ASUS Maximus V Formula ThunderFX Review
Test Setup and Overclocking
Published: 8th August 2012 | Source: ASUS | Price: £268 |
Test Setup
ASUS Z77 Maximus V Formula
Intel Core i7-3770K
8GB G.Skill Trident 2400 @ 10-12-12-31
Sapphire HD7950
Catalyst 12.4
Cougar CM1000 PSU
Corsair F80 SSD
Thermalright Silver Arrow
Windows 7 x64
The Supreme FX lights up the whole left hand side of the motherboard. If you like a red glow this is absolutely the motherboard for you, but you can turn it off in the BIOS.
Overclocking
With such a user-friendly BIOS on hand, and as we've said just now, all the elements are exactly where you'd expect to find them, it makes overclocking a breeze. The Formula isn't quite up there with the Extreme, but we wouldn't expect it to be, still 4.9GHz for most applications, and a 4.8GHz stable 24/7 overclock are right up there and certainly as hard as we'd want to push our i7-3770K on air in daily use.
Thx
Judging on last few reviews of Z77 I think MSI G65 is the best deal and hopefully it will end up in my new build.
Kind regards to everyone btw from a new member
The only reason I'm getting it is to use more tubing XD
I have this board and the barb size is 3/8, which can also be found in the PDF version on the motherboards manual
Cracking board btw
The second in our look at the Maximus V motherboards comes in the form of the Formula ThunderFX.
Continue Reading
