Abit IP35 Pro Intel socket 775 Motherboard
I/O and BIOS
Published: 30th July 2007 | Source: abit | Price: |
The backplate IO on the Abit IP35 Pro consists of:
* 4 x USB 2.0 Ports
* 2 x Gigabit LAN Ports
* 2 x e-SATA Ports
* SP-Dif Optical Input and Output
* 7.1 Analogue Surround Sound
* Microphone Input
* PS/2 keyboard and mouse input
* External CMOS reset switch
That's a decent amount of connections, mixing up the old and the new. Remember that the IP35 Pro provides us with 4 onboard USB 2 headers so we'll have plenty of USB input, even without a hub.
BIOS
The BIOS on the Abit IP35 Pro is a Phoenix Award BIOS and as usual with Abit it has everything you want.
To get into the overclocking features as usual Abit have gone for their uGuru BIOS utility. This is excellent and allows you full control over what you are overclocking.
Fron here we see that Abit give you all the way up to 600MHz FSB which is pretty decent.
The CPU volts go up to 1.825v which is rather generous and no-one apart from people using phase-change/LN2 or DICE should be using this much voltage. DDR2 voltage is also generous with 3.0v set in the "DDR2 Voltage" and an allowance for more in "DDR2 Reference voltage". I have not tried this feature as the RAM I was using only takes 2.2v max.
Again the NorthBridge voltage gets a decent amount of leeway at 2.0v and the MCH voltage gets an allowance of 1.72v.
Additional controls for memory timing are kept in the "Advanced Chipset Features" part of the BIOS and again there's a generous amount of tweaking to be done here.
Overall the BIOS on the ABit IP35 Pro is excellent as we have come to expect from Abit.
Great review Kemp, nice bunch of packaging akin to the rocketboy type of stuffz. I do wish the µguru thing was more of a 5.25 bay thingy tbh. Last time I checked, retailers were ramming these devices down peoples throats for like £11 or so - which amazes me why u never had one in the box ?!?
I would hope these good results will boost a tad more after some bios revisions, board to board I`d expect this one to be a bit better than shown - but meh..
Kewl, I recognize some of those photos too
Excellent review as usual mate. The 680i's are toasty little sods for sure, and it's a pity that abit didn't even provide some form of active cooling to try and address the problem. Well done
Their answer, and a few other manufs answer, seems to be to add this ugly looking heatpipe structure to stuff.
Heatpipes are great, but I don`t personally like the idea of 2 or 3 of the hs being connected together.
2 or 3 connected together is fine, but that needs active cooling to work ok
Great review, Kemp, thanks for doing it as I was thinking of grabbing one.
Now for my thoughts...
DAMN DAMN DAMN! I think the 680i chipset is good but not the king, would really like to see the 975X (or updated chipset) that can support nVidia's 8800 series gpu's in SLI... and done by ABIT. ABIT boards look great, and with the exception of the EZ PLUG for added graphics power, I like their layouts; not to mention my AW9D was rock-solid, even using an E6600 @ 3.7GHz... my 680i mobo can't touch it, only solid at 3.4GHz or lower.
Like the EZ CMOS as well, no more dip-switch installations!
(newer mobos don't have problems like the old mobos after a bad OC, but it's the thought that counts!)
I personally don't see all the fuss over the passive cooling for the NB/SB. My case uses 4 120mm fans on the side of the case, so I get a lot of extra cooling... not to mention the little fan that came with my mobo for the NB, so I don't have a heating problem. I think it works fine, even without the little fan made for the NB; on the other hand, an enthusiast board should give the user the option to remove the passive to add active (fan) cooling solutions. The only thing I wonder about is the need for pipes from SB--NB--PWM... do the pipes really do anything for the cooling?
TJS
Now for my thoughts...DAMN DAMN DAMN! I think the 680i chipset is good but not the king, would really like to see the 975X (or updated chipset) that can support nVidia's 8800 series gpu's in SLI... and done by ABIT. ABIT boards look great, and with the exception of the EZ PLUG for added graphics power, I like their layouts; not to mention my AW9D was rock-solid, even using an E6600 @ 3.7GHz... my 680i mobo can't touch it, only solid at 3.4GHz or lower.
(newer mobos don't have problems like the old mobos after a bad OC, but it's the thought that counts!)I personally don't see all the fuss over the passive cooling for the NB/SB. My case uses 4 120mm fans on the side of the case, so I get a lot of extra cooling... not to mention the little fan that came with my mobo for the NB, so I don't have a heating problem. I think it works fine, even without the little fan made for the NB; on the other hand, an enthusiast board should give the user the option to remove the passive to add active (fan) cooling solutions. The only thing I wonder about is the need for pipes from SB--NB--PWM... do the pipes really do anything for the cooling?
TJS
Thorough review as always.
You might have mentioned that they definitely are actively working on an updated BIOS though?
you mean like http://www.abit-usa.com/news/2005/20050511.php ?
That's the µguru panel - felt it should have been included with this board - would have certainly been a welcome addition
And yes I was going to put that in, but must have missed it out (twast 2.30am
). I'll add it now
). I'll add it nowbtw , I do believe that this is the world's first full published review of the IN9 32X MAX
edit: at least in English. Possibly done on a Japanese/Chinese site etc. where I would only be able to look at pretty pictures.
Come on Google, update that Index
Edit: And in that case - Digg It
Very thorough review like always. Seems like a rock solid board, at stock
Dugg.
Dugg.
Gotta love how 680i gets its butt kicked by 965/975
Great review Kempez. Awesome pictures, using your new camera I'm guessing?
only going to 440mhz max seems a bit low...
I've seen a screenie at 525 on 1 of the betas plus it seems to be overclocking Kentsfields better than the Striker/eVGA.
P.S. I put a link to your review in [H]ardOCP's forum IN9 32X thread.
Just waiting to hear back from abit atm but I may give it another go on one of the beta's if they ask me too. May need a dedicated fan on the NB though as it's toasty: which I didn't do for the other boards (I hasten to add)
EDIT: abit said they've had 550FSB in the labs
I'm inclined to believe that if the NB was cooled on the ABIT board like it is on the EVGA board it should do much better than 440FSB. I can't see ABIT putting out the smashing AW9D-MAX and then fall on their faces with the IN9 32X-MAX.
TJS
TJS
The AW9D-MAX does far from smash, I hated that board, and so did 90% of the other poor ripped off owners of it.
Hey, Frag, mine worked like a charm... didn't know so many had problems (other than Herr Schmidt). I thought a lot of people were getting some pretty good clocks compared to the 680i (don't know too much about the RD600 yet).
TJS
TJS
Passive chipset heatsink + extremely hot running chipset = ?
I find all this passive heatpipe nonsense very annoying personally. It wouldn't surprise me if it's cheaper than adding a fan, and that's the reason so many manufacturers are taking it onboard.
They build a board for enthusiasts, but the first thing enthusiasts do is rip off the nb cooling and replace it with something else (something that isn't aluminium sprayed in a copper colour).
If only they would implement a decent 3rd party solution or even get a decent solution in-house
Take a look inside...click
World Exclusive!!! - Digg It
