Asus E35M1-M PRO Micro ATX
The E35M1-M PRO - A Closer Look
Published: 3rd February 2011 | Source: Asus | Price: £119.99 |
A Closer Look
Another day, another Asus box. The design theme may not have changed much however we would rather see a starving marketing department over a cash throttled R&D division.
Inside you will find the usual suspects; a manual, I/O shield, Q Connector and two SATA cables. More than enough to bring your new computer to life.
Underneath the false floor you will find the E35M1-M PRO motherboard. As you can probably tell, it is of Micro ATX form factor, although Asus have decided to not exercise the full 9.6" x 9.6" size allowance. If it cuts the overall cost of the board without losing functionality, we really do not mind.
Feature rich is definitely a term to describe this product. Despite being an entry level platform, Asus have provided 5 internal SATA 6.0Gb/sec ports at your disposal with scope for up to 14 USB ports, of which 2 are of 3.0 standard.
You won't be lost for video outputs either as the E35M1 should agree with any user, from the cheapskate with the 15" CRT on DSUB, through to the HTPC user with the 50" 1080p HDTV.
Interested in what lurks underneath that big blue heatsink? Turn over...
As the new HD 6310 GPU supports UVD 3.0, this means that DivX decoding is now included (on top of the existing MPEG2/H.264) and also Blu-Ray 3D support. However neither Asus or AMD have clearly stated that the HD 6310 will decode 3D well. I suppose this will become more clear as time goes on however my initial impressions are that a HTPC for higher end functionality such as 3D support or anything else that may command some more CPU horse power is probably better off with a conventional CPU and dedicated GPU.
I hope that helps
Pros: you'll have the coolest running 18W CPU on the block. WooHoo! Bragging rights.
Cons: You'll probably need to work on the mount - I don't see the usual AM3 hardware on that board. And do you figure £150 or more on a full-tower case to accommodate the Noctua is about right for a rig like this? An HAF-X or a Lanboy Air would be quite stylish.
http://www.asus.com/product.aspx?P_ID=9BmKhMwWCwqyl1lz&templete=2
Looks like it includes WiFi plus blue-tooth 3.0. Anyway, just look at the specs on this little monster. The feature set is extremely impressive for a Mini ITX board. I think this would make a sweet little pc that you could mount to the back of a monitor for a clutter and noise free desk. Definitely good for email, web browsing, word, netflix and watching movies.
So as Mul suggested probably wait for a more powerful AMD Fusion APU, and than bolt on a nice HTPC soundcard and PROFITS!
it doubled. so my question is using a discrete vga does indeed improves cpu perfomanse?? so a few more test with winzip and other cpu programs to see if with a discrete vga they will improve. if they improve then it will be interesting :-)
ANyone to comment that when you add the discrete card aand run the test to see how much it will bottleneck did you check the cpu score from 954 to 2020?? it doubled. so my question is using a discrete vga does indeed improves cpu perfomanse?? so a few more test with winzip and other cpu programs to see if with a discrete vga they will improve. if they improve then it will be interesting :-) |
But for a normal CPU, unless you a running nVidia with Physx I doubt it.
Loving these little options myself.
There was an error with this graph; CPU score should read 1954, not 954. This has now been edited, apologies if this has caused any confusion.
Another question would the new form factor have any complications in fitting into a standard ATX case?
Thanks
I am loving that the new technology for HTPC users like myself, as I am looking into this E35M1-M Pro board to build a low power HTPC. The only reason I would take this over the E35M1-M mini ATX board is that I need 2 PCIE slots for my Happauge Win Tv tuner cards, unless someone could tell me a great way of getting dual NTSC signals into one card ? Another question would the new form factor have any complications in fitting into a standard ATX case? Thanks |
http://www.silicondust.com/products/hdhomerun/dvbt/
Continue Reading
