DFI Lanparty DK P45-T2RS Plus
Bios
Published: 19th December 2008 | Source: DFI | Price: £114.59 |
BIOS
The BIOS is sometimes the make or break factor in mid-range boards, especially the ones that are aimed at enthusiasts. DFI have once again gone for a Phoenix Award Bios, so veteran DFI users should feel right at home right from the getgo. Starting off by looking at the flashing procedures available to us, we can see that the slightly dated floppy disk is still the preferred method of updating the BIOS. Of course, you can always use a correctly formatted USB stick to feel a bit more modern. Unfortunately, DFI are yet to implement a nice, easy flash program into their boards as Asus and other manufacturers' have done. There is a Windows tool, but do we really want to go there?
Upon boot, you're greeted with a splash screen inviting you to select either the Anti-lock Breaking System Auto Boost System feature, which is essentially a one button overclock, or enter the BIOS. The overly familiar menu is presented upon loading, and of course we went straight over to the Genie BIOS settings section to take a peek at the tweaking options.
As you can see in the above screenshot, the board doesn't disappoint in tweakable settings. DFI have gone with their usual ploy of throwing the accepted naming conventions for settings out the window and coming up with their own, so getting to grips with everything can take a minute or two. As you can see, there are all of the basic settings you would need for a decent enough overclock. The ridiculous degree of settings that can be found in the BIOS' of the high-end DFI boards isn't present here, which to be quite frank I found welcoming. It makes the board feel like it was designed to be used by anyone, rather than people who spend more time in the BIOS that in their OS.
Three menus are available from the Genie page: the "CPU Feature", "DRAM Timing" and "Voltage Setting" pages. Separating these options keeps things nice and organised. The CPU feature hosts the usual settings that most enthusiasts just turn off on first boot, as well as an interesting 'Core Multi-Processing' option that cuts the CPU down to one core when enabled. The DRAM Timing menu possessed a decent number of customisable settings without going over the top. Finally, in the Genie BIOS settings there is the "Voltage Setting" menu which does pretty much what it says on the tin, with no unnecessary settings.
The second page of interest was the CMOS Reloaded menu. This allows you to save various profiles to the BIOS for future use. This is a feature which is seen on a lot of boards these days, and rightly so as trying to remember every setting can be tricky. The page allows the saving of three separate profiles with descriptions so that you know what each profile does. The last page of the BIOS we see is the "PC Health Status", providing all the information you'll need and a little more about temperatures, voltages and fan speeds.
Overall, I'm very impressed by the BIOS on the T2RS Plus. It has plenty of options and tweaks that you see on the high-end without going completely over the top. It should allow for some decent overclocks while not scaring the poor user to just knock up the FSB until unstable for fear of what the other settings might do.
Over the page we go into the test setup and overclocking for the T2RS...
I don't think i've seen a DFI board look so good since the 939 days...
All I get from this tbh is there is absolutely no point in getting it if u have an IP35 Pro. Which in all honesty, including the other 2 mobos, is an absolute disgrace imo.
It also has ALC885 sound.. which is pretty old afaik.
I will say tho, for fear of sounding like a scratched record, I feel these 4 series Intel boards would probably perform better with newer cpus.
Good review, being truthful I`d overlook this unless I see it doing well with newer cpus.
bah humbug to you rast
...I see what your saying...if it had been released 18 months ago it may have warranted more attention...still a decent performing board for the money though...I wouldn't build a current system round it but if your in the field for a replacement then its worth a look...although I think DFI may have been better looking at 1377 rather then sticking to an already tried (and tried(and tried)) formula....
...I see what your saying...if it had been released 18 months ago it may have warranted more attention...still a decent performing board for the money though...I wouldn't build a current system round it but if your in the field for a replacement then its worth a look...although I think DFI may have been better looking at 1377 rather then sticking to an already tried (and tried(and tried)) formula....To be really honest, it`s plain to me that the mobo is less use than the IP35 Pro. I have to wonder how it would cope against the IP35 Pro XE.
So, rather than 18 months, it`d be that time PLUS before the Intel 35 chipset was released.
I seriously don`t see the point in this board. For sure it`s a 35 mobo with a dropped in 45 chipset - purely on availablity I`d imagine.
But does this really signal that the 45 chipset is that much of an insignificance over the 35 ? It does have the advantage of being more ddr3 orientated - so in that sense, why is there not a full bank of ddr3 dimms ? The mere presence of ddr2 dimms means that (from what I read on enthusiast sections) a 45 chipset needs to be crippled to use ddr2. How much I don`t know.
hmmmm....I can see why they say crippled....but I suppose its down to the DDR2 in question...(and believe me Ive sold E8400's to people using a 4core dual sata which only takes up to DDR667 and only one channel max 2gb
some people) ...
Sorry my mistake I read 45 chip not chipset...thought it was reference to the 45nm wolfdales...duh...but the point about the DDR2 in question still is a valid point
some people) ...Sorry my mistake I read 45 chip not chipset...thought it was reference to the 45nm wolfdales...duh...but the point about the DDR2 in question still is a valid point
To be perfectly honest Rast I've not used a 775 board that tops the IP35 Pro yet. This does come rather close though, and is available in pretty much any flavour you want (P45/X48, DDR2/DDR3). And all at a reasonable price.
I could comapre the two with a E7200 if you wanted to see some results based newerish chip. But said E7200 is a terrible overclocker really.
One thing u can't mock is the price.
And the fact that DFI aren't out of business
Looks lush
Looks lush
have the same board and ive no trouble getting my q6600 too 4ghz, the real selling point is the looks lolz, looks top dog anyways great review keep em up
![]() Looks lush ![]() |
Again tho, historically with tech, it's not about what's the best, it's about cash.
I'm pleased to find this motherboard, Would seem to have everything in place for me until I get to go with a Core I7 with whatever chipset's out in Mid 2010.
I have (at the moment), a broken Asus P5K Pro (fails in Raid 0 , AHCI and even IDE compatability mode's in SATA with three makes of HDD's - Maxtor/ Seagate 500gb 3rd gen drives and WD Raptor 74GB's).
I don't want a repeat of these issue's, and am avoiding any board with the Intel ICH9R southbridge as a result, and sincerely hope that it's fixed in the ICH10R?
Asus Tech support suck's basically, and they don't acknowlege the problem at all, despite loads of threads complaining about this problem, also, I managed to recently break a SATA port off of my P5K Pro (they are the straight mounted type rather than the 90 deg. type of this DFI board), and very breakable, just by pulling it off, although lucky 4 me, it didn't short out the connector, and i gingerly replaced it back as a temporary measure (Ironically, I was removing my SATA devices to replace with a Silicon Image PCI-Express SATA controller card, which didn't totally fiix my issue's because there is apparently a problem with PCI-Express timing with the board, that throws SATA into dissarray).
Look forward to running my Q6600 at 3.6 ghz (with my 120 extreme cpu cooler and 120mm fan).
Happy 2009 - Baron210.
(PS - I have a 8800 GTX Nvidia, and a 7600GT Nvid I would like to run in both PCI E Slot's to enable three monitors to be run, anyone know if this'll work, or would the 7600 hold back the performance of the 8800 ???).
Not talking SLI (I know its purely for ATI X Fire), just three outputs - must require some custom software too i'd imagine?
The review failed to mention the advanced BIOS mode on this DFI board which is hidden by default, you need to hit the F9 key to see all the BIOS options available so I'm not suprised at the poor overclocking results in the review. I agree with the previous post by windwithme who's also tested this board, overall it's an excellent motherboard for overclocking.
Yup, the X58 boards are the same. F9 opens up a new menu but that said, the options in there are not exactly all that and are not likely to suddenly boost overclocking by any huge margin. They are more for stabilising and fine tuning imo.
The review was based on the experience i had with the board with the limited time we have to get reviews out. During that time the extra options never made them selves apparent.
I'd hope that the board received a good enough review for anyone to shortlist it and I wouldn't hesitate to recommend it even before I knew about the extra settings (which were used a fair while after the review went like to get 5ghz out a very, very stubborn chip). So really they just make a great board even better!
http://www.overclock3d.net/gfx/artic...000515304s.jpg
