Abit IN9 32x Max Intel Socket 775 Motherboard
I/O, BIOS and Specification
Search Reviews
IO Connectors
The backplate IO on the abit IN9 32x Max looks pretty complete for a modern board standards.
abit in9 32x max
With:
* PS/2 mouse and keyboard ports
* SP-Dif Optical Connector
* 5.1 analogue sound outputs
* Dual nVidia Gigabit LAN ports
* 4 x USB 2.0 Ports
* 2 x eSATA ports
There is a very comprehensive feel about the IO panel on the IN9 32x Max.
Coming onto the onboard Audio: it is very good. abit include a high-def 7.1 audio chip supporting DTS and Dolby Digital Live. Notice also that a HDMI motherboard audio header is included on the board. The audio is good quality, although enthusiasts are likely to go for a discrete solution still.
Add to this the "EZ CMOS" reset switch and you have a very complete backplate lineup, worthy of a top end board like this.
BIOS
The BIOS on the abit IN9 32x Max is very comprehensive in it's options. The enthusiast is certainly catered for 100% with a plethora of FSB, memory and voltage adjustment. It is based on the Phoenix Award BIOS.
abit in9 32x max bios
As the BIOS is so comprehensive I will give a brief rundown of what's on offer as far as extra BIOS features.
Memory Timings
The memory timings on offer are pretty decent. With the normal 4 timings easily changeable, abit have added a couple of extras:
abit in9 32x max memory timings
As ou can see: setting manual means that you can set tCL (CAS), tRCD, tRP and tRAS as well as setting 1T or 2T for the Command Per Clock. There's a big performance boost in 1T so I would recommend using this if you can. The tRRD, tRC, tWR, tWTR and tREF are also changeable.
Overclocking Adjustments
abit provide a superb range of overclocking adjustments in their µGuru Utility in the BIOS.
The option to link or unlink the CPU and the memory is excellent, although they do not seem to be totally independent of each other.
abit in9 32x max cpu linking abit in9 32x max fsb
abit in9 32x max pci
The option to set the Multiplier is there as standard in the BIOS and goes up a 3000MHz (quad pumped), 750 actual. I found this a bit of a pain as you have to divide it by 4 to get the actual FSB which then gets multiplied by the multiplier. However 750MHz FSB is something I haven't seen yet on any forum (I'm never one to say it will never happen).
The PCI clocks can be set separately from each other which is a great option allowing for more control over your system.
Voltage Adjustment
Almost the most important bit of an overclockers BIOS, voltage adjustment is crucial on how far a board can go.
abit in9 32x max voltages
Showing this screen on it's own is a must I feel...1.85v on the CPU is for those of us crazy enough to have some serious cooling.
abit in9 32x max ddr voltage abit in9 32x max cpu vt
abit in9 max 32x ddr2 v abit in9 32x max HT volts
abit in9 32x max nb volts
3v+ on the RAM is plenty to play with and adjusting the CPU VTT and SB voltage has some good adjustments too. I though abit could have given the NorthBridge voltages a little bit more as 1.6 won't be enough for extreme overclocks.
EQ and temperature monitoring
abit's µGuru provides nice temperature and voltage monitoring monitoring in the BIOS, although I am not keen on the abit µGuru panel in windows which actually read approximately 5-7°C lower than CoreTemp did (a program hailed by overclockers as the best software temperature program).
That aside there is plenty of fan adjustment to be done in the BIOS and will keep you happy should you want your fans throttle in the BIOS.
It's also worth noting that the blue flashing lights that light up the area beneath the board can also be changed in the BIOS, allowing 5 settings and off...which is nice if it annoys you.
Specification (from abit's website)
# CPU
Designed for Intel LGA775 processors with 1333MHz FSB
Support Intel Core 2 Quad, Core 2 Duo & Extreme Edition, Pentium® D & Pentium®4 Processors
# 5-phase Digital PWM Designation provides high quality and efficient power
# Chipset Nvidia® nForce 680i SLI / NF590 SLI
# Memory
4 X 240-pin DIMM sockets support max. memory capacity 32GB
Supports Dual channel DDR2 800 Un-buffered / ECC or Non-ECC memory
# Graphics Two PCI-Express X16 slots support NVIDIA® Scalable Link Interface(SLI)
# LAN Dual NVIDIA® Gigabit Ethernet
# Timing and TCP/IP acceleration
# Audio
On board 7.1 CH HD Audio CODEC
Supports Jack Sensing and S/PDIF In/Out
HDMITM ready header (SPDIF header)
# Expansion Slots 2 x PCI-E X16, 1 x PCI-EX16(X8 bandwidth for X4, X8 and X16 devices), 1 x PCI-EX1, 2 x PC I
Internal I/O 1 x Floppy port, 1 x ATA 133 connector,
6 x SATA 3Gb/s connectors
3 x USB 2.0 headers, 2 x IEEE1394 headers
1 x FP-Audio header; 1x HDMITM header
# Quick Power & Reset Button
# Back Panel I/O 1 x PS/2 Keyboard, 1 x PS/2 Mouse
S/P DIF Out and IN, Clear CMOS switch
4 x USB 2.0, 2 x RJ-45 LAN,
2 x eSATA
# Serial ATA NVIDIA® 680i SLI: 6 x SATA 3Gb/s supports NVIDIA MediaShield RAID with SATA RAID 0/1/0+1/5 and JBOD
Silicon Image Sil3132: Support 2 ports eSATA
# IEEE 1394 Supports 2 Ports IEEE 1394 at 400Mb/s transfer rate
# Form Factor ATX form factor 305 x 245mm
# PCB Color: Black
# abit Engineered abit µGuruTM Technology
abit Silent OTESTM Technology
100% Japan capacitors
100% Low ESR and high ripple conductive polymer aluminum solid capacitor
Digital PWM
EZ switch for Clearing the CMOS
On-board LED Lighting
«Prev 1 2 3 4 5 6 7 8 9 Next»
14-02-2007, 08:41:40
FarFarAway
Top dollar...but is it a top board?
Take a look inside...click
World Exclusive!!! - Digg It
14-02-2007, 09:13:14
Rastalovich
Great review Kemp, nice bunch of packaging akin to the rocketboy type of stuffz. I do wish the µguru thing was more of a 5.25 bay thingy tbh. Last time I checked, retailers were ramming these devices down peoples throats for like £11 or so - which amazes me why u never had one in the box ?!?
I would hope these good results will boost a tad more after some bios revisions, board to board I`d expect this one to be a bit better than shown - but meh..
Kewl, I recognize some of those photos too
14-02-2007, 09:27:58
PV5150
Excellent review as usual mate. The 680i's are toasty little sods for sure, and it's a pity that abit didn't even provide some form of active cooling to try and address the problem. Well done
14-02-2007, 09:35:57
Rastalovich
Their answer, and a few other manufs answer, seems to be to add this ugly looking heatpipe structure to stuff.
Heatpipes are great, but I don`t personally like the idea of 2 or 3 of the hs being connected together.
14-02-2007, 09:38:11
FarFarAway
2 or 3 connected together is fine, but that needs active cooling to work ok
14-02-2007, 10:51:54
TJS
Great review, Kemp, thanks for doing it as I was thinking of grabbing one. Now for my thoughts...
DAMN DAMN DAMN! I think the 680i chipset is good but not the king, would really like to see the 975X (or updated chipset) that can support nVidia's 8800 series gpu's in SLI... and done by ABIT. ABIT boards look great, and with the exception of the EZ PLUG for added graphics power, I like their layouts; not to mention my AW9D was rock-solid, even using an E6600 @ 3.7GHz... my 680i mobo can't touch it, only solid at 3.4GHz or lower.
Like the EZ CMOS as well, no more dip-switch installations! (newer mobos don't have problems like the old mobos after a bad OC, but it's the thought that counts!)
I personally don't see all the fuss over the passive cooling for the NB/SB. My case uses 4 120mm fans on the side of the case, so I get a lot of extra cooling... not to mention the little fan that came with my mobo for the NB, so I don't have a heating problem. I think it works fine, even without the little fan made for the NB; on the other hand, an enthusiast board should give the user the option to remove the passive to add active (fan) cooling solutions. The only thing I wonder about is the need for pipes from SB--NB--PWM... do the pipes really do anything for the cooling?
TJS
14-02-2007, 11:14:12
BUFF
Thorough review as always.
You might have mentioned that they definitely are actively working on an updated BIOS though?
you mean like http://www.abit-usa.com/news/2005/20050511.php ?
14-02-2007, 11:28:52
FarFarAway
That's the µguru panel - felt it should have been included with this board - would have certainly been a welcome addition
And yes I was going to put that in, but must have missed it out (twast 2.30am). I'll add it now
14-02-2007, 11:40:10
BUFF
btw , I do believe that this is the world's first full published review of the IN9 32X MAX
edit: at least in English. Possibly done on a Japanese/Chinese site etc. where I would only be able to look at pretty pictures.
14-02-2007, 12:09:15
Jim
Oooh wasn't aware of that Come on Google, update that Index
Edit: And in that case - Digg It
14-02-2007, 12:22:35
Ares210
Very thorough review like always. Seems like a rock solid board, at stock
Dugg.
14-02-2007, 12:45:02
NickS
Gotta love how 680i gets its butt kicked by 965/975
Great review Kempez. Awesome pictures, using your new camera I'm guessing?
15-02-2007, 03:39:09
FarFarAway
It does in a way...although it seems that in gaming 680i pwns hard...and I'm not quite sure why (linkboost shouldn't work with an x1600Pro)
Thanks and yep with maaa new camera
15-02-2007, 10:58:24
Praxis1452
only going to 440mhz max seems a bit low...
15-02-2007, 10:59:49
FarFarAway
Agreed. I'm talking to abit about that now but the review got published 'cause they'd had over the 24hours to reply
15-02-2007, 11:22:30
BUFF
I've seen a screenie at 525 on 1 of the betas plus it seems to be overclocking Kentsfields better than the Striker/eVGA.
P.S. I put a link to your review in [H]ardOCP's forum IN9 32X thread.
15-02-2007, 11:28:14
FarFarAway
Just waiting to hear back from abit atm but I may give it another go on one of the beta's if they ask me too. May need a dedicated fan on the NB though as it's toasty: which I didn't do for the other boards (I hasten to add)
EDIT: abit said they've had 550FSB in the labs
15-02-2007, 17:47:45
TJS
I'm inclined to believe that if the NB was cooled on the ABIT board like it is on the EVGA board it should do much better than 440FSB. I can't see ABIT putting out the smashing AW9D-MAX and then fall on their faces with the IN9 32X-MAX.
TJS
15-02-2007, 17:56:23
FragTek
The AW9D-MAX does far from smash, I hated that board, and so did 90% of the other poor ripped off owners of it.
15-02-2007, 20:00:05
TJS
Hey, Frag, mine worked like a charm... didn't know so many had problems (other than Herr Schmidt). I thought a lot of people were getting some pretty good clocks compared to the 680i (don't know too much about the RD600 yet).
TJS
15-02-2007, 20:01:14
FarFarAway
The fact is though that the cooler gets very very hot
15-02-2007, 20:17:37
NickS
Passive chipset heatsink + extremely hot running chipset = ?
16-02-2007, 03:17:34
Jim
I find all this passive heatpipe nonsense very annoying personally. It wouldn't surprise me if it's cheaper than adding a fan, and that's the reason so many manufacturers are taking it onboard.
They build a board for enthusiasts, but the first thing enthusiasts do is rip off the nb cooling and replace it with something else (something that isn't aluminium sprayed in a copper colour).
16-02-2007, 03:19:21
FarFarAway
If only they would implement a decent 3rd party solution or even get a decent solution in-house
16-02-2007, 03:24:30
Jim
Yep, something made out of copper with a fan on top. Not too much to ask really when you're paying over £200 for a motherboard.
