ASUS Maximus III Extreme 1156 Motherboard
Search Reviews
Conclusions are often a balancing act in which we try and explain how the bad points outweigh the good, or the good points outweigh the good. We nit pick and just try and balance it all out until we are happy with the score we've given, and you can then make tiny adjustments depends on how you feel about the good or bad points we've raised.
The ASUS Maximus III Extreme makes all of this a non-issue by being brilliant.
The packaging is stunning, exuding both class and sturdiness. The box itself is fantastically laid out and the design is excellent. Internally the motherboard is protected well with more sturdy cardboard, and the accessories box is of the same high quality.
The accessories themselves are all well-made and not an afterthought. The manual is a particular highlight. The included SATA Cables are black, latched and one of the ends is at an angle to ensure easy insertion and routing.
The board. What more can I say. It's feature rich beyond almost anything else we've seen, fantastic build quality, comes complete with a plethora of features that assist everyone from the overclocking neophyte to the people already preparing their LN2.
The ROG Connect features add yet another layer of control, and along with the twin user-selectable BIOS, MemOK and GO features, it should be impossible to ever end up with a situation you need to clear the CMOS in, much less coax the board back into life. Although 4GHz rock-solid stable
Quad and Tri card compatibility, or five cards for the Folders among you, USB3, SATA 6Gb/s, support for incredible speeds and all wrapped up in great package.
Unfortunately this does come and quite a steep price. When X58 motherboards were first released most of us baulked at some of the prices being discussed for even average boards.  Thankfully the P55 based offerings quickly fixed that by definitely being the budget option of the two.
Now I don't know if the P55 marketplace is so hot right now that manufacturers are moving towards it as their product of choice, but early indications are that the Maximus III Extreme will come to the market around the £250 mark. Almost spot on the Rampage II Extreme price.
This doesn't bode well for two reasons. Firstly it makes any thoughts that the whole 1156 option is "more affordable" instantly rubbish. Yes ok this is a premium product, but is it seriously that much better than the competition. After all, if the pricing is right (and with the Formula at 190ish it seems likely) then the only P55 motherboards more expensive are the MSI Big Bang ones, and they are all sorts of weird and wonderful tech.
There is no denying the performance. The packaging is sublime. But the price point is eye-watering. If you must have the absolute best, this is it. If you've got budgetary concerns, there are plenty of other options, including the lesser models of this very board.
Video
For those of you with a video fetish Tom kindly did a box opening video.
Pros
- Stunning performance
- Great looks
- Wonderful packaging
Mediocre
- If that price proves accurate, this will swiftly become a con.
Cons
- None to speak of
    Performance
Thanks to ASUS for giving us todays review sample. Discuss in our forums.
«Prev 1 2 3 4 5 6 7 8 9 10 11 Next»
19-02-2010, 05:16:07
tinytomlogan
Always good to post the first proper full review.... OC3D takes first place yet again! VonBlade has worked all hours to bring you the first review of the Asus Maximus III Extreme.
Continue Reading
19-02-2010, 17:49:54
Jim
the red and black themes still aren't wearing thin on me yet
Looks like a pretty awesome board.
20-02-2010, 08:39:54
pazman4
Looks Sweet. Nice review, thanks
21-02-2010, 16:35:36
cl0ck_ed
Still can't see how anybody could justify buying this when x58 mobo's are about the same price and the 920's are cheaper than 860's.
21-02-2010, 19:33:37
VonBlade
Because you're getting LOADS more motherboard for the same price, the 1156s clock much easier than the X58 stuff, dual channel is naturally a lot cheaper and, if hyper-threading isn't important to you, a i5 750 is way cheaper than a 920. Yes the X58 is amazing. But the P55 is much better value.
This Maximus III is a mental amount of motherboard. The serious contender for it in X58 terms is the Quad Classified. And if you're trying to say they're the same money....
22-02-2010, 14:10:54
cl0ck_ed
I have to disagree 1366 overclocks much better than 1156. You can put dual channel on x58 if that is a concern. Yes i5 750 is good value but p55 i7's are expensive in the UK.
You bring value into the discussion but anyone buying p55 has a lower budget and will therefore buy the 750. People on higher budgets will more than likely get the x58 based system that will support the 6 core 32nm cpus that will be shortly released.
People that have funds for a tri/quad sli/xfire system will have enough for the classified.
