Asus E35M1-M PRO Micro ATX
Multimedia & System Wide Testing
Published: 3rd February 2011 | Source: Asus | Price: £119.99 |
Adobe Flash HD - Youtube.com
Watching Flash based High Definition video is often more tasking on a system than you'd be led to believe. Without Flash Player 10.1 which enables GPU acceleration, many systems would have otherwise ground to a halt. Let's see how our test setup performs here.
Unlike some of our previous Flash HD endeavours, we are pleased to report no issues. Using only the E35M1-M's hardware for this test, it was possible to playback 1080p video with less than 50% usage. The playback itself was fluid and without stutter.
Microsoft HD Video Suite
Microsoft's HD Suite contains a variety of 720p and 1080p video clips. We selected one 1080p Video Clip and gauged performance on the basis of CPU utilisation and fluidity.
Again, the E350 APU accomplishes it's mission without kicking up a fuss. Our FRAPS frame rate counter showed a consistent 60fps reading throughout.
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC.
GPGPU Test
The GPGPU test leverages CUDA and OpenCL to determine the ability of today's stream processor based GPUs for general purpose computing.
While synthetic benchmarks such as these aren't the best representative of actual performance, it is quite likely that the APU's HD 6310 GPU can take on nVidia GeForce GPU's with up to 32 CUDA cores.
PCMark Vantage
PCMark Vantage is Futuremark's flagship "System Wide" benchmark. With a large focus on day to day operations, it's an excellent means of judging the capability of a computer as a whole.
We finish this set of benchmarks with another win for Team AMD in this system wide test.
As the new HD 6310 GPU supports UVD 3.0, this means that DivX decoding is now included (on top of the existing MPEG2/H.264) and also Blu-Ray 3D support. However neither Asus or AMD have clearly stated that the HD 6310 will decode 3D well. I suppose this will become more clear as time goes on however my initial impressions are that a HTPC for higher end functionality such as 3D support or anything else that may command some more CPU horse power is probably better off with a conventional CPU and dedicated GPU.
I hope that helps
Pros: you'll have the coolest running 18W CPU on the block. WooHoo! Bragging rights.
Cons: You'll probably need to work on the mount - I don't see the usual AM3 hardware on that board. And do you figure £150 or more on a full-tower case to accommodate the Noctua is about right for a rig like this? An HAF-X or a Lanboy Air would be quite stylish.
http://www.asus.com/product.aspx?P_ID=9BmKhMwWCwqyl1lz&templete=2
Looks like it includes WiFi plus blue-tooth 3.0. Anyway, just look at the specs on this little monster. The feature set is extremely impressive for a Mini ITX board. I think this would make a sweet little pc that you could mount to the back of a monitor for a clutter and noise free desk. Definitely good for email, web browsing, word, netflix and watching movies.
So as Mul suggested probably wait for a more powerful AMD Fusion APU, and than bolt on a nice HTPC soundcard and PROFITS!
it doubled. so my question is using a discrete vga does indeed improves cpu perfomanse?? so a few more test with winzip and other cpu programs to see if with a discrete vga they will improve. if they improve then it will be interesting :-)
ANyone to comment that when you add the discrete card aand run the test to see how much it will bottleneck did you check the cpu score from 954 to 2020?? it doubled. so my question is using a discrete vga does indeed improves cpu perfomanse?? so a few more test with winzip and other cpu programs to see if with a discrete vga they will improve. if they improve then it will be interesting :-) |
But for a normal CPU, unless you a running nVidia with Physx I doubt it.
Loving these little options myself.
There was an error with this graph; CPU score should read 1954, not 954. This has now been edited, apologies if this has caused any confusion.
Another question would the new form factor have any complications in fitting into a standard ATX case?
Thanks
I am loving that the new technology for HTPC users like myself, as I am looking into this E35M1-M Pro board to build a low power HTPC. The only reason I would take this over the E35M1-M mini ATX board is that I need 2 PCIE slots for my Happauge Win Tv tuner cards, unless someone could tell me a great way of getting dual NTSC signals into one card ? Another question would the new form factor have any complications in fitting into a standard ATX case? Thanks |
http://www.silicondust.com/products/hdhomerun/dvbt/
Continue Reading
