of a nb cooler! What is the deal with all these cokey coolers ? Why we want a wad of heatsink sticking out the back of the case ? Why we want big arse tower things ? Just give us an oustanding board with decent cooling... most of the hardcored guys take them off anyways. |
Stretching the mediocre points a little I feel, I've not met an EZ Clear CMOS switch that works every time yet to be honest |
Point taken over the switches, I was just peeved while writing the conclusion as I was stupidly running the chip at 3.9ghz( I'm always one to push things as far as possible lol) and had a BSOD when the conclusion was almost complete. The board then wouldn't reboot (again) without a jumper switch. Grrrrr
That said there's simply no doubting it's one hell of a clocker and providing you have the patience, as the review showed, the overclocking results can be astounding.
Just cries out 'insulate me!'
Fantastic job as ever webbo!
http://www.overclock3d.net/gfx/artic...131911733l.jpg
Originally Posted by name='Bungral'
Wow... It's so flat and clean it reflects logos that aren't actually there
![]() http://www.overclock3d.net/gfx/artic...131911733l.jpg |
Either that or DFI engraved it specially
Originally Posted by name='Jim'
Ahh damnit, looks like webbo forgot to remove the oc3d logo stuck to the lens of his camera for that shot.
Ha that would be quite funny actually...
http://www.overclock3d.net/gfx/artic...203719426s.jpg
Read the full in-depth review HERE .
