Asus E35M1-M PRO Micro ATX
BIOS & Overclocking
Published: 3rd February 2011 | Source: Asus | Price: £119.99 |
BIOS
Like most of Asus' latest releases, the E35M1-M comes with a graphic EFI BIOS. The intention is to accomodate for both novice and advanced users.
Asus have done this by offering two versions of the BIOS - EZ and Advanced. Above is the simple EZ version, which contains everything a basic end user may ever need to look at. Fancy verifying that a memory upgrade has been acknowledged? Sure, the stats are all on display. Need to change your boot device? Just look for the logo that looks like your boot device and the job is done.
However given that this is a website originally set up for PC Enthusiasts and Overclockers, you will probably find yourself feeling a little patronised by the EZ BIOS. Never fear however as you can switch to Advanced mode in two clicks.
You may (or may not be) surprised to discover that overclocking is supported by this motherboard. We will soon find out how far the E350 APU can go.
A final BIOS feature to showcase is Asus' latest iteration of the EZ Flash utility. While similar to the previous edition, the EFI BIOS combined with mouse functionality makes navigating folders for a new BIOS a total breeze.
Overclocking
So we finally set about overclocking the Fusion E350. We first started off with the Automated (TurboV) utility, which awarded us a 3MHz increase in base frequency and consequently a 48MHz overclock overall. Feeling a little underwhelmed we then took matters into our own hands.
Despite our best attempts, our processor refused to budge any further than 1728MHz (a base clock of 109MHz). Our best guess is that the memory controller and the link between the APU and the Hudson M1 cannot tolerate higher base frequencies.
Ho hum, let's look into Temperatures and Power Consumption.
As the new HD 6310 GPU supports UVD 3.0, this means that DivX decoding is now included (on top of the existing MPEG2/H.264) and also Blu-Ray 3D support. However neither Asus or AMD have clearly stated that the HD 6310 will decode 3D well. I suppose this will become more clear as time goes on however my initial impressions are that a HTPC for higher end functionality such as 3D support or anything else that may command some more CPU horse power is probably better off with a conventional CPU and dedicated GPU.
I hope that helps
Pros: you'll have the coolest running 18W CPU on the block. WooHoo! Bragging rights.
Cons: You'll probably need to work on the mount - I don't see the usual AM3 hardware on that board. And do you figure £150 or more on a full-tower case to accommodate the Noctua is about right for a rig like this? An HAF-X or a Lanboy Air would be quite stylish.
http://www.asus.com/product.aspx?P_ID=9BmKhMwWCwqyl1lz&templete=2
Looks like it includes WiFi plus blue-tooth 3.0. Anyway, just look at the specs on this little monster. The feature set is extremely impressive for a Mini ITX board. I think this would make a sweet little pc that you could mount to the back of a monitor for a clutter and noise free desk. Definitely good for email, web browsing, word, netflix and watching movies.
So as Mul suggested probably wait for a more powerful AMD Fusion APU, and than bolt on a nice HTPC soundcard and PROFITS!
it doubled. so my question is using a discrete vga does indeed improves cpu perfomanse?? so a few more test with winzip and other cpu programs to see if with a discrete vga they will improve. if they improve then it will be interesting :-)
ANyone to comment that when you add the discrete card aand run the test to see how much it will bottleneck did you check the cpu score from 954 to 2020?? it doubled. so my question is using a discrete vga does indeed improves cpu perfomanse?? so a few more test with winzip and other cpu programs to see if with a discrete vga they will improve. if they improve then it will be interesting :-) |
But for a normal CPU, unless you a running nVidia with Physx I doubt it.
Loving these little options myself.
There was an error with this graph; CPU score should read 1954, not 954. This has now been edited, apologies if this has caused any confusion.
Another question would the new form factor have any complications in fitting into a standard ATX case?
Thanks
I am loving that the new technology for HTPC users like myself, as I am looking into this E35M1-M Pro board to build a low power HTPC. The only reason I would take this over the E35M1-M mini ATX board is that I need 2 PCIE slots for my Happauge Win Tv tuner cards, unless someone could tell me a great way of getting dual NTSC signals into one card ? Another question would the new form factor have any complications in fitting into a standard ATX case? Thanks |
http://www.silicondust.com/products/hdhomerun/dvbt/
Continue Reading
