Abit IN9 32x Max Intel Socket 775 Motherboard
Overclocking
Overclocking
Overclocking was performed through the BIOS, as all good 24/7 overclocking should be done. I have heard mixed results from the 680i chipset so I was wondering what I would get from the IN9. There are plenty of BIOS options to play with but the BIOS feels a bit in need of an update and it seems I am not the only one to think so.
Low Voltage Overclocking
I set an upper limit of 1.325v for the CPU and clocked the CPU as high as I could whilst maintaining a 3 hour Orthos (dual prime95) stable overclock. As the abit board only gives you 1.33v or 1.32v I have chosen 1.32v.
3350
3350 cpu-z
3350Mhz on 1.32v stable is pretty nice overclock for sure.
Overclocking - Highest Possible Stable on Air
For this test I stopped when I got concerned that the temperature rose too high. This overclock was performed on air using a Scythe Infinity. I stopped when the CPU started getting around 65-70°C. For this overclock I had to use 1.65v which is not always to be recommended for those who are faint of heart! Let's see how we get on here.
3800 stable
abit in9 3800mhz
Once again the IN9 shows that it's up there with the best overclocking boards we've tested.
Max FSB
Here the abit board showed some weakness.
440 fsb
440 fsb stabl;e
I got the board to 440FSB x 6 100% stable. However for some reason the board just would not boot past the welcome screen at 1Mhz past this speed. This was slightly disappointing, especially as I felt this board could do more. After a long afternoon and evening trying various hardware configurations, BIOS settings etc I gave up but I really think the board can do more...
A mixed bag of overclocking, but there is certainly a lot of potential.
«Prev 1 2 3 4 5 6 7 8 9 Next»
14-02-2007, 08:41:40
FarFarAway
Top dollar...but is it a top board?
Take a look inside...click
World Exclusive!!! - Digg ItQuote
14-02-2007, 09:13:14
Rastalovich
Great review Kemp, nice bunch of packaging akin to the rocketboy type of stuffz. I do wish the µguru thing was more of a 5.25 bay thingy tbh. Last time I checked, retailers were ramming these devices down peoples throats for like £11 or so - which amazes me why u never had one in the box ?!?
I would hope these good results will boost a tad more after some bios revisions, board to board I`d expect this one to be a bit better than shown - but meh..
Kewl, I recognize some of those photos too Quote
14-02-2007, 09:27:58
PV5150
Excellent review as usual mate. The 680i's are toasty little sods for sure, and it's a pity that abit didn't even provide some form of active cooling to try and address the problem. Well done Quote
14-02-2007, 09:35:57
Rastalovich
Their answer, and a few other manufs answer, seems to be to add this ugly looking heatpipe structure to stuff.
Heatpipes are great, but I don`t personally like the idea of 2 or 3 of the hs being connected together.Quote
14-02-2007, 09:38:11
FarFarAway
2 or 3 connected together is fine, but that needs active cooling to work okQuote
14-02-2007, 10:51:54
TJS
Great review, Kemp, thanks for doing it as I was thinking of grabbing one. Now for my thoughts...
DAMN DAMN DAMN! I think the 680i chipset is good but not the king, would really like to see the 975X (or updated chipset) that can support nVidia's 8800 series gpu's in SLI... and done by ABIT. ABIT boards look great, and with the exception of the EZ PLUG for added graphics power, I like their layouts; not to mention my AW9D was rock-solid, even using an E6600 @ 3.7GHz... my 680i mobo can't touch it, only solid at 3.4GHz or lower.
Like the EZ CMOS as well, no more dip-switch installations! (newer mobos don't have problems like the old mobos after a bad OC, but it's the thought that counts!)
I personally don't see all the fuss over the passive cooling for the NB/SB. My case uses 4 120mm fans on the side of the case, so I get a lot of extra cooling... not to mention the little fan that came with my mobo for the NB, so I don't have a heating problem. I think it works fine, even without the little fan made for the NB; on the other hand, an enthusiast board should give the user the option to remove the passive to add active (fan) cooling solutions. The only thing I wonder about is the need for pipes from SB--NB--PWM... do the pipes really do anything for the cooling?
TJSQuote
14-02-2007, 11:14:12
BUFF
Thorough review as always.
You might have mentioned that they definitely are actively working on an updated BIOS though?
you mean like http://www.abit-usa.com/news/2005/20050511.php ? Quote
14-02-2007, 11:28:52
FarFarAway
That's the µguru panel - felt it should have been included with this board - would have certainly been a welcome addition
And yes I was going to put that in, but must have missed it out (twast 2.30am). I'll add it nowQuote
14-02-2007, 11:40:10
BUFF
btw , I do believe that this is the world's first full published review of the IN9 32X MAX
edit: at least in English. Possibly done on a Japanese/Chinese site etc. where I would only be able to look at pretty pictures.Quote
14-02-2007, 12:09:15
JN
Oooh wasn't aware of that Come on Google, update that Index
Edit: And in that case - Digg ItQuote
14-02-2007, 12:22:35
Ares210
Very thorough review like always. Seems like a rock solid board, at stock
Dugg.Quote
14-02-2007, 12:45:02
NickS
Gotta love how 680i gets its butt kicked by 965/975
Great review Kempez. Awesome pictures, using your new camera I'm guessing? Quote
15-02-2007, 03:39:09
FarFarAway
It does in a way...although it seems that in gaming 680i pwns hard...and I'm not quite sure why (linkboost shouldn't work with an x1600Pro)
Thanks and yep with maaa new camera Quote
15-02-2007, 10:58:24
Praxis1452
only going to 440mhz max seems a bit low...Quote
15-02-2007, 10:59:49
FarFarAway
Agreed. I'm talking to abit about that now but the review got published 'cause they'd had over the 24hours to replyQuote
15-02-2007, 11:22:30
BUFF
I've seen a screenie at 525 on 1 of the betas plus it seems to be overclocking Kentsfields better than the Striker/eVGA.
P.S. I put a link to your review in [H]ardOCP's forum IN9 32X thread.Quote
15-02-2007, 11:28:14
FarFarAway
Just waiting to hear back from abit atm but I may give it another go on one of the beta's if they ask me too. May need a dedicated fan on the NB though as it's toasty: which I didn't do for the other boards (I hasten to add)
EDIT: abit said they've had 550FSB in the labsQuote
15-02-2007, 17:47:45
TJS
I'm inclined to believe that if the NB was cooled on the ABIT board like it is on the EVGA board it should do much better than 440FSB. I can't see ABIT putting out the smashing AW9D-MAX and then fall on their faces with the IN9 32X-MAX.
TJSQuote
15-02-2007, 17:56:23
FragTek
The AW9D-MAX does far from smash, I hated that board, and so did 90% of the other poor ripped off owners of it.Quote
15-02-2007, 20:00:05
TJS
Hey, Frag, mine worked like a charm... didn't know so many had problems (other than Herr Schmidt). I thought a lot of people were getting some pretty good clocks compared to the 680i (don't know too much about the RD600 yet).
TJSQuote
15-02-2007, 20:01:14
FarFarAway
The fact is though that the cooler gets very very hot Quote
15-02-2007, 20:17:37
NickS
Passive chipset heatsink + extremely hot running chipset = ? Quote
16-02-2007, 03:17:34
JN
I find all this passive heatpipe nonsense very annoying personally. It wouldn't surprise me if it's cheaper than adding a fan, and that's the reason so many manufacturers are taking it onboard.
They build a board for enthusiasts, but the first thing enthusiasts do is rip off the nb cooling and replace it with something else (something that isn't aluminium sprayed in a copper colour).Quote
16-02-2007, 03:19:21
FarFarAway
If only they would implement a decent 3rd party solution or even get a decent solution in-houseQuote
16-02-2007, 03:24:30
JN
Yep, something made out of copper with a fan on top. Not too much to ask really when you're paying over £200 for a motherboard.Quote
