Asus P5E3 Premium X48 DDR3 Motherboard
3D Gaming Results
Published: 8th March 2008 | Source: Asus | Price: £TBA |
Quake 4 is a game built on the Doom 3 engine. Benchmarking was performed using Quake4Bench and a custom timedemo recording along with 0xAA, 0xAF settings at a resolution of 1024x768. The benchmark was set to run a total of 5 times, with Quake4Bench automatically calculating an average result at the end of the run.
F.E.A.R. is a game based on the Lithtech Jupiter EX engine. It has volumetric lighting, soft shadows, parallax mapping and particle effects. Included in the game is a benchmark facility that taxes the entire PC system. This benchmark was run a total of 5 times, with the highest and lowest results being excluded and an average being calculated on the remaining 3 results.
Bioshock is a recent FPS shooter by 2K games. Based on the UT3 engine it has a large amount of advanced DirectX techniques including excellent water rendering and superb lighting and smoke techniques. All results were recorded using F.R.A.P.S with a total of 5 identical runs through the same area of the game. The highest and lowest results were then removed, with an average being calculated from the remaining 3 results.
Result Observations
The P5E3 Premium manages to keep up with the rest of boards in the test, indeed showing that it is in no way crippled when compared to any of Asus' Replublic of Gamers boards or indeed any of the Nvidia chipset based boards (Striker II / XFX 780i).
Wow nice overclocking, i read somewhere that x48 is just a die shrink of x38, is that true?
yeah, thats pretty good as my x38 gets real toasty, i guess thats what aids overclocking the fact it runs cooler, as 680i boards were awful with stock but under water really rocked most of the time..
Nice review btw
i look forward to a proper read later
Nice review btw
i look forward to a proper read laterlooks nice
performs well
asus have been listening to people and implimenting some good ideas into their motherboards it seems...
performs well
Nice review btw i look forward to a proper read later |
Apparently the 790i is a lot cooler than the 680/708i (according to the marketing dudes), but I'll be able to say for sure in a week or so
Are OC3D getting one in? theyve been on show on cebit, which i spotted one in a hexus article, it looks like a heatsink about the same size as that on 780i, but hopefully your right and it is a lot cooler.
It IS better than the 780i tho....
Well this is what nvidia have been working on am i right? then they realised ppl still wanted ddr2 so mashed up a 680i with the pci-e 2 chip...
w00t! looking forward to that
i'm guessing you've got the review done, and will post it at 00:01 on the 18'th?
I am sorely tempted to get one of these. Either the P5E3 or the DFI x48lt...hmmmm.
Great review once again Jim.
mm. and not that your subzero, but it has a very good coldbug (as in you can get to -100 i believe before it wont post..)
It's been booted at -140 degrees C....
For all you LN2 Junkies out there!
http://www.overclock3d.net/gfx/artic...120101900s.jpg
Asus P5E3 Premium review
