Asus Blitz Extreme P35 Socket 775 Motherboard
The BIOS
Search Reviews
The BIOS
As with all of Asus' most recent motherboards, the Blitz Extreme is based around a BIOS from Phoenix Technologies. Some enthusiasts tend to favor the Award BIOS layout over Phoenix, but it's extremely hard to find fault with the overall wealth of features available on the Blitz.
Asus Blitz Extreme BIOS Asus Blitz Extreme BIOS
The "Extreme Tweaker" section of the BIOS is where you'll find most of the overclocking related options. Settings such as CPU multiplier, FSB/NB Strap, FSB Frequency, Memory Frequency, Memory Timings and Memory Command Rate (1T/2T) can all be adjusted in the upper section of this page. The list of available choices for some of these options can be seen below:
OptionAvailable Range
CPU Multiplier
x6 upwards
FSB/NB Strap
200/266/333mhz
FSB Frequency
200-800mhz (1mhz steps)
PCI-E Frequency
100-150mhz (1mhz steps)
DRAM Command Rate
1T / 2T
Asus Blitz Extreme BIOS Asus Blitz Extreme Voltages
Asus Blitz Extreme Voltages Asus Blitz Extreme Voltage
Asus Blitz Extreme Voltages Asus Blitz Extreme Voltages
When it comes to voltage options on the Blitz, all I can say is "wow!". Somebody at Asus was clearly hell bent on on giving this board the most extensive range of voltage options on any motherboard in existance. For a start, the CPU voltage can be increased up to a silicon frying 1.9v in minisucule 0.00625v increments, then there's the DDR3 memory voltage which can be taken from 1.50v up to a whopping 3.04v in 0.02v steps.
Obviously a large range of these options are dangerous to the health of hardware, so Asus have gone to the trouble of placing LED's at various points on the motherboard (CPU, Northbridge, Southbridge, DRAM Slots) that change from green to orange to red depending on how much voltage you are putting through the components.
A full list of voltage options can be seen in the table below:
CPU Voltage
1.1v-1.9v (0.00625v steps)
FSB Termination Voltage
1.20v-1.80v (0.02v steps)
Northbridge Voltage
1.25v-2.03v (0.02v steps)
DRAM Voltage
1.50-3.04v (0.02v steps)
Southbridge Voltage
1.050v-1.225v (0.025v steps)
PLL Voltage
1.05-1.20v (0.02v steps)
Asus Blitz Extreme Profile Asus Blitz Extreme Profile
With the extensive range of options available in the BIOS the last thing you wan't to do is lose your configuration once you've found the sweet spot for your overclock. This is where the Asus O.C Profile comes in to play. Allowing you to save all of your BIOS settings to one of two available profiles in the CMOS or to an external storage device, your settings can then be restored easily at a later date.
Asus Blitz Extreme Hardware Monitor Asus Blitz Extreme Hardware Monitor
The "Hardware Monitor" section of the BIOS has also been given a re-vamp too since we last visited it on the P5K. Temperature monitoring of the Northbridge and Southbridge has been added along with a much wider range of voltage monitoring points.
«Prev 1 2 3 4 5 6 7 8 9 10 Next»
16-08-2007, 16:22:22
Jim
"After the success of Asus' first P35 chipset motherboard, we've been given the opportunity to test the tweaked out "Republic of Gamers" version affectionately known as the Blitz. Will it come out all guns blazing or bomb it big time? Read on to find out."
http://www.overclock3d.net/gfx/artic...120649525s.jpg
Asus Blitz Extreme Review
16-08-2007, 16:42:37
ionicle
they've taken there previous motherboards, and just tweaked them to make them slightly better, added a higher pricetag, and shoved it on the market, genious really
oh, and great review
very....extensive
16-08-2007, 16:55:54
Rastalovich
I think ASUS fans will like this especially, for the reasons ionicle states. Though it does imply that this latest tweak will allow u to get that much more % of an oc.
Outside of this review, I`d like to see a study where some1 takes 1 set of a full pc hardware install, and install the OS on it a large number of times. Each time take the benchmarks like XMS has used, and find out how much a difference u get in terms of a % each time. It`ll be small, I`d think, but it would add proof to my thinking that one board beating another in a finite benchmark doesn`t necessarily mean anything, unless it goes over a %.
My theory being, u build a setup and install u`r OS fully and u`ll get 1 result. Next time around, wipe the drive, and re-install everything and u`r result will be off by a few %.
16-08-2007, 17:31:19
FarFarAway
No generally that's not the case actually as I have done that a couple of times for varying reasons. You get a score almost exactly identical, shown especially by the benchmarks on these three boards that are exactly the same
16-08-2007, 18:14:52
Ham
Big question:
Is it better than the IP35 Pro
16-08-2007, 20:07:06
glocktodahead
great review, I enjoyed reading it.
16-08-2007, 20:14:27
Azreil_2
Worth getting over the p5k premium?
17-08-2007, 01:00:22
Jim
Originally Posted by name='Ham'
Big question:
In terms of features I'd personally say yes. But the IP35 is a fair bit cheaper so it all matters what you want really.
For the extra £20-30 I'd say yes definitely.
17-08-2007, 05:38:00
Mr. Smith
Mate, that was a review and a half, probably one of the best on this site.
The mobo looks quality, a friend of mine Alex has £2K for an air cooled PC, this would have been a good coice if it did not require water on the NB
The tiny voltage increments is a god send, although can you imagine how long it would take to tune down to the sweet spot?
P.S Link to forum from front page not worky
17-08-2007, 05:43:52
Rastalovich
Yeah, I can see how some statistics, the likes of cpu-use, the whole value of a percentage isn`t gonna waiver - and to be fair something like 3.05% and 3.25% of cpu isn`t that relevant.
Think I`m edging towards the likes of 3dmark, big number value outputers, where I`ve witnessed myself a +/-100, which on the face of it doesn`t look much, but comparing boards it can make one look better than the other. Think tho it`s wildly accepted that u can get a different mark score everytime u run it, so maybe a % acceptance should be assumed. One board beating another by a couple of hundred marks may look good, but not necessarily be that accurate - I think is what I`m saying. Imo the 06 marks should be divided by 100, with no decimal places, or something.
ABit vS ASUS playoff would be interesting.
17-08-2007, 06:16:50
Jim
I see where you're coming from Rasta, and yes 3DMark05 scores are a little more prone to variation (3DMark06 is actually very reproducible). Running the tests 3 times does help to average out any fluke results, but I think our accuracy is as good, if not better than other review sites.
One thing that does annoy me is when graphs are set to a small scale so that minor differences in results look like massive. I try to avoid this as much as possible - if something is 1.111 and the other is 1.112, then you shouldn't even be able to see the difference on a graph imo.
Cheers dude. It took a little while to complete (to say the least).
I was a bit miffed about the w/c requirement too, but I guess there's no way around it really.
I'm actually considering buying one to replace my beloved command...and I'll probably be sticking a Swiftech NB cooler and some heatsinks on SB/Crosslinx to avoid messing up my water loop.
17-08-2007, 06:21:38
Jim
17-08-2007, 06:25:39
Rastalovich
Stats can be very finicky, averaging is often u`r best friend in that sense.
Outside of spending a month benching 1 mobo, I`m not sure what else u could do. Point in fact, the way u`r doing it is obviously tried and tested and does very well tbh.
I`d just h8 to think some1 would look at a bunch of really close results for a group of items and bank on a small % win for 1 item as it spanking the others.
Meh, something to think about maybe whilst people read a review rather than for a reviewer to compensate for.
17-08-2007, 07:27:39
Raging
that is a review and a half for sure,good work.
the price doesnt seem all that bad either.
Raging.
17-08-2007, 09:02:56
Mr. Smith
Jim, are you getting the Extreme (ddr3) or the Formula (ddr2)?
17-08-2007, 09:19:48
Jim
I'm gonna grab me an Extreme....Speeds like DDR3-2000 make me weak at the knees
21-08-2007, 07:20:33
bo_3li_h
Guys , sorry but i'm confused a little bit , this motherboard have 4 ram slots
2x blue color the other 2 are in white ,
does that mean i can run ddr2 (OR) ddr3 ram individually , coz i want to buy it now but i can't afford buying 2GIG Ram module at the same time, instead i want to use my ddr2 ram for the moment.. advise please
21-08-2007, 07:33:30
PV5150
Hi mate and welcome to OC3D The Blitz Extreme is a DDR3 motherboard, where the Blitz Formula is DDR2. This is not a review of a hybrid board. If you want to run your DDR2 then you'll need to get yourself the Blitz Formula.
21-08-2007, 07:39:05
Azreil_2
The Diffrent Colours are somthing to do with Dual Channel i belive , and as PV said they are two diffrent Boards;
Blitz Extreme = DDR 3
Blitz Formula = DDR 2
21-08-2007, 07:43:09
Elderbree TM
hi there all (my first post ) i have what i assume will be a stupid question but i wanted to know if the "Crosslinx" has any relation to an SLI GPU setting (makes it better worse or no different) i assume it does not have any relation but just making sure and also if i have an SLI configuration on this MoBo do i need to worry about cooling it (the crosslinx chip that is)
thanks for helping a noob in this
21-08-2007, 07:48:40
Azreil_2
This board uses the "P35" chipset, which can NOT run SLI. If you want SLI you will need to get a board with a Nvidia chipset.
The Crosslink allows you to run a CROSSFIRE setup (ATI/AMD) using two 8x/8x lanes to your graphics cards hope that helps, and that im not mistaken on anything lol
21-08-2007, 07:57:30
Elderbree TM
i was not aware of this (damn all my computer build planing need to be redone) ........
is there a DDR3 MoBo out there that support SLI (i already have 2 8800 Ultra GPUs that i wold hate to pass down to my brother if i can help it and also for the fact that as far as i know ATI has not made a GPU that can compete with NVidia (am i right??)
__________________________________________________ ____
soon to buy it :-)
Motherboard
1x Asus Blitz Extreme(??)
Power supply
Memory
4x OCZ DDR3 PC3-12800 FlexXLC Edition(??)
GPU
2x Asus EN8800ULTRA/G/HTDP/768M(have)
HDD
4x Western Digital's Raptor 150GB(each.)(have)
Screen
1x HP LP3065(??)
Keyboard & Mouse
Case
Cooling
Mods
Misc
21-08-2007, 07:59:56
Azreil_2
Erm, Well tbh i'v never looked at SLI compatable motherboards, i just know the p35 chipset dosnt support it ^^, im sure somone will post some more helpful advice later today, but might be better to post a thread in the Motorboard section, will catch more attention i belive. Oh and Welcome to the forums
21-08-2007, 08:03:00
Elderbree TM
Thanks and i will :-)
21-08-2007, 08:25:39
bo_3li_h
Thanks Elderbree, i will think again after your question , i already have 2 asus 8800 gtx and it would be very dissapointement if i bought this motherboard without sli, i think i can wait for now till something new like blitz BUT with SLI Support, Thanks guys all of you for replying fast & 4 the help
23-08-2007, 06:29:18
Mr. Smith
XMS - does the blitz come with adaptors for the NB? Long story short - I'm craming alot into a small case so the rad will overlap the bottom pci slot, pci-e slot, crosslinxchip/sb chip.
No room for heatsinks have to w/c NB. Not having a window so I guess looks don't matter anymore :/
Getting a refund on the q6600, e6850 ftw.
I'm ordering from our in house boys so let me know asap
23-08-2007, 06:42:49
Jim
Yeah you get a big bag of adapters that allow you to use most tubing sizes with the NB. Are you going 1/2"? I'll double check tonight if ya like.
You seem like a e6850 man to me, I reckon it'll make u more happy than a quad.
23-08-2007, 06:52:54
Mr. Smith
Case is tight, I need the flexibility of the 7/16" tubing...
I think I'll be happier with the e6850... I was thinking I'd get more than 3.5 stable from the q6600 (especially as it was tested to 3.6 on relativly low volts).
I want 4.0ghz from the 6850 on water! More would be nice
Case is sorted too
Off topic - Jim, I have that hiper for sale but I also have a load of other things, rads, pelt, etc etc... Can you change the title if I add things to it tonight?
23-08-2007, 07:00:12
Jim
I doubt it will have 7/16" in there, but if it has 1/2" it's just a case of sticking the tubing in some hot water and it'll slide over with a bit of force.
Its what I'll be getting when F40 gets sold off. For my rig I can't justify the need for Quad - especially not at the moment.
A new OC3D server being built soon will have a Quad in it tho
Ja...just pm'izzle me.
23-08-2007, 12:31:01
FarFarAway
Ye here too. I want quad but I certainly don't need it
Oh yes it will, should be nice and lag free for those playing CS (and UT3 soon)
11-11-2007, 05:12:33
InSearchOf
hi, i just want some clarification about the Blitz Formula board. the Blitz Extreme review states that water cooling is a must on the NB. would this be true for the Formula board as well? i thought watercooling was an option not a necessity. is there any other website or review that confirms this? this now has me confused. what other mainstream ASUS P35 mobo would you recommend? i was thinking the P5K E or the P5K...any ideas would help, this would be my first build and dont want to watercool til i get more experience.
11-11-2007, 05:19:04
PV5150
The Blitz Formula SE and Blitz Extreme use the same NB chipset (P35) and subsequently the same Fusion water block. I have never tried my Formula without water-cooling so I can't comment there, but if you remove the thermal paste that ASUS uses for their chipset cooling and apply AS Ceramique then you possibly could. If you aren't looking to overclock then the Fusion block should be ok as is, but I would recommend applying a better thermal paste anyway. Failing that, you could always go and get yourself some better NB/SB cooling and replace ASUS' heat-pipes altogether
