DFI X48 UT-T3RS Motherboard
Search Reviews
LanpartyIn years gone by, DFI was the motherboard of choice for overclockers worldwide. The AMD Skt 939 NF4 Ultra-D was the jewel in DFI's crown, attracting praise from all sectors due to its ultimate overclocking prowess and to a lesser extent, its funky looks. So then, it seemed DFI could do no wrong. Sadly, DFI appeared to drop off the map when Intel's dominance became prevalent with the Core2 series of chips. Asus and Gigabyte took centre stage and enjoyed booming sales due in part to DFI's absence.
Having a solid background of working with NVidia chipsets, DFI released a 680i variant of its Lanparty series but the 965/975 chipsets from Intel were found wanting. It wasn't until the advent of Intel's P35 chipset that we witnessed the switch from NVidia to Intel. With the Lanparty branding still present and the trademark UV slots, DFI were welcomed back with open arms. However, due to hold ups and research in this unfamiliar territory, the Lanparty boards were not released on the chipsets launch, instead arriving midway through the season, which in hindsight is a good thing as the chipsets had time to mature. DFI released not one board but a trio, The DK(Dark), LT(Lethal Tweaking) and UT(Ultra Tweaking), catering for everyone's pocket and needs. The Thai based manufacturer gathered momentum with the X38 LT-T2R proving to be a tremendous board, cementing DFI's return to the limelight (pun intended!).
Today we will be taking a look at DFI's latest Lanparty creation in the form of its flagship X48-T3RS. DDR3, full Crossfire support and topped off with Intel's latest and greatest chipset - the X48 series.
Specification
The DFI Lanparty X48-T3RS specifications were taken directly from the DFI product page.
CPU
LGA 775 socket for:
- Intel® CoreTM2 Quad and Intel® CoreTM2 Duo
Supports Intel Enhanced Memory 64 Technology (EMT64T)
Supports Enhanced Intel SpeedStep Technology (EIST)
Supports Intel Hyper-Threading Technology
Supports 1600/1333/1066/800MHz FSB
Chipset
Intel® chipset
- Northbridge: Intel® X48 Express chipset (with Intel® Fast Memory Access technology)
- Southbridge: Intel® ICH9R
System Memory
Four 240-pin DDR3 DIMM sockets
Supports DDR3 1600MHz (O.C 1800/2000 MHz)
Delivers up to 21.3Gb/s bandwidth at 1333MHz,(25.6GB/s bandwidth at 1600MHz)
Supports dual channel (128-bit wide) memory interface
Supports up to 8GB system memory
Supports unbuffered x8 and x16 DIMMs
Expansion Slots
2 PCI Express (Gen 2) x16 slots (PCIE 1 and PCIE 3)
- 2-way CrossFire at x16/x16 bandwidth
- 2-way CrossFire + Physics at x16/x16/x4 bandwidth
1 PCI Express x1 slot (PCIE 2)
1 PCI Express x4 slot (PCIE 4)
3 PCI slots
BIOS
Award BIOS
8Mbit flash memory
CMOS Reloaded
Audio
Bernstein audio module
- Realtek ALC885 8-channel High Definition Audio CODEC
- Center/subwoofer, rear R/L and side R/L jacks
- Line-in, line-out (front R/L) and mic-in jacks
- 2 coaxial RCA S/PDIF-in/out jacks
- 1 optical S/PDIF connector
- 1 CD-in connector
- 1 front audio connector
DAC SNR/ADC SNR of 106dB/101dB
Full-rate lossless content protection technology
LAN
Marvell 88E8052 and Marvell 88E8053 PCIE Gigabit LAN controllers
Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
IEEE 1394
VIA VT6307
Supports two 100/200/400 Mb/sec ports
Power Management
Ultimate 8-phase digital PWM with 18 MOSFETs
ACPI and OS Directed Power Management
ACPI STR (Suspend to RAM) function
Wake-On-PS/2 / Wake-On-USB Keyboard/Mouse
Wake-On-LAN and Wake-On-Ring
RTC timer to power-on the system
AC power failure recovery
Storage
Intel ICH9R chip
- Intel Matrix Storage technology
- Supports up to 6 SATA devices
- SATA speed up to 3Gb/s
- RAID 0, RAID 1, RAID 0+1 and RAID 5
JMicron JMB363 PCI Express to SATA and PATA host controller
- Supports up to 2 UltraDMA 100Mbps IDE devices
- Supports 2 SATA devices
- RAID 0 and RAID 1
Rear Panel I/O Ports
Mini-DIN-6 PS/2 mouse port and PS/2 keyboard port
1 IEEE 1394 port
6 USB 2.0/1.1 ports
2 RJ45 LAN ports
I/O Connectors
3 connectors for 6 additional external USB 2.0 ports
1 connector for an external COM port
1 connector for an IEEE 1394 port
1 connector for the Bernstein audio module
1 front audio connector (on the Bernstein audio module)
1 CD-in connector (on the Bernstein audio module)
1 S/PDIF connector (on the Bernstein audio module)
1 IrDA connector
1 CIR connector
8 Serial ATA connectors
1 40-pin IDE connector and 1 floppy connector
1 24-pin ATX power connector
1 8-pin 12V power connector
2 4-pin 5V/12V power connectors (FDD type)
1 front panel connector
6 fan connectors
1 diagnostic LED
EZ touch switches (power switch and reset switch)
Hardware Monitor
Monitors CPU/system/Northbridge temperature and overheat alarm
Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
Monitors the speed of the cooling fans
CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
PCB
6 layers, ATX form factor
24.5cm (9.64") x 30.5cm (12")
The DFI sets its stall out well with quality components chosen for its premium board, making for a perfect foundation with which to overclock the nuts off both CPU and RAM. With support for 45nm processors and DDR3 it is obvious that the T3RS is aimed at the high-end of the market. Should you have the funds to fill those green and yellow memory slots, the board will support up to 8GB of DDR3 and overclock to 2000MHz! Being an X48 chipset the board natively supports ATI Crossfire configurations and with the quality Bernstein module included, the T3RS is sure to be a hit with the hardcore gamers out there.
Lets take a look at the motherboard's packaging and contents...
«Prev 1 2 3 4 5 6 7 8 9 10 11 Next»
27-08-2008, 15:39:13
w3bbo
"A premium chipset paired with DFI's overclocking prowess - an enthusiasts wet dream? We put DFI's latest motherboard, the Lanparty X48-T3RS, through its paces to satisfy your loins."
http://www.overclock3d.net/gfx/artic...203719426s.jpg
Read the full in-depth review HERE .
27-08-2008, 15:59:47
nepas
nice review mate as always.you sounded a bit unhappy with the fact that you dont get quick and dirty clocks with the DFI,I treat that as one of their trademarks if anything(the bios on a DFI can be a pretty scary place compared to others).Nice to see that it broke the record anyway
27-08-2008, 16:29:14
Rastalovich
Nearly bought this board ...
Today I received an Abit IX48 GT3, and have to modify a scythe ninja (trim 4 fins) in order to get past the skycraper of a nb cooler!
What is the deal with all these cokey coolers ? Why we want a wad of heatsink sticking out the back of the case ? Why we want big arse tower things ?
Just give us an oustanding board with decent cooling... most of the hardcored guys take them off anyways.
27-08-2008, 17:12:52
FarFarAway
I'm sorry Rast, that boards cooling is simply gorgeous. Unless you're watercooling you won't need to replace it.
Great review. As always, DFI's are nail-biting, scream-inducing overclocking nightmares but if you fiddle long enough they hit the spot big time
Originally Posted by webbo
- EZ Clear switches don't ALWAYS clear CMOS.
- EZ Cear switches look basic in comparison to other boards.
Stretching the mediocre points a little I feel, I've not met an EZ Clear CMOS switch that works every time yet to be honest
27-08-2008, 17:51:16
w3bbo
I had that X38 a couple of weeks before I sold it to you m8 and tbh that was pretty similar. I just felt that although the overclock was better than the rest the time it took to get even a half decent (3.6ghz) overclock took alot more effort than with other motherboards and taking into account the numerous (my fingers actually got sore pressing the EZ-Clear switches) BIOS resets it became a frustrating affair rather than a joyous one.
It IS an outstanding board and it has THE best cooling setup on any board I have ever used, add a thermalright Ultra extreme and you have perhaps the best aircooled solution around - certainly the best looking!
I guess it comes down to your point of view. Overclocking has never been so easy with other boards, maybe that takes some of the fun out of it or maybe it relieves the stress of endlessly rebooting, stress testing resetting BIOS etc.
Point taken over the switches, I was just peeved while writing the conclusion as I was stupidly running the chip at 3.9ghz( I'm always one to push things as far as possible lol) and had a BSOD when the conclusion was almost complete. The board then wouldn't reboot (again) without a jumper switch. Grrrrr
That said there's simply no doubting it's one hell of a clocker and providing you have the patience, as the review showed, the overclocking results can be astounding.
27-08-2008, 18:18:40
Ham
I wish more companies would adopt the digi PWM. the socket area is just so much cleaner.
Just cries out 'insulate me!'
Fantastic job as ever webbo!
27-08-2008, 20:01:50
Bungral
Wow... It's so flat and clean it reflects logos that aren't actually there
http://www.overclock3d.net/gfx/artic...131911733l.jpg
28-08-2008, 03:17:09
Jim
Ahh damnit, looks like webbo forgot to remove the oc3d logo stuck to the lens of his camera for that shot.
28-08-2008, 04:56:53
Luigi
haha
Either that or DFI engraved it specially
28-08-2008, 09:28:47
Bungral
Ha that would be quite funny actually...
28-08-2008, 09:32:41
Rastalovich
Even funnier if the image was reversed and upsidedown
29-08-2008, 12:05:24
w3bbo
Stops the scumbags from stealling my 1337 photography skills
