DFI Lanparty DK P45-T2RS Plus
Packaging & Contents
Published: 19th December 2008 | Source: DFI | Price: £114.59 |
Packaging
The T2RS came in a rather standard size box, nothing over the top like you see on a lot of high end boards. In sticking with the dark theme, it shows off a holographic black finish which really looks quite flash - the pictures here simply don't do it justice. A large emblem on the front and the branding under it let you know what's inside from the second you look at it, but aside from a few stickers advertising some of the board's features, there isn't much more to the design until you reach the back.
The back the box enlightens us on the board's main features and what it supports component-wise. It's worth noting the three highlighted features on the bottom right. Being the 'Plus' version of the board, it has a few extra little tricks up its sleeve to set it apart from its sibling, the plain T2RS.
Opening the box, we're presented with the accessories as well as a guide sheet in both traditional and simplified Chinese, as well as Japanese. Digging through the box, there is plenty to help you get a machine up and running. The full accessory list is shown below:
* IDE Cable
* Floopy Cable
* SATA Cables (Power & Data)
* Crossfire connector
* Manual
* Quickstart guide
* ABS manual
* Driver CD
* Driver Floopy
* Floopy Cable
* Manual
* Quickstart guide
* ABS manual
* Driver CD
* Driver Floopy
Under the accessories, we find a protective card layer keeping the motherboard out of harm's way, and obviously below that is the board itself wrapped up in an anti-static bag. Overall the packaging and accessories you get with the T2RS Plus are pretty standard.
The Board
Taking a look over the DK P45 for the first time, I can say that, at least in my opinion, it looks fantastic. The orange and black theme gives it a slightly sinister aura about it, and nothing on the board sticks out like a sore thumb. The back of the board shows us little out of the ordinary. It's noteworthy to see that the northbridge heatsink is bolted on rather than using the traditional push pins.
Starting the tour of the board where it counts the most, the socket area is fairly clutter free. The 4 phase power delivery system is the first concern about the board. With overclockers demanding cleaner, more stable voltages to the CPU, it was a bit of a worry whether the system could keep up with the likes of a Quad Core. For the sub-zero users about, it would be no harder to insulate than any other socket area that uses analogue PWM solutions.
Moving down to the area sporting the DIMM slots, 24 pin power and IDE connectors, there isn't really any clutter here either. A single phase supplies the RAM with the necessary power. The IDE & 24 pin ATX connectors are in pretty much the ideal place. It's noteworthy that DFI has seen fit to move the floppy connector however. This is probably a smart move, as no one really uses them anymore, but the RAID drivers are supplied on a diskette and therefore one may be needed.
Underneath the DIMM slots, we find the ICH10R southbridge that's covered by a small, black aluminium sink. To the immediate right of that are the eight 90° SATA connectors controlled by both the southbridge and JMicron controller. I for one am glad no straight connectors were used, as they have too much of a tendency to pull right off the board when disconnecting cables. Beneath the southbridge chip is the LCD post code display along with the EZ switches and a built-in speaker. Once again, these are all welcome additions and I'm happy to see them on a mid-range board. It means that this board is geared up not only for 24/7 use, but for a testing environment as well. Also in this section, we see two fan headers along with the internal USB and front port I/O headers.
Next on the tour of the board we come to the PCI slot area. Being an ATX board, it makes use of six of the seven possible expansion slots; assumingly the components surrounding the northbridge got in the way of a seventh. But no fear, the board still comes with 2 of the following: PCI-E x1, PCI-E x16 and standard PCI - plenty of room for all but the most card loving among us. We also find our floppy connector located under the slots. As I stated earlier, it's not a massive deal as no-one uses them anymore really, but if you need the raid drivers it could be a hassle if your FDD cable is too short.
Finally we come to the I/O backplate. It's not the busiest of places, but it has everything that I for one would need. The Clear CMOS EZ jumper is a nice touch, but a switch would have been a bit nicer for the back plate. Six 3.5mm jacks and both SPDIF connectors should provide all the audio-out options you could ask of a mid-range board. The lack of Firewire might concern some, but it's another standard that is just not that widely used.
The cooling on the board is a point that interested me. There have been some very elaborate solutions about recently (see the Foxconn Blackops and Gigabyte P45 Extreme reviews) and the DFI has nothing but a simple heatsink connected to the two PWM sinks by a single heat pipe. The board's cooling certainly looks good, with the black and chrome working well together. I was happy to see that DFI weren't trying to pass it off as copper. Having worked with P45 boards before, the fact that the heatsink was no monster didn't raise a concern as the northbridge isn't the hottest of chips. As for the southbridge, it probably doesn't even need a heatsink, but DFI added one on anyways.
Moving on we take a look around the board's BIOS...
I don't think i've seen a DFI board look so good since the 939 days...
All I get from this tbh is there is absolutely no point in getting it if u have an IP35 Pro. Which in all honesty, including the other 2 mobos, is an absolute disgrace imo.
It also has ALC885 sound.. which is pretty old afaik.
I will say tho, for fear of sounding like a scratched record, I feel these 4 series Intel boards would probably perform better with newer cpus.
Good review, being truthful I`d overlook this unless I see it doing well with newer cpus.
bah humbug to you rast
...I see what your saying...if it had been released 18 months ago it may have warranted more attention...still a decent performing board for the money though...I wouldn't build a current system round it but if your in the field for a replacement then its worth a look...although I think DFI may have been better looking at 1377 rather then sticking to an already tried (and tried(and tried)) formula....
...I see what your saying...if it had been released 18 months ago it may have warranted more attention...still a decent performing board for the money though...I wouldn't build a current system round it but if your in the field for a replacement then its worth a look...although I think DFI may have been better looking at 1377 rather then sticking to an already tried (and tried(and tried)) formula....To be really honest, it`s plain to me that the mobo is less use than the IP35 Pro. I have to wonder how it would cope against the IP35 Pro XE.
So, rather than 18 months, it`d be that time PLUS before the Intel 35 chipset was released.
I seriously don`t see the point in this board. For sure it`s a 35 mobo with a dropped in 45 chipset - purely on availablity I`d imagine.
But does this really signal that the 45 chipset is that much of an insignificance over the 35 ? It does have the advantage of being more ddr3 orientated - so in that sense, why is there not a full bank of ddr3 dimms ? The mere presence of ddr2 dimms means that (from what I read on enthusiast sections) a 45 chipset needs to be crippled to use ddr2. How much I don`t know.
hmmmm....I can see why they say crippled....but I suppose its down to the DDR2 in question...(and believe me Ive sold E8400's to people using a 4core dual sata which only takes up to DDR667 and only one channel max 2gb
some people) ...
Sorry my mistake I read 45 chip not chipset...thought it was reference to the 45nm wolfdales...duh...but the point about the DDR2 in question still is a valid point
some people) ...Sorry my mistake I read 45 chip not chipset...thought it was reference to the 45nm wolfdales...duh...but the point about the DDR2 in question still is a valid point
To be perfectly honest Rast I've not used a 775 board that tops the IP35 Pro yet. This does come rather close though, and is available in pretty much any flavour you want (P45/X48, DDR2/DDR3). And all at a reasonable price.
I could comapre the two with a E7200 if you wanted to see some results based newerish chip. But said E7200 is a terrible overclocker really.
One thing u can't mock is the price.
And the fact that DFI aren't out of business
Looks lush
Looks lush
have the same board and ive no trouble getting my q6600 too 4ghz, the real selling point is the looks lolz, looks top dog anyways great review keep em up
![]() Looks lush ![]() |
Again tho, historically with tech, it's not about what's the best, it's about cash.
I'm pleased to find this motherboard, Would seem to have everything in place for me until I get to go with a Core I7 with whatever chipset's out in Mid 2010.
I have (at the moment), a broken Asus P5K Pro (fails in Raid 0 , AHCI and even IDE compatability mode's in SATA with three makes of HDD's - Maxtor/ Seagate 500gb 3rd gen drives and WD Raptor 74GB's).
I don't want a repeat of these issue's, and am avoiding any board with the Intel ICH9R southbridge as a result, and sincerely hope that it's fixed in the ICH10R?
Asus Tech support suck's basically, and they don't acknowlege the problem at all, despite loads of threads complaining about this problem, also, I managed to recently break a SATA port off of my P5K Pro (they are the straight mounted type rather than the 90 deg. type of this DFI board), and very breakable, just by pulling it off, although lucky 4 me, it didn't short out the connector, and i gingerly replaced it back as a temporary measure (Ironically, I was removing my SATA devices to replace with a Silicon Image PCI-Express SATA controller card, which didn't totally fiix my issue's because there is apparently a problem with PCI-Express timing with the board, that throws SATA into dissarray).
Look forward to running my Q6600 at 3.6 ghz (with my 120 extreme cpu cooler and 120mm fan).
Happy 2009 - Baron210.
(PS - I have a 8800 GTX Nvidia, and a 7600GT Nvid I would like to run in both PCI E Slot's to enable three monitors to be run, anyone know if this'll work, or would the 7600 hold back the performance of the 8800 ???).
Not talking SLI (I know its purely for ATI X Fire), just three outputs - must require some custom software too i'd imagine?
The review failed to mention the advanced BIOS mode on this DFI board which is hidden by default, you need to hit the F9 key to see all the BIOS options available so I'm not suprised at the poor overclocking results in the review. I agree with the previous post by windwithme who's also tested this board, overall it's an excellent motherboard for overclocking.
Yup, the X58 boards are the same. F9 opens up a new menu but that said, the options in there are not exactly all that and are not likely to suddenly boost overclocking by any huge margin. They are more for stabilising and fine tuning imo.
The review was based on the experience i had with the board with the limited time we have to get reviews out. During that time the extra options never made them selves apparent.
I'd hope that the board received a good enough review for anyone to shortlist it and I wouldn't hesitate to recommend it even before I knew about the extra settings (which were used a fair while after the review went like to get 5ghz out a very, very stubborn chip). So really they just make a great board even better!
http://www.overclock3d.net/gfx/artic...000515304s.jpg
