Abit IN9 32x Max Intel Socket 775 Motherboard
Installation and Test Setup
Search Reviews
Installation
Installation of the abit IN9 32x Max was a fairly straight forward process with all of the connectors on the board being right at the edge of the board I had little wiring problems. The only slight problem of note was the molex at the bottom edge of the board causing an annoying extra wire. However nothing else was really too taxing.
abit in9 32x max installed abit in9 max installed
abit in9 32x max installed high
Board Setup
After installation and on first boot everything worked fine with no problems. Having taken a look around some forums it seems that this may be because both sets of RAM that I tested on the board are designed to run at low voltages and boot at 1.7v and above. However in my case the setup worked excellently and I had no issues booting properley when I setup the board.
For testing I setup a RAID 0 array on the board as a secondary array to the SATA primary OS drive and this also worked fine. I haven't had a change to test eSATA yet though.
Testing Setup and Notes
The following test setup was as following:
Core2Duo E6700 ES
abit IN9 32x Max Motherboard
1gb Mushkin HP2 6400 (4-4-4-10)
Sapphire X1600Pro
Hitachia Deskstar 7K160 SATA HDD
Sony DVD-Rom/CD-RW
Silverstone 560w ZEUS PSU
Silverstone TJ09 case
Note that to test that users would not have an issue with 8800 and 8800 SLI use on the board I also installed 1/2 8800GTS overclocked editions. No issues were found.
For comparison I used results from an earlier review by OC3D on the Intel D975XBX, the Abit AB9 Review, the AW9D max Review and the Asus P5B-E Plus Review
Testing
To test the motherboard I first ran it at stock using as stress test comprising of Orthos (dual Prime95), Folding @ Home running on both cores (set to idle priority) and RTHDRIBL running 1/2 screen. I let this run for 12hours to see how the board would fare.
The benches and tests used on the motherboard were:
Super PI 1m and 32m
SiSoft Sandra:
Processor Arithmatic
Procsssor Multemedia
Memory Bandwidth
Memory Latency
3DMark05 and 3DMark06 @ 1024 x 768 and 1280 x 1024
Counter Strike Source @ 1024 x 768 and 1280 x 1024
HD Tach
Cinebench:
CPU Rendering
OpenGL
For comparison I used the following:
- Silverstone Zeus 560w PSU
- XFX 7900GT GPU
- Kingston HyperX PC2-8500 (5-5-5-15)
- Stock Intel Cooler
- Intel Core 2 Duo E6700 (2.66ghz)
«Prev 1 2 3 4 5 6 7 8 9 Next»
14-02-2007, 08:41:40
FarFarAway
Top dollar...but is it a top board?
Take a look inside...click
World Exclusive!!! - Digg It
14-02-2007, 09:13:14
Rastalovich
Great review Kemp, nice bunch of packaging akin to the rocketboy type of stuffz. I do wish the µguru thing was more of a 5.25 bay thingy tbh. Last time I checked, retailers were ramming these devices down peoples throats for like £11 or so - which amazes me why u never had one in the box ?!?
I would hope these good results will boost a tad more after some bios revisions, board to board I`d expect this one to be a bit better than shown - but meh..
Kewl, I recognize some of those photos too
14-02-2007, 09:27:58
PV5150
Excellent review as usual mate. The 680i's are toasty little sods for sure, and it's a pity that abit didn't even provide some form of active cooling to try and address the problem. Well done
14-02-2007, 09:35:57
Rastalovich
Their answer, and a few other manufs answer, seems to be to add this ugly looking heatpipe structure to stuff.
Heatpipes are great, but I don`t personally like the idea of 2 or 3 of the hs being connected together.
14-02-2007, 09:38:11
FarFarAway
2 or 3 connected together is fine, but that needs active cooling to work ok
14-02-2007, 10:51:54
TJS
Great review, Kemp, thanks for doing it as I was thinking of grabbing one. Now for my thoughts...
DAMN DAMN DAMN! I think the 680i chipset is good but not the king, would really like to see the 975X (or updated chipset) that can support nVidia's 8800 series gpu's in SLI... and done by ABIT. ABIT boards look great, and with the exception of the EZ PLUG for added graphics power, I like their layouts; not to mention my AW9D was rock-solid, even using an E6600 @ 3.7GHz... my 680i mobo can't touch it, only solid at 3.4GHz or lower.
Like the EZ CMOS as well, no more dip-switch installations! (newer mobos don't have problems like the old mobos after a bad OC, but it's the thought that counts!)
I personally don't see all the fuss over the passive cooling for the NB/SB. My case uses 4 120mm fans on the side of the case, so I get a lot of extra cooling... not to mention the little fan that came with my mobo for the NB, so I don't have a heating problem. I think it works fine, even without the little fan made for the NB; on the other hand, an enthusiast board should give the user the option to remove the passive to add active (fan) cooling solutions. The only thing I wonder about is the need for pipes from SB--NB--PWM... do the pipes really do anything for the cooling?
TJS
14-02-2007, 11:14:12
BUFF
Thorough review as always.
You might have mentioned that they definitely are actively working on an updated BIOS though?
you mean like http://www.abit-usa.com/news/2005/20050511.php ?
14-02-2007, 11:28:52
FarFarAway
That's the µguru panel - felt it should have been included with this board - would have certainly been a welcome addition
And yes I was going to put that in, but must have missed it out (twast 2.30am). I'll add it now
14-02-2007, 11:40:10
BUFF
btw , I do believe that this is the world's first full published review of the IN9 32X MAX
edit: at least in English. Possibly done on a Japanese/Chinese site etc. where I would only be able to look at pretty pictures.
14-02-2007, 12:09:15
Jim
Oooh wasn't aware of that Come on Google, update that Index
Edit: And in that case - Digg It
14-02-2007, 12:22:35
Ares210
Very thorough review like always. Seems like a rock solid board, at stock
Dugg.
14-02-2007, 12:45:02
NickS
Gotta love how 680i gets its butt kicked by 965/975
Great review Kempez. Awesome pictures, using your new camera I'm guessing?
15-02-2007, 03:39:09
FarFarAway
It does in a way...although it seems that in gaming 680i pwns hard...and I'm not quite sure why (linkboost shouldn't work with an x1600Pro)
Thanks and yep with maaa new camera
15-02-2007, 10:58:24
Praxis1452
only going to 440mhz max seems a bit low...
15-02-2007, 10:59:49
FarFarAway
Agreed. I'm talking to abit about that now but the review got published 'cause they'd had over the 24hours to reply
15-02-2007, 11:22:30
BUFF
I've seen a screenie at 525 on 1 of the betas plus it seems to be overclocking Kentsfields better than the Striker/eVGA.
P.S. I put a link to your review in [H]ardOCP's forum IN9 32X thread.
15-02-2007, 11:28:14
FarFarAway
Just waiting to hear back from abit atm but I may give it another go on one of the beta's if they ask me too. May need a dedicated fan on the NB though as it's toasty: which I didn't do for the other boards (I hasten to add)
EDIT: abit said they've had 550FSB in the labs
15-02-2007, 17:47:45
TJS
I'm inclined to believe that if the NB was cooled on the ABIT board like it is on the EVGA board it should do much better than 440FSB. I can't see ABIT putting out the smashing AW9D-MAX and then fall on their faces with the IN9 32X-MAX.
TJS
15-02-2007, 17:56:23
FragTek
The AW9D-MAX does far from smash, I hated that board, and so did 90% of the other poor ripped off owners of it.
15-02-2007, 20:00:05
TJS
Hey, Frag, mine worked like a charm... didn't know so many had problems (other than Herr Schmidt). I thought a lot of people were getting some pretty good clocks compared to the 680i (don't know too much about the RD600 yet).
TJS
15-02-2007, 20:01:14
FarFarAway
The fact is though that the cooler gets very very hot
15-02-2007, 20:17:37
NickS
Passive chipset heatsink + extremely hot running chipset = ?
16-02-2007, 03:17:34
Jim
I find all this passive heatpipe nonsense very annoying personally. It wouldn't surprise me if it's cheaper than adding a fan, and that's the reason so many manufacturers are taking it onboard.
They build a board for enthusiasts, but the first thing enthusiasts do is rip off the nb cooling and replace it with something else (something that isn't aluminium sprayed in a copper colour).
16-02-2007, 03:19:21
FarFarAway
If only they would implement a decent 3rd party solution or even get a decent solution in-house
16-02-2007, 03:24:30
Jim
Yep, something made out of copper with a fan on top. Not too much to ask really when you're paying over £200 for a motherboard.
