Asus ROG Crosshair IV Formula
Published: 27th April 2010 | Source: Asus | Price: ~£169 |
It's Here...
It's been a busy week in the Overclock3D labs... While I'm sure many of you will have relished the warmth and sunshine of the weekend and perhaps a select few of you may have even participated in Sunday's London Marathon too, unfortunately the same cannot be said for our reviewing squad. They have been trapped indoors running a different sort of marathon; an extensive regime of component photography, tweaking and benchmarking. Yes, it's been a tiring week, but it has most certainly paid off as today we're proud to present a fully fledged review of the Asus ROG Crosshair IV Formula 890FX motherboard.
Following on from our previously published preview of the motherboard we can safely say that Asus, ROG and the board itself needs no introduction. For those who need a brief reminder of the Crosshair IV Formula's fundamental specifications they are as follows.
| Form Factor | ATX, 12" x 9.6" (30.5cm x 24.5cm) |
| Processor Support | AMD Socket AM3 Sempron 100/Athlon II X2/X3/X4 and Phenom II X2/X3/X4 Processors |
| Chipset | AMD 890FX / SB850 |
| Memory | 4 x DIMM, Max. 16 GB 2000(OC)/1600/1333/1066 Non-ECC,Un-buffered Memory Dual Channel memory architecture |
| Expansion Slots | 4 x PCIe 2.0 x16 (Operates in Dual 16x/16x, Triple 16x/8x/8x or Quad 8x/8x/8x/8x) 2 x PCI |
| Multi-GPU Support | ATi CrossfireX Supported |
| Storage | AMD SB850 Southbridge JMicron 363 SATA Controller. |
| LAN | One Marvell 8059 PCI Express LAN 10/100/1000 |
| Audio | Creative SupremeFX X-Fi 7.1 Audio |
| USB | AMD SB850 Southbridge - 12 x USB 2.0 ports (7 x Rear, 5 x Internal) NEC USB 3.0 Controller - 2 x rear USB 3.0 ports |
| Firewire | 2 x 1394a ports (1x Rear I/O, 1x Onboard) |
| Back Panel I/O | 1 x PS/2 Keyboard 1 x e-SATA 1 x LAN 6 x USB2.0/1.1 ports 1 x IEEE1394a port 1 x Clear CMOS switch |
The Crosshair IV Formula looks brilliant on paper. However, it has much to achieve in order to surpass it's predecessor. On that note I believe it's time to cut the red tape and get testing!
I've never been one for motherboard looks but I must admit I did get suckered in, was the first thing that caught my eye about it, just waiting for my 1090T to arrive - can't wait to get it hooked up.
The worse review I've seen so far out of everyones is bit-tech, lack of depth, lack of benchmarks, lack of detail etc.
Enjoyed the review, can't find fault with it to be honest, not just saying that either if I thought it was crap I would say so.
not yet anyways:-P
the reason why i want em to test the 8GB set is that i have one myself, but i have never had the chance to test it cause i dont have the motherboard for it:D;)
not yet anyways:-P
What I said dude is we have 1 review up for the Hex, there will be more to come. Patience young padawan.
