Abit IN9 32x Max Intel Socket 775 Motherboard
Test results - 3DMark and Counter Strike Source
Search Reviews
3DMark05
3DMark05 is a benchmark that relies heavily upon DX 8 and DX 9 shader paths. 3DMark05 is very useful benchmark to give us numbers to compare systems. It does give a decent indicator of gaming performance, and includes a couple of CPU benchmarks. Being branded as a complete gamers board I was certainly interested in what the IN9 max could do here.
abit IN9 32x max 3dmark05
It seems that the IN9 Max really lives up to that gamers tag beating out all of our boards by a margain in this test.
3DMark06
3dMark06 is the latest in the benchmarking tests from Futuremark. It has a lot of DirectX 9.0c features such as HDR and use of Shader model 3.0.
abit in9 32x max 3dmark06
Again the IN9 Max really shows what an advantage the board seems to give in gaming-like situations.
Counter Strike: Source - 1024 x 768
Counter Strike: Source is a hugely popular online FPS game based on the Source engine by Valve. This will show what a typical gamer will play on their PC and is a great indication of real-world gaming performance as the engine is so scalable. Will the IN9 Max continue the gaming experience here too?
abit in9 32x max css 1024 x 768
The board seems to even out the gameplay in CSS making the frames more even and getting a fairly higher average framerate.
Counter Strike: Source - 1280 x 1024
I tested in a higher res for those who like more detail.
abit in9 32x max css 1280 x 1024
Again the IN9 Max came out ahead of the other boards by a fair margain: quite surprising considering that the other boards are closely matched.
After doing extensive game-testing with both the X1600Pro and 8800GTS in single card and SLI configuration it seems the board really does give a good framerate boost in games: for a motherboard on it's own. This quite surprised me and leaves me wondering what abit have been doing with the tweaking, apart from implementing nVidia's linkboost technology for the 8800 cards.
«Prev 1 2 3 4 5 6 7 8 9 Next»
14-02-2007, 08:41:40
FarFarAway
Top dollar...but is it a top board?
Take a look inside...click
World Exclusive!!! - Digg It
14-02-2007, 09:13:14
Rastalovich
Great review Kemp, nice bunch of packaging akin to the rocketboy type of stuffz. I do wish the µguru thing was more of a 5.25 bay thingy tbh. Last time I checked, retailers were ramming these devices down peoples throats for like £11 or so - which amazes me why u never had one in the box ?!?
I would hope these good results will boost a tad more after some bios revisions, board to board I`d expect this one to be a bit better than shown - but meh..
Kewl, I recognize some of those photos too
14-02-2007, 09:27:58
PV5150
Excellent review as usual mate. The 680i's are toasty little sods for sure, and it's a pity that abit didn't even provide some form of active cooling to try and address the problem. Well done
14-02-2007, 09:35:57
Rastalovich
Their answer, and a few other manufs answer, seems to be to add this ugly looking heatpipe structure to stuff.
Heatpipes are great, but I don`t personally like the idea of 2 or 3 of the hs being connected together.
14-02-2007, 09:38:11
FarFarAway
2 or 3 connected together is fine, but that needs active cooling to work ok
14-02-2007, 10:51:54
TJS
Great review, Kemp, thanks for doing it as I was thinking of grabbing one. Now for my thoughts...
DAMN DAMN DAMN! I think the 680i chipset is good but not the king, would really like to see the 975X (or updated chipset) that can support nVidia's 8800 series gpu's in SLI... and done by ABIT. ABIT boards look great, and with the exception of the EZ PLUG for added graphics power, I like their layouts; not to mention my AW9D was rock-solid, even using an E6600 @ 3.7GHz... my 680i mobo can't touch it, only solid at 3.4GHz or lower.
Like the EZ CMOS as well, no more dip-switch installations! (newer mobos don't have problems like the old mobos after a bad OC, but it's the thought that counts!)
I personally don't see all the fuss over the passive cooling for the NB/SB. My case uses 4 120mm fans on the side of the case, so I get a lot of extra cooling... not to mention the little fan that came with my mobo for the NB, so I don't have a heating problem. I think it works fine, even without the little fan made for the NB; on the other hand, an enthusiast board should give the user the option to remove the passive to add active (fan) cooling solutions. The only thing I wonder about is the need for pipes from SB--NB--PWM... do the pipes really do anything for the cooling?
TJS
14-02-2007, 11:14:12
BUFF
Thorough review as always.
You might have mentioned that they definitely are actively working on an updated BIOS though?
you mean like http://www.abit-usa.com/news/2005/20050511.php ?
14-02-2007, 11:28:52
FarFarAway
That's the µguru panel - felt it should have been included with this board - would have certainly been a welcome addition
And yes I was going to put that in, but must have missed it out (twast 2.30am). I'll add it now
14-02-2007, 11:40:10
BUFF
btw , I do believe that this is the world's first full published review of the IN9 32X MAX
edit: at least in English. Possibly done on a Japanese/Chinese site etc. where I would only be able to look at pretty pictures.
14-02-2007, 12:09:15
Jim
Oooh wasn't aware of that Come on Google, update that Index
Edit: And in that case - Digg It
14-02-2007, 12:22:35
Ares210
Very thorough review like always. Seems like a rock solid board, at stock
Dugg.
14-02-2007, 12:45:02
NickS
Gotta love how 680i gets its butt kicked by 965/975
Great review Kempez. Awesome pictures, using your new camera I'm guessing?
15-02-2007, 03:39:09
FarFarAway
It does in a way...although it seems that in gaming 680i pwns hard...and I'm not quite sure why (linkboost shouldn't work with an x1600Pro)
Thanks and yep with maaa new camera
15-02-2007, 10:58:24
Praxis1452
only going to 440mhz max seems a bit low...
15-02-2007, 10:59:49
FarFarAway
Agreed. I'm talking to abit about that now but the review got published 'cause they'd had over the 24hours to reply
15-02-2007, 11:22:30
BUFF
I've seen a screenie at 525 on 1 of the betas plus it seems to be overclocking Kentsfields better than the Striker/eVGA.
P.S. I put a link to your review in [H]ardOCP's forum IN9 32X thread.
15-02-2007, 11:28:14
FarFarAway
Just waiting to hear back from abit atm but I may give it another go on one of the beta's if they ask me too. May need a dedicated fan on the NB though as it's toasty: which I didn't do for the other boards (I hasten to add)
EDIT: abit said they've had 550FSB in the labs
15-02-2007, 17:47:45
TJS
I'm inclined to believe that if the NB was cooled on the ABIT board like it is on the EVGA board it should do much better than 440FSB. I can't see ABIT putting out the smashing AW9D-MAX and then fall on their faces with the IN9 32X-MAX.
TJS
15-02-2007, 17:56:23
FragTek
The AW9D-MAX does far from smash, I hated that board, and so did 90% of the other poor ripped off owners of it.
15-02-2007, 20:00:05
TJS
Hey, Frag, mine worked like a charm... didn't know so many had problems (other than Herr Schmidt). I thought a lot of people were getting some pretty good clocks compared to the 680i (don't know too much about the RD600 yet).
TJS
15-02-2007, 20:01:14
FarFarAway
The fact is though that the cooler gets very very hot
15-02-2007, 20:17:37
NickS
Passive chipset heatsink + extremely hot running chipset = ?
16-02-2007, 03:17:34
Jim
I find all this passive heatpipe nonsense very annoying personally. It wouldn't surprise me if it's cheaper than adding a fan, and that's the reason so many manufacturers are taking it onboard.
They build a board for enthusiasts, but the first thing enthusiasts do is rip off the nb cooling and replace it with something else (something that isn't aluminium sprayed in a copper colour).
16-02-2007, 03:19:21
FarFarAway
If only they would implement a decent 3rd party solution or even get a decent solution in-house
16-02-2007, 03:24:30
Jim
Yep, something made out of copper with a fan on top. Not too much to ask really when you're paying over £200 for a motherboard.
