AMD Athlon II 620 X4
Synthetic Tests part one
Search Reviews
Synthetic Benchmarks
Whilst not always an indicator of actual performance, synthetic benchmarks have a place in our hearts because there is nothing like the purity of numbers to give a feel for the capability of a processor or system, and you can also get a feel for how much extra performance to expect in general usage from an overclock.
SiSoft Sandra shows that the overclock of 25% gives an improvement of around 23% in the Arithmetic tests. Not bad at all as we know that you never get a one to one improvement.
The Multi-Media test showed an even higher improvement. Maths tells us that if we saw a one to one improvement via the clock speed then our Multi-Media Int overclocked result would be 149591. We actually got 149134 showing that this is one theoretical test that gets very close to a direct increase when the processor is overclocked.
7-Zip 64 bit comes with a built in benchmark. For this test we used the 32MB dictionary and ran 6 passes. This more real-world test showed similar results to the above two, in that this scales very well with little loss in performance between theoretical increase and that seen by the end user.
It wouldn't be CPU review without the old favourite SuperPI. In this case, whilst there is a clear improvement between the stock and overclocked tests, the 1M result isn't exactly earth shattering. Not bad for a disappointing overclock on a L3 disabled processor, but I was expecting around 20 seconds.
Let's go and see some more synthetic results.
«Prev 1 2 3 4 5 6 7 Next»
03-11-2009, 04:01:04
tinytomlogan
We welcome VonBlade to the Overclock3d Review team by sending him an AMD Athlon II 620 X4 to review.
Continue Reading
03-11-2009, 05:01:00
Mul.
Welcome to the team VB!
The X4 620 certainly is a stonking processor for the money, though my hunch is that the OC limitation lies with the motherboard. 250HTT can often be a real struggle for some boards. It may have been a CPU related limitation if the mobo didn't offer a decremental NB multiplier.
Good work!
03-11-2009, 07:37:11
VonBlade
Thanks Mul.
It was the most frustrating OC I've ever attempted. Usually you get towards it and gradually strike the balance between stability and the CPUz screengrab of death. This was just all or nothing.
It's amazing value for money though.
03-11-2009, 16:09:49
painejake
Picked one of these up last week actually... Gotta say for the cash it is a complete bargain. I managed 3.4Ghz but unstable. Running at 3.2GHz very stable
At £70-80 for a 3.2GHz Quad CPU you can't complain at all
Nice review VB
03-11-2009, 17:57:56
Rastalovich
Great review VB.
I think I'm alone in feeling uneasy about the pricing on this.
I do accept that, yes it's quad core, and yes it'll capably handle what's thrown at it - and I can see oc'ers liking this.
So why the uneasy feeling... perhaps if the £77 is mrrp and it onlines at £70 or a snatch under, I'd feel a little better.
But I think I latch onto the superpi score (which there is a multicore version available now I think I've seen), just under 25s for an oc. Then look over at Intel's camp, especially considering the £220 mobo/cpu idea. Intel are ofc making the adjustments too, and they're 'pentiumizing' previous c2d cpus, and yeah they're 2 cores (if u bank on 4 cores, or have a legit reason to think ur software will use it - ur not really on a budget imo) - but they are more attractively priced imo, and ofc they oc too.
Tough one.
04-11-2009, 13:29:13
Judderman
Originally Posted by name='VonBlade'
Thanks Mul.
Very good review, and looks like the chip is going to be a bit of a bargain, to check if the 250fsb is the limit did you drop the multiplier down?, this may give an indicator if the 250fsb is the problem or the 3.2ghz clock is the limit
04-11-2009, 13:57:15
funslave
Hi, new here.
1. Nice review, man. 'Cause that's real life, where the silicon you buy does only a part of what most reviews say.
2. It looks to me that the notorius and long praised 785G chipset is somewhat stucked in OC. I don't especially blame a certain producer, but the chipset/BIOS combination. AMD770 + SB710 appears more OC-friendly, since I personally jumped over the 250 mark, and I bet I'm not the only.
3. Picked one of these nano-beasts last month. I've come along with a CADAC. After getting around 3.7 GHz with decent voltage, finally managed the 3.9 GHz with 13 x 300 on air cooling, but at 1.6V (see validation below). By the way, was it possible to set the memory to "Ganged" in the BIOS? I've noticed that you may OC further in this way.
It is also a question of luck: during more than a 6-year period, this is only the third CPU I own in a long series which proved to be highly OC-able.
Sorry, I'm not allowed to post links.
04-11-2009, 15:44:11
VonBlade
Yes. Sorry I thought I'd said. The multiplier was dropped to 5, 7 and 10 and it still fell over at 250. Which does indicate it's probably the mobo.
Another test is in the pipeline.
