Asus Crosshair IV Extreme
CPU Performance
Search Reviews
CPU Performance
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC.
CPU Arithmetic
The CPU arithmetic test ascertains the processor's capabilities in terms of numerical operations. Two subtests named Dhrystone and Whetstone are carried out respectively. This is not a measure of latency and thus higher is better.
Unsurprisingly, the Crosshair IV Extreme commences our testing with scores that nicely match the Crosshair IV Formula and the recently reviewed 870A Fuzion PE. As the man responsible for testing almost all of OC3D's Socket AM3 motherboards, let me assure you that these results are exactly as expected.
CPU Multimedia
The CPU Multimedia Test focuses on CPU based operations that may occur during multimedia based tasks. The magnitude of the score depends on the processor's ability to handle Integer, Float and Double data types
Once again a similar story with CPU Multimedia. Strong gains are shown by our overclock in the region of 4.00GHz.
CPU Queen
CPU Queen is based on branch prediction and the misprediction penalties that are involved.
Everest's CPU benchmark suite usually tends to offer similar outcomes. The Queen benchmark also shows a level set of results.
CPU Photoworxx
PhotoWorxx as the name may suggest tests processors by means of invoking functions that are common to Photo Manipulation including Fill, Flip, Crop, Rotate, Difference and Colour to B&W conversion.
Photoworxx performance has a tendency to fluctuate and so its often required to repeat the benchmark quite a lot to determine concordant results. Regardless, the CH4 Extreme appears to take a fair lead over the rest, while the MSI 870A holds its unusually low score.
CPU ZLib
This is an integer based benchmark that will test the CPU and Memory by means of the CPU ZLib compression library.
Equality is restored with the ZLib test. This is a particularly important test due to its operations having similarities with the likes of WinRAR.
29-09-2010, 19:00:12
tinytomlogan
At last, it's finally here. After four weeks of examining Asus' flagship AMD motherboard, what do we think of it?
Continue Reading
29-09-2010, 19:28:31
wraithien
Good review as usual though it did seem a little short. I had a bad feeling regarding the actively cooled heatsink when i first looked at the board a few weeks back, out of interest how hot does it get when the fan is unplugged? Hydra performance is thankfully better than i expected too. At £250 its not cheap especially with AMD's new none compatible CPU's coming quite soon. Never the less I will give this board some serious consideration for my new build.
29-09-2010, 19:34:47
AMDFTW
Continue Reading
there is no graph for metro fella
man i realy wished this performed better its a shame tho
29-09-2010, 20:08:41
F-alienware
I must admit that I'm not a fan of the ROG motherboards. I liked the CHIV but this one goes too far with add on crap that's all a bit pointless.
I mean sure, if you are a gadget freak then it may appeal to you, but the bottom line on a board of this cost is function. Function should come over form as it does with the MSI.
Yet it wasn't even able to match the MSI's bottom line function.
So all of the stick on tat does very little if it is being compared to what I would call a budget board.
It was the same with my CHII ROG. Loads of stupid tat (The LED poster for one) that was fun for about five minutes and then got old fast. The only thing I really liked on that board that explained away the premium price was the cmos reset on the IO shield - that was bloody marvellous. But the rest? I ended up disconnecting the LED poster after about six boots never to use it again.
And then I got my M3A32 deluxe wifi which was also a very expensive board, yet doesn't have any silly bits on and has far more to offer in the way of function.
Again I suppose Asus are going to cater to many people with this board, but what with this, the Ares, the Mars II (if it ever comes along) and that add in board previewed today I just worry sometimes that they are being a bit over indulgent and started to fritter away their successes on stupid stuff.
It's all starting to seem a little... How do you say it?... EVGA.
Sorry if I sound harsh or pessimistic, I am only thinking aloud. But I think this time MSI have shown that stuff like this and EVGA boards are all rather pointless.
Thanks ever so much as ever for the reviews guys.
30-09-2010, 01:11:52
Wendriel
hi, i wanted to know if any of you readers, or even tom could tell me if this mobo is able to boot from a PCI e slot. im looking to build a system and have been hoping this board comes out, but was set on getting the formula. the only thing holding me back was the fact that it couldnt boot from pcie. i was planning on an OCZ RevoDrive (http://www.newegg.com/Product/Product.aspx?Item=N82E16820227597) but on the OCZ site, it states, "-Asus Crosshair IV – Please check with motherboard manufacturer for BIOS update to enable boot over PCIe." basically, with the new board, has the bios been updated to allow pci e booting? or am i still SOL...
30-09-2010, 03:52:20
tinytomlogan
PCIE booting is not something we test for so Im affraid you will have to look on the Asus website for specifics dude sorry
30-09-2010, 05:07:08
silenthill
Looks like that M/B fan is designed so that the M/B can takeoff from Heathrow airport
30-09-2010, 05:26:15
Diablo
Just thinking of the excellent board marred by fan issues that was the A8N-SLI deluxe makes me wince. I still run it, with a slow running 60mm fan. This board though has a lot of bells and whistles, only two of which makes me really want it (the hydra chip and the remote post). Ultimately for this price I can't see people choosing i7 and a decent midrange board over this and a 1060T.
Great review, shame about the price. The formula looks like the best option for those needing multi GPU lanes or the MSI for rampant overclockers.
30-09-2010, 06:43:05
alexhull24
TTL, I enjoyed the video of your impressions, it certainly made a much better deal of explaining what the board is really about and why it's not the stonking performance beast we were perhaps expecting.
Correct me if I'm wrong, but this board has taken a LONG time to come to market, and in the previews we've actually seen various heatsink designs fitted. Why oh why did they decide that this one was the best? Looking at how it's put together, I'm almost certain a better heatsink would deal with things much more effectively anyway. Perhaps they could have bundled an add-on fan for low airflow environments (read watercooling etc) that wasn't as small any whiny and above all, not necessary for most.
The performance also seems a bit of a let down for such an expensive piece of kit. You talk about it perhaps being good for extreme overclockers, but if you look at all the features on this board, perhaps it's not aimed at them, but more at the feature nuts who want to control their board with bluetooth and run mixed cards just because they can. Some of the sentiments in this thread seem to be that the RoG boards are almost gimmicky and don't have the performance to match, especially the AMD ones. There must be an element of truth in that.
Speaking of AMD, the only massive advantage this board has is SLI I would think. You could change to a hex core and run your 460 SLI etc if you wanted to. It does seem AMD have made some headway to Intel on the CPU front, but they're still not there yet. I think you may be right that they're not extracting everything from the multi-gpu setup, but the reason is unclear. Hopefully it is just drivers as you say. I guess we'll see as the Lucid chips mature. You can't ignore the major selling point for AMD kit though. You get most of the performance and all the high end features you want for a fraction of the price. It's nice to have a top end board to play with (I have the Crosshair III Forumula) rather than a run of the mill. Still, I understand that's not everybody's cup of tea, but it makes extreme overclocking with all the bells and whistles (and bluetooth overclocking!) a bit more accessible.
Disappointed that after a massive wait this board is a bit of a flop? Yes. Would I still like to play with it and clock the nuts off my AM3 chip with my phone? Almost certainly!
30-09-2010, 07:21:05
F-alienware
There's now a hack that allows you to run SLI on any ATI/AMD chipset.
I've not tried it (obviously) but there are videos doing the rounds on Youtube ETC.
Just in the process of watching your video Tom..
I think the difference with the results over the P55 and the AMD set is the bios. Well, not strictly the bioses but the drivers communicating with the ports.
The P55 (IIRC) already allows SLI and Crossfire.. Let me check that... Yes it would seem it does. And maybe this has made it easier to integrate the Lucid chip into those boards?
Moving onto your MSI comment about how it was faster? Well, MSI have more experience with the Lucid IMO. Thus they know how to integrate it better and how to work their bios possibly? Where as Asus have never tried it before?
Things could well improve with bios updates....
I do really appreciate your honesty over it all. Most would get all excited and say how wonderful it was, but this is very misleading and can cause people to waste money. What I really respect from you guys is the fact that Asus are good to OC3D and supply us with some of the most droolworthy items, yet, there is no favoritism when reviewing their products.
I also really appreciate how you have demonstrated just how much bum that fan sucks. Most wouldn't give a crap about that noise, but times are a changing and that noise is just not acceptable any more. I know a good few people who bought the EVGA 790i board and that too had a woefully loud and obnoxious northbridge fan. The workaround was to cable tie a 92mm fan on to quieten it down, yet, not a single review mentioned this. It seems that some people think that just because a product is expensive and top of the range that it can be loud and no one should care. Olbocks !
*Hi Emma !*
Once again I appreciate your videos, your honesty and this site's integrity on being truthful and honest !
I mean, it is obviously down to the drivers, as it could be that the drivers need to be completely and utterly different to do what they do on an ATI/AMD set. Communciation between the lanes is handled by the bios at a low level IIRC via the northbridge so it may take Lucid/Hydra time to sort this out. Or, it could even be the actual bios itself?
But yes, those scores look utterly cack.
30-09-2010, 08:01:29
El Gappo
Sli on amd? http://www.xdevs.com/eplugins/content/content.php?content.30 Problem solved. Enough of this board, NEXT!
30-09-2010, 11:08:41
wraithien
Hi Tom I've just got round to watching the review video on youtube you mention your issue with running the 5870 and a 480 together while i agree with you on that. I think this board will appeal to those who wish to have the benefits of nvidia cards such as physX. So for example I'm thinking of having a 5870 as the main card and then something like a 450 purely for PhysX. After watching your video though that fan is beyond irritating. And also given the price difference between this and the IV Formula I'm struggling to justify the very significant price difference.
30-09-2010, 11:29:04
Diablo
wraithien, as it stands, there is an unofficial hack that allows a physx card to be run with an ATI card, the patch is free, so it wouldn't make sense just to buy this board when the same effect can be enabled for free. That and there are very few instances when physx is actually worth it.
I don't see the difference in price between the formula and extreme though. With all the extras I could understand £50, but £100 is excessive really.
30-09-2010, 11:47:54
AMD_PBz
I officially feel cheated and let down greatly by ASUS
It greatly leaves me questioning the worthiness of even the Formula as it has overheating problems on the north bridge. With all the hype everything has now come to a grinding halt and fallen flat on it's face.
Why on earth did they not stick with some of the early passive heatsinKS which looked far better and were dead silent to boot.
Oh The decisions!
30-09-2010, 16:17:51
barkaway
Oh The decisions!
God i so know what you talk about,i mean come on asus..
And what the heck is the deal with lucid working better with intel, jesus...
30-09-2010, 17:21:35
AMD_PBz
Iphone App is available and free to download in the app store have had in on my phone for about a week for anyone with an iphone it's version 1.00.05
02-10-2010, 13:28:31
wraithien
Does anyone know when this is going to be avaliable in the UK? Its readily avaliable in America already and though I'm probably going to go with the Crosshair iv Formula would be nice to see what the cheapest price these are going to go for.
03-10-2010, 08:37:22
Mul.
Asus recently got in touch with us to discuss the heatsink's fan. Our article has been updated (along with a few other things) to reflect this.
Long story short, the fan is not a necessity. While previous ROG packages offered an optional bolt on fan, the Extreme has one prefitted on the grounds of space saving. The fan is orientated towards those who run their systems under conditions with minimal case airflow (i.e.- open test bench and/or watercooled). It is only fair that we mention the reasoning behind the fan implementation, but our personal opinions remain unchanged.
05-10-2010, 17:03:55
Wendriel
Hey, in case anyone was wondering, asus got back to me and they do now support booting from a pci-e device. So very happy 8-)
