ASUS Maximus III Extreme 1156 Motherboard
Technical Specifications
Published: 19th February 2010 | Source: ASUS | Price: around £250 |
As befits a ROG motherboard the specifications are very comprehensive with a huge array of options related to the P55 side of things and a lot of additional ASUS ROG specific features.
| CPU | Intel® Socket 1156 Core™ i7 Processor/Core™ i5 Processor/Core™ i3 Processor Supports Intel® Turbo Boost Technology | |
| Chipset | Intel® P55 Express Chipset | |
| Memory | 4xDIMM, Max 16 GB, DDR3 2200(O.C.)/2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Non-ECC,Un-buffered Dual Channel memory architecture * Hyper DIMM support is subject to the physical characteristics of individual CPUs. * Supports Intel® Extreme Memory Profile (XMP) | |
| Expansion Slots | 5 x PCIe 2.0 x16 Supports single at x16, dual at x16, triple at x 16 x16 x8, quad x8, or 5 x8 1 x PCI 2.2 | |
| Storage | Intel® P55 Express Chipset built-in 6 xSATA 3.0 Gb/s ports (Gray) Intel Matrix Storage Technology Support RAID 0,1,5,10 JMicron® 363 controllers: - 1 x SATA 3.0 Gb/s port (Black) - 1 x External SATA 3.0 Gb/s port (SATA On-the-Go) Marvell® PCIe SATA 6Gb/s controller - 2 x SATA 6.0 Gb/s ports (Red) | |
| LAN | Realtek® RTL8112L Gigabit LAN controller | |
| Audio | VIA® VT2020 10-Channel High Definition Audio CODEC - Supports Blu-ray audio layer content protection - Supports 1 Optical S/PDIF out port at back I/O - Supports 1 S/PDIF out header - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking | |
| IEEE 1394 | 2 x 1394a port(s) (1 port onboard, 1 port at back I/O) | |
| USB | NEC® USB 3.0 controller - 2 x USB 3.0/2.0 ports (at back I/O) Intel® P55 Express Chipset - 11 USB 2.0 ports (4 ports at mid-board, 7 ports at back I/O, 1 port at back I/O is also for ROG connect) | |
| Overclocking Features | ROG Connect RC Bluetooth Extreme Engine Digi+ - 8-phase CPU digital VRM power - 3-phase VTT digital VRM power - 3-phase Memory power - ML Cap for CPU ProbeIt iROG Extreme Tweaker BIOS Flashback Loadline Calibration Intelligent overclocking tools: - 8 O.C. Profile Overclocking Protection: - COP EX (Component Overheat Protection - EX) - Voltiminder LED - ASUS C.P.R.(CPU Parameter Recall) | |
| Special Features | CPU Level Up MemOK! Onboard Button: Power / Reset / Clr CMOS (at back IO) ASUS MyLogo3 ASUS Fan Xpert ASUS EZ Flash 2 ASUS CrashFree BIOS 3 ASUS Q-Connector ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED) ASUS Q-Slot ASUS Q-DIMM | |
| Back Panel I/O Ports | 1 x External SATA 1 x IEEE 1394a 1 x LAN(RJ45) port 10 -Channel Audio I/O 1 x Clr CMOS switch 1 x PS/2 Keyboard port (purple) 2 x USB 3.0/2.0 ports 7 x USB 2.0 ports (1 port also for ROG Connect) 1 x ROG Connect On/Off switch S/PDIF Out (Optical) | |
| Internal I/O Connectors | 2 x USB connectors support additional 4 USB 2.0 ports 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional | |
| BIOS | 16 Mb Flash ROM AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a Multi-Language BIOS | |
| Manageability | WOL by PME,WOR by PME,PXE | |
| Accessories | 1 x RC Bluetooth Card 1 x I/O Shield 1 x Optional Fan 1 x ROG Connect Cable 1 x SLI Cable 1 x 3-way SLI Cable 1 x 2-in-1 ASUS Q-Connector Kit 1 x 2-in-1 SATA 6.0Gb/s Cables 3 x 2-in-1 SATA 3.0Gb/s Signal Cables 1 x 2-port USB2.0 + ESATA Module 1 x Thermal Sensor Cables Pack 1 x Cable Ties Pack 1 x ROG Theme Label 1 x 12-in-1 ROG Cable Label 1 x User's Manual Bluetooth Module Accessory Card - Bluetooth V2.0/V2.1+EDR - RC Bluetooth On/Off Switch | |
| Support Disc | ASUS PC Probe II ASUS AI Suite ASUS Update Kaspersky® Anti-Virus Support DVD: - Drivers and Applications Futuremark® 3DMark® Vantage Advanced Edition ASUS TurboV EVO Utility | |
| Form Factor | ATX Form Factor | |
| Size | 12 inch x 9.6 inch (30.5 cm x 24.4 cm) |
That certainly is a comprehensive selection of features and included accessories. But a big table of specifications can seem a little dry, so it's time to take a look at the Maximus III in the flesh.
Looks like a pretty awesome board.
This Maximus III is a mental amount of motherboard. The serious contender for it in X58 terms is the Quad Classified. And if you're trying to say they're the same money....
Originally Posted by name='VonBlade'
Because you're getting LOADS more motherboard for the same price, the 1156s clock much easier than the X58 stuff, dual channel is naturally a lot cheaper and, if hyper-threading isn't important to you, a i5 750 is way cheaper than a 920. Yes the X58 is amazing. But the P55 is much better value.
This Maximus III is a mental amount of motherboard. The serious contender for it in X58 terms is the Quad Classified. And if you're trying to say they're the same money.... |
You bring value into the discussion but anyone buying p55 has a lower budget and will therefore buy the 750. People on higher budgets will more than likely get the x58 based system that will support the 6 core 32nm cpus that will be shortly released.
People that have funds for a tri/quad sli/xfire system will have enough for the classified.
Continue Reading
