Asus Striker II Extreme 790i DDR3 Motherboard
Introduction & Specifications
Search Reviews
Having only reviewed the Asus Striker II Formula board a couple of months ago, the prospect of reviewing the same board yet again - just with DDR3 slots initially didn't spark much enthusiasm amongst the team here at Overclock3D. After all, the 780i chipset used on the "Formula" was really nothing more than aAsus Striker II Extreme re-hash of the ageing 680i chipset with a PCI Express 2.0 support stapled to it. Issues such as poor overclocking with Quad-core chips and an insanely hot northbridge still hadn't been resolved and overall we left the review feeling a little short changed. However, in much the same way as the recently reviewed Asus P5E3 Premium got a spangly new X48 chipset (much to the envy of it's elder P5E3 Deluxe brother), the Striker II Extreme has also undergone a chipset upgrade, and is now kitted out with the greatly anticipated 790i SLI Ultra.
While the difference in model numbers seem to imply that there was more of a jump in technology between the 680i and the 780i, this couldn't be further from the truth. Comprising of a C73 Northbridge and MCP55 Southbridge, the 790i SLI Ultra provides full support for DDR3, the latest Intel 45nm CPU's with 1600mhz FSB and PCI Express 2.0 on-chip. The "Ultra" suffix in the name also denotes support for "SLI" memory modules at speeds of DDR3-1600, DDR3-1800 and DDR3-2000. PR peeps will also be quick to tell you that the 790i produces a lot less heat than than its predecessors and should be able to give Intel's X38 and X48 chipsets a run for their money where overclocking is concerned.
Unfortunately the Asus website didn't have any information available for the Striker II Extreme board at the time of review, so for the moment we've bodged together our own unofficial specs list compiled from various sources around the web:
CPU
LGA775 socket for Intel Core 2 Quad / Core 2 Extreme / Core 2 Duo / Pentium Extreme / Pentium D / Pentium 4 processors
Supports Intel next-generation 45nm multi-core CPU's
Compatible with Intel 06/05B/05A processors
Chipset
Striker II Extreme: NVIDIA nForce 790i Ultra SLI
Striker II NSE: NVIDIA nForce 790i SLI
System Bus
Dual-channel memory architecture supports NVIDIA SLI ready memory technology
- 4x 240-pin DIMM sockets support unbuffered non-ECC DDR3 2000 (O.C)/1800(O.C)/1600(O.C)/1333/1066/800 memory modules (Striker II Extreme)
- 4x 240-pin DIMM sockets support unbuffered non-ECC DDR3 1600(O.C)/1333/1066/800 memory modules (Striker II NSE)
- Supports up to 8gb system memory.
Expansion Slots
2x PCIe 2.0 x16 slots (support NVIDIA SLI technology: blue @ x16, x16 speed)
1x PCIe x16 slot (white @ x16 speed)
2x PCIe x1 slots (PCIEX1_1 (black) is compatible with the audio slot)
2x PCI 2.2 slots
Scalable Link Interface
Supports NVIDIA 3-way SLI graphics cards (triple at x16 mode)
Storage
Southbridge supports:
- 1x UltraDMA 133/100/66/33
- 6x SATA 3.0 Gb/s
- NVIDIA MediaShield RAID supports RAID 0, 1, 0+1, 5 and JBOD configuration across SATA drives
JMIcron JMB363 SATA controller
- 2x External SATA 3.0 Gb/s port
LAN
Dual Gigabit LAN, both featuring AI NET 2
Supports Teaming Technology
High Definition Audio
SupremeFX II Audio Card
- ADI 1988B 8-channel High Definition Audio CODEC
- Noise Filter
Coaxial / Optical SPDIF Out ports at back I/O
IEEE 1394
2x IEEE 1394a ports
USB
10x USB 2.0 ports (4 ports at midboard, 6 ports at back panel)
ROG Exclusive Overclocking Features
Extreme Tweaker
2-Phase DDR3
Loadline Calibration
Intelligent overclocking tools:
- CPU Level Up
- ASUS EPU
- AI Gear 3
- AI Overclocking
- AI Booster Utility
- OC Profile
Overclocking protection:
- COP EX (Component Overheat Protection)
- Voltminder LED
- Frequency LED
- Asus C.P.R
ROG Special Features
Fusion Block System
LCD Poster
EL I/O
Onboard Switches: Power, Reset, Clr CMOS
Asus Q-Connector
Asus Q-Fan Plus
Asus EX Flash 2
Asus CrashFree BIOS 2
ROG BIOS Wallpaper
Asus MyLogo 3
Being a motherboard from Asus' Republic of Gamers line-up, the Striker II Extreme is packed with more features than you can shake a very large stick (of RAM?) at. While we'll undoubtedly cover most of these features as we take a closer look at the board over the next few pages, let's have a quick look at some of the features that often get overlooked:
Asus EPUThe ASUS EPU is an on-board, hardware-based power saving IC controller that digitally monitors and fine tunes your CPU's power supply in real-time, providing improved VRM efficiency under light and heavy loads. According to Asus, this can provide up to 58.6% CPU power savings - but only when Intel's on-chip energy saving "C1E" technology is disabled.
Loadline CalibrationLoadline Calibration is a feature recently introduced on Asus motherboards which helps prevent CPU voltage droop when the system is under heavy load. While many enthusiasts often obsess over vdroop and hold it solely responsible for unstable overclocks, the truth of the matter is that vdroop was very much part of Intel processor specifications and can play an important role in the longevity of your CPU and Motherboard.
Voltminder LEDThe Voltminder LED provides enthusiasts with a quick and easy way to monitor how much voltage they are putting through components such as the CPU, Northbridge and Memory. Simply look at the area surrounding the component you are interested in, and you will find a series of LED's that change colour between Green, Orange and Red depending on the amount of voltage applied.
Now that we've got most of the specs out of the way, it's time to delve into what Asus have thrown in the box...
«Prev 1 2 3 4 5 6 7 8 9 10 11 Next»
02-04-2008, 16:37:36
breadloaf
what sort of drivers did you take from 780i?
That does seem like the board fault, although did you up volts at all or anything?
Tried many settings and voltages etc .....
Thing is the machine runs perfectly stable at stock - I think I have managed to get the system working OK at 3.3 ghz now.
Not taken any drivers for the 780i board - full fresh install of Vista (stock speed for that) then used the CD that came with the motherboard :)
I am using a Targan 900W PSU too so I do not think it's a PSU issue !!
04-04-2008, 13:24:25
man_in_africa
Why does the back of the box say "780i chipset" ?
04-04-2008, 13:28:15
Jim
Well spotted. Either a typo by Asus on a pre-production box, or a c0ckup by me using an image from the Formula box.
04-04-2008, 16:11:59
breadloaf
Back of the Box I have is different and says 790i Ultra Sli :)
04-04-2008, 16:23:25
Jim
I might be a bit late to the table with this lads, but this thread has just reminded me about the BIOS I promised you all.
04-04-2008, 18:47:11
breadloaf
Awesome - testing the machnie now on 3.66 and it's been stable so far - I have never got this high before :)
Asus probe keeps giving warnings though - saying that the CPU PPL voltage has dropped- is this normal ?
Also my CPU temp is around 59 - 63 degree fully loaded - is this normal ? I have a liquid cooled chipset and CPU :)
Motherboard temp is 36 degrees which is miles better than the old Striker II
04-04-2008, 18:49:32
Jim
Great stuff. I think there may even be a newer version than this one - I'll ask Asus.
04-04-2008, 19:05:10
breadloaf
what do you think about the temperature though and the CPU PPL power droop ?
I think I might have spoken too soon as the machine rebooted shortly after my last post :(
Still I think with a little bit of tweaking I can sort the problems out I am concerned about probe showing the voltage droping as it's also happening on my memory now !!!
What do you think ?
07-04-2008, 09:49:38
Jim
Latest BIOS attached :)
29-04-2008, 09:56:31
ThaClown
mmm pricey but very very nice indeed..
