Asus P5E3 Deluxe WiFi-AP @n Socket 775 Motherboard
Introduction and Specification
Search Reviews
Asus are one of the largest motherboard manufacturers out there, as well as being one of the most respected. With a long history of making top-end enthusiast-based boards as well as a huge reputation in the OEM business, Asus motherboards have graced many different types of PC's over the years.
After introducting an X38-based motherboard in the Maximus Formula we're now taking a look at another X38 based board, this time with DDR3 support.
The P5E3 Deluxe is an Intel® X38 chipset-based motherboard that combines powerful performance with great energy efficiency; and supports DDR3 1800MHz dual-channel memory architecture and Dual PCI Express 2.0 x16 lanes for extreme graphics performance. It also comes with the world’s first ASUS EPU (Energy Processing Unit), allowing the CPU power supply to be digitally monitored and fine-tuned with improved VRM efficiency in heavy or light loadings – attaining the best possible power efficiency and energy savings to help save the environment.
AI Lifestyle Series motherboards bring lifestyle and personal computing together. They provide you better system performance to enjoy graphic-intensive games and applications. The cutting-edge audio feature dramatically enhances the quality of voice signal. Thoughtful design allows you to set up your system easily. To create a peaceful environment, several new and improved innovations are included to reduce noise and temperature. Don´t change your way of life for a computer. Instead let the ASUS Lifestyle Series improve the quality of your life.
One of the Asus Ai Lifestyle branded motherboards: the P5E3 comes with dual WiFi and a whole host of power saving features. The P5E3 looks to be a feature-stacked board that offers everything for the professional home user in mind.
Asus have followed up the Maximus by putting in the EPU (Energy Processing Unit) to bring digitally efficient savings when delivering the power to the CPU.
Let's take a look at the hard facts, and of course you can take a look at more of the foibles of the board on Asus's website.
Specification
CPU
LGA775 socket for Intel® Core™2 Quad / Core™2 Extreme / Core™2 Duo / Pentium® Extreme / Pentium® D / Pentium® 4 Processors
Compatible with Intel® 05B/05A/06 processors
Supports Intel® next generation 45nm Multi-Core CPU
Chipset
Intel® X38 / ICH9R with Intel® Fast Memory Access Technology
Front Side Bus
1600/1333 / 1066 / 800 MHz
Memory
4 x DIMM, max. 8GB, DDR3 1800(O.C.)/1600(O.C.)/1333/1066/800 MHz, non-ECC, un-buffered memory
Dual channel memory architecture
*Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lidts).
Expansion Slots
3 x PCIe x16 (blue @PCIe2.0 x16 mode, black @PCIe x4 or x1 mode) supports CrossFire Technology
2 x PCIe x1
2 x PCI
Storage
Southbridge
- 6 x SATA 3.0 Gb/s ports
- Intel Matrix Storage Technology supports RAID 0, 1, 5 and 10
JMicron® JMB363(JMB368) PATA and SATA controller
- 1 x UltraDMA 133/100/66 for up to 2 PATA devices
- 2 x External SATA 3.0 Gb/s port (SATA On-the-Go)
- Supports SATA RAID 0,1,JBOD
LAN
Dual Gigabit LAN controllers
Marvell88E8056® PCIe Gigabit LAN controller featuring AI NET2
RealtekRTL8110SC® PCI Gigabit LAN controller featuring AI NET2
Audio
ADI® AD1988B 8-channel High Definition Audio CODEC
- Support Jack-Sensing, Enumeration, Multi-streaming
- Coaxial / Optical S/PDIF out ports at back I/O
- AI Audio 2
- ASUS Noise Filter
IEEE 1394
Agere® L-FW3227 1394a controller supports 2 x IEEE 1394a ports (one at midboard; one at back panel)
USB
12 x USB 2.0 ports (6 ports at mid-board, 6ports at back panel)
ASUS AI Lifestyle Features
ASUS Power Saving Solution
- ASUS EPU (Energy Processing Unit)
- ASUS 3rd Generation 8-phase Power Design
- ASUS AI Nap
ASUS AI Lifestyle Features:
- ASUS AI Direct Link
ASUS Quiet Thermal Solution:
- ASUS Fanless Design: Heat-pipe solution
- ASUS Fanless Design: Stack Cool 2
- ASUS Q-Fan 2
- ASUS Optional Fan for Water-cooling or Passive-Cooling only
ASUS Crystal Sound:
- ASUS Noise Filter
ASUS EZ DIY:
- ASUS Q-Shield
- ASUS Q-Connector
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- ASUS AI Slot Detector
Special Features
ASUS MyLogo 3
Multi-language BIOS
Overclocking Features
ASUS AI Booster utility
Precision Tweaker 2:
- vCore: Adjustable CPU voltage at 0.00625V increment
- vDIMM: 64-step DRAM voltage control
- vChipset (N.B.): 33-step DRAM voltage control
- vFSB Termination: 15-step reference voltage control
- vCPU PLL: 64-step CPU PLL voltage control
SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 800MHz at 1MHz increment
- Memory tuning from 800MHz up to 3200MHz
- PCI Express frequency tuning from 100MHz up to150MHz at 1MHz increment
Overclocking Protection:
- ASUS C.P.R.(CPU Parameter Recall)
Back Panel I/O Ports
1 x PS/2 Keyboard
1 x S/PDIF Out (Coaxial + Optical)
2 x External SATA
1 x IEEE1394a
2 x RJ45 port
6 x USB 2.0/1.1
8-channel Audio I/O
Internal I/O Connectors
3 x USB connectors support additional 6 USB ports
1 x Floppy disk drive connector
1 x IDE connector
1 x COM connector
6 x SATA connectors
1 x CPU Fan connector
4 x Chassis Fan connector
1 x Power Fan connector
1 x IEEE1394a connector
Front panel audio connector
1 x S/PDIF Out Header
Chassis Intrusion connector
CD audio in
24-pin ATX Power connector
2 x 4-pin ATX 12V Power connector
System Panel(Q-Connector)
BIOS
16 Mb Flash ROM, AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3
Manageability
WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Accessories
UltraDMA 133/100/66 cable
FDD cable
6 x Serial ATA cables
1 x 2-port Serial ATA power cable
ASUS Q-Shield
User's manual
3 in 1 Q-connector
1 x 2-port USB2.0 / 1-port IEEE1394 module
2 x Optional Fan for Water-Cooling or Passive-Cooling only
Support CD
Drivers
ASUS PC Probe II
ASUS Update
ASUS AI Suite
Anti-virus software (OEM version)
Image-Editing Suite
Form Factor
ATX Form Factor, 12"x 9.6" (30.5cm x 24.4cm)
Even though the P5E3 isn't a Republic of Gamers Board (RoG), there's a whole load of features to get you slavering in your coffee. Now let's get onto the nitty gritty...
10-12-2007, 18:10:29
Kempez
We have a gander at Asus "AI-Lifestyle" board, the P5E3 Deluxe
[IMG]http://www.overclock3d.net/gfx/articles/2007/12/08142735608s.jpg[/IMG]
See what we think
10-12-2007, 19:48:48
ionicle
looks decent enough, but why, in one of the pictures, was there a sticker over two usb ports, and a network port? :S
infact, its in the pic in the first post ^^
is it to protect it or somthing? :S
10-12-2007, 20:03:22
Kempez
Nah just shows you where the USB wake-on goes in, should have taken it off but forgot :p
10-12-2007, 21:08:18
ionicle
:rolleyes::p
10-12-2007, 21:45:42
SBB
Looks nice, shame the overclocking isnt as good as the rest of it :(
10-12-2007, 21:48:39
Kempez
Agreed, although cooling limited me tbh. Still 3.7GHz easily on a Q6600 isn't to be sniffed at. Sometimes I wish we could have a bit more time with the boards to tweak away :)
