Asus Blitz Extreme P35 Socket 775 Motherboard
Results - Sisoft Sandra & Everest
Published: 16th August 2007 | Source: Asus | Price: |
Sisoft Sandra is a synthetic benchmark utility capable of reporting and benchmarking a wide range of system components. For the Blitz Extreme, P5K and P5K3 motherboards we run both the CPU, Memory and Disk benchmarks three times to ensure accuracy of results.
Everest is in many ways similar to Sisoft Sandra. Focusing mainly on Software and Hardware information reporting, Everest also comes with a benchmark utility suitable for testing the read, write and latency performance of the memory subsystem.
Result Observations
In the Sisoft Sandra and Everest memory benchmarks the Blitz Extreme totally walked over the P5K and P5K3 motherboards despite the P5K3 using the same memory modules at the same settings. It certainly seems that Asus have done some behind-the-scenes tweaking of the memory latencies on the Blitz to produce such impressive results.
As expected, the disk benchmarks for all 3 boards were identical. This is due to the P5K, P5K3 and Blitz all using the ICH9R southbride chipset for their primary SATA controllers.
they've taken there previous motherboards, and just tweaked them to make them slightly better, added a higher pricetag, and shoved it on the market, genious really
oh, and great review
very....extensive
very....extensive
I think ASUS fans will like this especially, for the reasons ionicle states. Though it does imply that this latest tweak will allow u to get that much more % of an oc.
Outside of this review, I`d like to see a study where some1 takes 1 set of a full pc hardware install, and install the OS on it a large number of times. Each time take the benchmarks like XMS has used, and find out how much a difference u get in terms of a % each time. It`ll be small, I`d think, but it would add proof to my thinking that one board beating another in a finite benchmark doesn`t necessarily mean anything, unless it goes over a %.
My theory being, u build a setup and install u`r OS fully and u`ll get 1 result. Next time around, wipe the drive, and re-install everything and u`r result will be off by a few %.
No generally that's not the case actually as I have done that a couple of times for varying reasons. You get a score almost exactly identical, shown especially by the benchmarks on these three boards that are exactly the same
Big question:
Is it better than the IP35 Pro
great review, I enjoyed reading it.
Worth getting over the p5k premium?
Originally Posted by name='Ham'
Big question:
Is it better than the IP35 Pro ![]() |
Mate, that was a review and a half, probably one of the best on this site.
The mobo looks quality, a friend of mine Alex has £2K for an air cooled PC, this would have been a good coice if it did not require water on the NB
The tiny voltage increments is a god send, although can you imagine how long it would take to tune down to the sweet spot?
P.S Link to forum from front page not worky
Think I`m edging towards the likes of 3dmark, big number value outputers, where I`ve witnessed myself a +/-100, which on the face of it doesn`t look much, but comparing boards it can make one look better than the other. Think tho it`s wildly accepted that u can get a different mark score everytime u run it, so maybe a % acceptance should be assumed. One board beating another by a couple of hundred marks may look good, but not necessarily be that accurate - I think is what I`m saying. Imo the 06 marks should be divided by 100, with no decimal places, or something.
ABit vS ASUS playoff would be interesting.
I see where you're coming from Rasta, and yes 3DMark05 scores are a little more prone to variation (3DMark06 is actually very reproducible). Running the tests 3 times does help to average out any fluke results, but I think our accuracy is as good, if not better than other review sites.
One thing that does annoy me is when graphs are set to a small scale so that minor differences in results look like massive. I try to avoid this as much as possible - if something is 1.111 and the other is 1.112, then you shouldn't even be able to see the difference on a graph imo.
Cheers dude. It took a little while to complete (to say the least).
I was a bit miffed about the w/c requirement too, but I guess there's no way around it really.
I'm actually considering buying one to replace my beloved command...and I'll probably be sticking a Swiftech NB cooler and some heatsinks on SB/Crosslinx to avoid messing up my water loop.
The mobo looks quality, a friend of mine Alex has £2K for an air cooled PC, this would have been a good coice if it did not require water on the NB The tiny voltage increments is a god send, although can you imagine how long it would take to tune down to the sweet spot? P.S Link to forum from front page not worky |
Stats can be very finicky, averaging is often u`r best friend in that sense.
Outside of spending a month benching 1 mobo, I`m not sure what else u could do. Point in fact, the way u`r doing it is obviously tried and tested and does very well tbh.
I`d just h8 to think some1 would look at a bunch of really close results for a group of items and bank on a small % win for 1 item as it spanking the others.
Meh, something to think about maybe whilst people read a review rather than for a reviewer to compensate for.
that is a review and a half for sure,good work.
the price doesnt seem all that bad either.
Raging.
Raging.
Jim, are you getting the Extreme (ddr3) or the Formula (ddr2)?
Guys , sorry but i'm confused a little bit , this motherboard have 4 ram slots
2x blue color the other 2 are in white ,
does that mean i can run ddr2 (OR) ddr3 ram individually , coz i want to buy it now but i can't afford buying 2GIG Ram module at the same time, instead i want to use my ddr2 ram for the moment.. advise please
Hi mate and welcome to OC3D
The Blitz Extreme is a DDR3 motherboard, where the Blitz Formula is DDR2. This is not a review of a hybrid board. If you want to run your DDR2 then you'll need to get yourself the Blitz Formula.
The Blitz Extreme is a DDR3 motherboard, where the Blitz Formula is DDR2. This is not a review of a hybrid board. If you want to run your DDR2 then you'll need to get yourself the Blitz Formula.The Diffrent Colours are somthing to do with Dual Channel i belive
, and as PV said they are two diffrent Boards;
Blitz Extreme = DDR 3
Blitz Formula = DDR 2
, and as PV said they are two diffrent Boards;Blitz Extreme = DDR 3
hi there all (my first post ) i have what i assume will be a stupid question but i wanted to know if the "Crosslinx" has any relation to an SLI GPU setting (makes it better worse or no different) i assume it does not have any relation but just making sure and also if i have an SLI configuration on this MoBo do i need to worry about cooling it (the crosslinx chip that is)
thanks for helping a noob in this
This board uses the "P35" chipset, which can NOT run SLI. If you want SLI you will need to get a board with a Nvidia chipset.
The Crosslink allows you to run a CROSSFIRE setup (ATI/AMD) using two 8x/8x lanes to your graphics cards
hope that helps, and that im not mistaken on anything lol
hope that helps, and that im not mistaken on anything loli was not aware of this (damn all my computer build planing need to be redone) ........
is there a DDR3 MoBo out there that support SLI (i already have 2 8800 Ultra GPUs that i wold hate to pass down to my brother if i can help it and also for the fact that as far as i know ATI has not made a GPU that can compete with NVidia (am i right??)
__________________________________________________ ____
soon to buy it :-)
Motherboard
1x Asus Blitz Extreme(??)
Power supply
Memory
4x OCZ DDR3 PC3-12800 FlexXLC Edition(??)
GPU
2x Asus EN8800ULTRA/G/HTDP/768M(have)
HDD
4x Western Digital's Raptor 150GB(each.)(have)
Screen
1x HP LP3065(??)
Keyboard & Mouse
Case
Cooling
Mods
Misc
soon to buy it :-)
Motherboard
Power supply
Memory
GPU
HDD
Screen
1x HP LP3065(??)
Keyboard & Mouse
Case
Cooling
Mods
Misc
Erm, Well tbh i'v never looked at SLI compatable motherboards, i just know the p35 chipset dosnt support it ^^, im sure somone will post some more helpful advice later today, but might be better to post a thread in the Motorboard section, will catch more attention i belive. Oh and Welcome to the forums
Thanks and i will :-)
Thanks Elderbree, i will think again after your question , i already have 2 asus 8800 gtx and it would be very dissapointement if i bought this motherboard without sli, i think i can wait for now till something new like blitz BUT with SLI Support, Thanks guys all of you for replying fast & 4 the help
XMS - does the blitz come with adaptors for the NB? Long story short - I'm craming alot into a small case so the rad will overlap the bottom pci slot, pci-e slot, crosslinxchip/sb chip.
No room for heatsinks have to w/c NB. Not having a window so I guess looks don't matter anymore :/
Getting a refund on the q6600, e6850 ftw.
I'm ordering from our in house boys so let me know asap
No room for heatsinks have to w/c NB. Not having a window so I guess looks don't matter anymore :/ Getting a refund on the q6600, e6850 ftw. I'm ordering from our in house boys so let me know asap |
You seem like a e6850 man to me, I reckon it'll make u more happy than a quad.
Case is tight, I need the flexibility of the 7/16" tubing...
I think I'll be happier with the e6850... I was thinking I'd get more than 3.5 stable from the q6600 (especially as it was tested to 3.6 on relativly low volts).
I want 4.0ghz from the 6850 on water! More would be nice
Case is sorted too
Off topic - Jim, I have that hiper for sale but I also have a load of other things, rads, pelt, etc etc... Can you change the title if I add things to it tonight?
Case is sorted too
I think I'll be happier with the e6850... I was thinking I'd get more than 3.5 stable from the q6600 (especially as it was tested to 3.6 on relativly low volts). I want 4.0ghz from the 6850 on water! More would be nice ![]() |
A new OC3D server being built soon will have a Quad in it tho
Off topic - Jim, I have that hiper for sale but I also have a load of other things, rads, pelt, etc etc... Can you change the title if I add things to it tonight? |
Originally Posted by name='XMS'
Its what I'll be getting when F40 gets sold off. For my rig I can't justify the need for Quad - especially not at the moment.
The Blitz Extreme is a DDR3 motherboard, where the Blitz Formula is DDR2. This is not a review of a hybrid board. If you want to run your DDR2 then you'll need to get yourself the Blitz Formula. |
The Blitz Formula SE and Blitz Extreme use the same NB chipset (P35) and subsequently the same Fusion water block. I have never tried my Formula without water-cooling so I can't comment there, but if you remove the thermal paste that ASUS uses for their chipset cooling and apply AS Ceramique then you possibly could. If you aren't looking to overclock then the Fusion block should be ok as is, but I would recommend applying a better thermal paste anyway. Failing that, you could always go and get yourself some better NB/SB cooling and replace ASUS' heat-pipes altogether
http://www.overclock3d.net/gfx/artic...120649525s.jpg
Asus Blitz Extreme Review
