Asus Striker II Formula 780i Socket 775 Motherboard
Introduction & Specifications
Published: 8th January 2008 | Source: Asus | Price: £220 |
The Republic of Gamers consists only the best of the best. We offer the best hardware engineering, the fastest performance, the most innovating ideas, and we welcome the best gamers to join in. In the Republic of Gamers, mercy rules are only for the weak, and bragging rights means everything. We believe in making statements and we excel in competitions. If your character matches our trait, then join the elite club, make your presence felt, in the Republic of Gamers.
- Intel® Core™2 Quad / Core™2 Extreme / Core™2 Duo / Pentium® Extreme / Pentium® D / Pentium® 4 Processors
- Supports Intel® next generation 45nm Multi-core CPU
- NVIDIA nForce® 780i SLI chipset
- CPU Level Up
- Pin-Fin Thermal Module
- SupremeFX II 8-CH Audio
- Voltiminder LED
- LCD Poster
- Extreme Tweaker
- ASUS EPU (Energy Processing Unit)
CPU | Intel Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® Extreme/Pentium® D/Pentium® 4 Processors Compatible with Intel® 05B/05A/06 processors Support Intel® next generation 45nm CPU * Refer to www.asus.com for Intel CPU support list |
Chipset | NVIDIA nForce 780i SLI |
Front Side Bus | 1333/1066/800 MHz |
Memory | 4 x DIMM, Max. 8 GB, DDR2 1066/800/667 Non-ECC,Un-buffered Memory Dual Channel memory architecture *Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lidts). |
Expansion Slots | 2 x PCIe 2.0 x16 , support NVIDIA® SLI™ technology, at full x16, x16 speed(blue) 1 x PCIe x16 , at x16 speed(middle) 2 x PCIe x1 ( the PCIEx1_1 (black) is compatible with audio slot) 2 x PCI 2.2 |
Scalable Link Interface (SLI™) | Support three identical NVIDIA SLI-Ready graphics cards (triple at x16 mode) |
Storage | Southbridge 1 xUltraDMA 133/100/66/33 6 xSATA 3 Gb/s ports NVIDIA MediaShield™ RAID Support RAID 0,1,0+1,5,JBOD span cross Serial ATA drives |
LAN | Dual Gigabit LAN, both featuring AI NET2 Support Teaming Technology |
Audio | SupremeFX II Audio Card ADI 1988B 8 -Channel High Definition Audio CODEC Coaxial / Optical S/PDIF out ports at back I/O ASUS Noise Filter |
IEEE 1394 | 2 x 1394a ports (1 port at back I/O, 1 port onboard) |
USB | 10 USB 2.0 ports (4 ports at mid-board, 6 ports at back panel) |
Overclocking Features | Extreme Tweaker Loadline Calibration 2-Phase DDR 2 Intelligent overclocking tools - CPU Level Up - AI Gear 3 - AI Overclocking (intelligent CPU frequency tuner) - ASUS AI Booster Utility - ASUS O.C. Profile: overclocking configuration-sharing tool Overclocking Protection - COP EX (Component Overheat Protection - EX) - Voltiminder LED - ASUS C.P.R.(CPU Parameter Recall) |
Special Features | ASUS MyLogo 3 ASUS EZ Flash 2 ASUS CrashFree BIOS 2 ASUS Q-Connector ASUS Q-Fan 2 LCD Poster Onboard Switches: Power / Reset / Cls CMOS (at rear) ASUS EPU (Energy Processing Unit) BIOS Wallpaper |
Back Panel I/O Ports | 1 x PS/2 Keyboard 1 x IEEE 1394a 2 x LAN(RJ45) port 6 x USB 2.0/1.1 1 x Clr CMOS switch 1 x Optical + 1 x Coaxial S/PDIF Output |
Internal I/O Connectors | 3 x USB connectors support additional 6 USB 2.0 ports 1 x Floppy disk drive connector 1 x IDE connector 6 x SATA connectors 1 x IEEE 1394a connector 1 x CPU Fan connector 3 x Chassis Fan connector 1 x Power Fan connector 3 x Optional Fan connector 1 x S/PDIF Out connector 1 x8-pin ATX 12V Power connector 24 -pin ATX Power connector 1 x En/Dis-able Clr CMOS connector 3 x thermal sensor connectors Chassis Intrusion connector System Panel Connector |
BIOS | 8 Mb Flash ROM DMI 2.0 AMI BIOS PnP WfM 2.0 SM BIOS 2.4 ACPI 2.0a Multi-language BIOS |
Manageability | WOL by PME,WOR by PME,Chasis Intrusion, PXE |
Accessories | User's manual Cable Ties ASUS Optional Fan I/O Shield LCD Poster ASUS Optional Fan SupremeFX II Audio Card 3 in 1 ASUS Q-Connector Kit UltraDMA 133/100/66 cable Floppy disk drive cable 3-way SLI bridge ASUS SLI bridge SATA cables SATA power cables 2-port USB2.0 + IEEE 1394a module |
Support Disc | The hottest 3D Game: Company of Heroes: Opposing Fronts Support DVD: - Drivers and applications ASUS PC Probe II ASUS Update ASUS AI Suite Futuremark ® 3DMark® 06 Advanced Edition Kaspersky® Anti-Virus |
Form Factor | ATX Form Factor 12 inch x 9.6 inch ( 30.5 cm x 24.5 cm ) |
Shame about the OC results...no shock tbh tho.
I am interested in overclocking software other than what comes with the mobo to overclock vid card. I've read that you can do 4ghz on the 8400 easy with air cooling since Im running water cooling mabe I could push it even more let me know what you think thanks.
For the graphics card I would suggest:
Rivatuner
and
ATI Tool
For the cpu, no overclock is guaranteed so you just have to try it and see. From what I've seen, people are getting 4ghz on that chip, as you've got a 9 times multiplier it seems pretty obtainable.
Hope thats some help.
Cheers!
Anyway, just my two cents.
Let me know if anyones had the same problems.
should of waited for the 790I oh well its only money.
thanks
Please dont by this board its crap!!! :cussing::cussing:you'll be lucky if it works wait for the 790i to come out this summer sound like a big improvment.
Bad luck on your run with the motherboard mate, that would be frustrating....wait for the 790i to come out this summer sound like a big improvment.
I just pity the people who bought the 780i or 790i (when it comes) to have it made somewhat obsolete by Intel's next offering for Nehalem (on-die memory controller). I think the 790i will only be offering a slight increase in speed over the 780i and the emergence of DDR3 support which is nothing revolutionary. I may be wrong however.
I think a 780i motherboard, a 45nm proc, some fast DDR2 1066Mhz RAM or faster and a couple of decent gfx cards (if you have to have SLI); your system will hang right in there with the 790i systems of the near future.
I had assembled another MSI X58 Pro for my chiropractor pal for his office barely a week earlier and he had complained last tuesday that it seemed even slower than the 4 year old machine I replaced... so I went over there yesterday and did a reboot into the bios hardware monitor and it displayed a 76 deg C temp on the northbridge after 15 minutes idling on the bios page. I am sure it is higher than that when it is processing a digital xray ... answering a fax, communicating with the patient files on the server, and printing a report all at the same time. I am surprisd it is not fried yet too. tomorrow I am going toput artic silver under the stock chipset sinks until the active onesshow up in the mail about wed I hope.
when I took the N Bridge cooler off of the fried one here at my house it had zero paste betwen the cooler and the chip, as it was all squished outside the periphery of the flip chip core, and the paste was so dried and hard that when I chiseled it off with a razor knife it made powder...
MSI gtold me there is no known problems with their heat sinks installs but when I searched I found many pages explaining the exact same issue with MIS X58 boards and sveral with pics. I also took pics and will be putting the whole story on my youtube page in a few days.
one thing I hoped toget fromyou chillin jim was a url to any of the reports youfound describing the high N Bridge failure rates ?? if I show enough of this to my chiropractor pal I might get to do the systems for his other machines still
regards... Tom in dallas
Thanks again
