ASUS Maximus V Formula ThunderFX Review
wPrime95 and Unigine
Search Reviews
ASUS Maximus V Formula Review
wPrime95
wPrime continues the trend we saw with our rendering tests. The Maximus V Formula is by no means bad, but it isn't doing anything to stand out from the crowd either.
Unigine 0xAA
Things improve with Unigine as the Maximus V Formula nestles in just behind the Maximus V Extreme as the second best that's been tested with this particular GPU.
08-08-2012, 03:50:54
tinytomlogan
http://www.overclock3d.net/gfx/artic...095225657l.JPG
The second in our look at the Maximus V motherboards comes in the form of the Formula ThunderFX.
Continue Reading
08-08-2012, 05:28:48
Lollipop
I don't really like the barbs and the heatsink design in general.
08-08-2012, 06:54:52
dipzy
same here, the heatsinks have that rubbery look/texture but other than that great board
08-08-2012, 07:10:56
Ciric
Yea, why can't they just make some 1/4 threads, and close it with some plugs with the top in the same material as the heatsinks :/
08-08-2012, 07:12:52
tinytomlogan
Pretty much what I thought too.
08-08-2012, 09:21:03
AverageNinja
I don't think it looks that bad at all. And maybe you could just get the dremel out and cut it off? That would ruin the watercooling possibilities on that heatsink though.
08-08-2012, 11:11:08
spidey81
I've been considering this board for a future IB build. However, of all the reviews I've seen there's been no mention of the barb size on the built in water blocks. I agree that it would have been heaps easier to just have put 1/4" threads in instead of permanent barbs. However, my entire system uses 1/2" barbs with 7/16" tubing. It may technically work if I got a couple of 3/8" barbs/adapters, but it just wouldn't be right. If you get what I mean. I'm assuming since there's been no mention, and from the looks of it, that they are 3/8" barbs. So that will probably be a deal killer.
10-08-2012, 12:03:48
me29011993
I have the same board, but on top of the board against the cooling block and a little bit right of the 2 fan connectors, are 3 pins, do you know what they are for, cause I can't find them in the user guide.
Thx
19-08-2012, 14:54:15
Munio
A very good review with an honest conclusion. Well done Mr Waters.
Judging on last few reviews of Z77 I think MSI G65 is the best deal and hopefully it will end up in my new build.
Kind regards to everyone btw from a new member
19-09-2012, 08:21:41
XtremePhysX
I'm most likely buying this motherboard but with out the thunderbolt thing.
The only reason I'm getting it is to use more tubing XD
16-11-2012, 03:52:28
Stalker_26
Hi All,
I have this board and the barb size is 3/8, which can also be found in the PDF version on the motherboards manual
Cracking board btw
