Abit IN9 32x Max Intel Socket 775 Motherboard
Close Look - abit IN9 32x Max Socket 775 Intel Motherboard
Search Reviews
The board itself
Now lets take a good look at how the board is layed out and see if we like it.
abit in9 32x max name
First of all the PCB is black which is a great start as to me this is far more aesthetically pleasing than any other mainboard colour.
abit in9 max full pic abit in9 max full pic 2
Taking a long hard look at the layout shows that there is very little that abit have put in the "wrong" place. The socket area has a lot of clearance with not a cap in sight to get in the way. The 90° rotated SATA and IDE connectors are excellent and everything appears to be where it should be - around the edge of the board. Perhaps those who want to use SLI with high-end cards won't be happy with the lack of accessible PCI slots, but I feel that abit have done very well in squeezing in two.
One thing I would like more motherboards to do would be to lose the PCI-e 1x slot above the PCI-e x16 slot, although on this board your GPU would be touching the heatsink.
Coming on to the heatsink: it gets very hot. My temp sensors were screaming at me that when overclocking I was hitting 80-90°C and above at full load. Pretty high stuff really for a board that isn't supplied with a fan (although mounting brackets are included). I think abit should address this if they ever decide on a hardware revision as usually their heatpipe coolers are excellent, the simple and cheap inclusion of a fan for the NorthBridge like Asus have done in the past would be fine to keep those temperatures down.
abit in9 max capacitors
The board has high-quality solid Japanese capacitors throughout, great for stability.
abit in9 32x max ddr2 slots
The DDR2 slots are far enough away from the CPU area that you should be able to get a rather large heatsink and tall DDR2 on-board without too much hassle. Here we also see one of the power phases, a couple of 90° and standard SATA ports and the ATX 24pin power connector all at the edge of the board.
abit in9 32x max socket area abit in9 32x max cpu
As we move on to the socket area we notice that the board has excellent clearance. The only slightly tight part of the board is around the PWM heatsink where very large coolers may possibly butt up against the boards heatsink. All in all I would say most cooling configurations should easily fit on the board with no problems.
abit in9 32x max pci-e slots
Here we see that abit have chosen to go with three PCI-e slots along with a couple of PCI-e x1 slots and 2 PCI slots too. This is certainly squeezing in a lot onto a board and gives the consumer a good deal of choice. The inclusion of the PCI-e x1 WiFi card means that that top slot need not go unused, good news for those who are into their Wireless. Once again we see that abit has taken every care to get everything in the right position at the edge of the board.
abit in9 32x max power/reset onboard
An onboard power and reset switch has been chosen for the board, meaning that those into benchmarking out of the case will be very happy. The µGuru external panel is supported on the IN9 Max, although sadly not included. Also note that the CMOS battery is in a great place for those times when the board really doesn't want to reset...not that I have had to use it at all on this board, which is a very good thing.
abit in9 max in close abiot in9 max close up
Above are a couple of gratuitious shots of the motherboard showcasing the µGuru chip and the 90° SATA connectors, as well as the standard CMOS reset jumper on the far left of the second picture.
abit in9 32x max ez cmos
Another excellent feature of the board is the "EZ CMOS" reset switch. The board actually usually allows you to reboot straight into the BIOS to change settings if you've found a bad overclock, but this CMOS switch on the rear I/O panel is a lifesaver. No more opening the case up and having a fun time fiddling around with a small jumper: power down totally and flick this switch and the CMOS memory gets reset. This is a great feature and yes: it does actually work.
Board setup final thoughts
The board is incredibly well laid out and it's hard to list any of the very minor niggles with layout I found as an actual problem. I think that abit have done an incredible job with the IN9 32x Max board layout which will be very hard to match indeed.
«Prev 1 2 3 4 5 6 7 8 9 Next»
14-02-2007, 08:41:40
FarFarAway
Top dollar...but is it a top board?
Take a look inside...click
World Exclusive!!! - Digg It
14-02-2007, 09:13:14
Rastalovich
Great review Kemp, nice bunch of packaging akin to the rocketboy type of stuffz. I do wish the µguru thing was more of a 5.25 bay thingy tbh. Last time I checked, retailers were ramming these devices down peoples throats for like £11 or so - which amazes me why u never had one in the box ?!?
I would hope these good results will boost a tad more after some bios revisions, board to board I`d expect this one to be a bit better than shown - but meh..
Kewl, I recognize some of those photos too
14-02-2007, 09:27:58
PV5150
Excellent review as usual mate. The 680i's are toasty little sods for sure, and it's a pity that abit didn't even provide some form of active cooling to try and address the problem. Well done
14-02-2007, 09:35:57
Rastalovich
Their answer, and a few other manufs answer, seems to be to add this ugly looking heatpipe structure to stuff.
Heatpipes are great, but I don`t personally like the idea of 2 or 3 of the hs being connected together.
14-02-2007, 09:38:11
FarFarAway
2 or 3 connected together is fine, but that needs active cooling to work ok
14-02-2007, 10:51:54
TJS
Great review, Kemp, thanks for doing it as I was thinking of grabbing one. Now for my thoughts...
DAMN DAMN DAMN! I think the 680i chipset is good but not the king, would really like to see the 975X (or updated chipset) that can support nVidia's 8800 series gpu's in SLI... and done by ABIT. ABIT boards look great, and with the exception of the EZ PLUG for added graphics power, I like their layouts; not to mention my AW9D was rock-solid, even using an E6600 @ 3.7GHz... my 680i mobo can't touch it, only solid at 3.4GHz or lower.
Like the EZ CMOS as well, no more dip-switch installations! (newer mobos don't have problems like the old mobos after a bad OC, but it's the thought that counts!)
I personally don't see all the fuss over the passive cooling for the NB/SB. My case uses 4 120mm fans on the side of the case, so I get a lot of extra cooling... not to mention the little fan that came with my mobo for the NB, so I don't have a heating problem. I think it works fine, even without the little fan made for the NB; on the other hand, an enthusiast board should give the user the option to remove the passive to add active (fan) cooling solutions. The only thing I wonder about is the need for pipes from SB--NB--PWM... do the pipes really do anything for the cooling?
TJS
14-02-2007, 11:14:12
BUFF
Thorough review as always.
You might have mentioned that they definitely are actively working on an updated BIOS though?
you mean like http://www.abit-usa.com/news/2005/20050511.php ?
14-02-2007, 11:28:52
FarFarAway
That's the µguru panel - felt it should have been included with this board - would have certainly been a welcome addition
And yes I was going to put that in, but must have missed it out (twast 2.30am). I'll add it now
14-02-2007, 11:40:10
BUFF
btw , I do believe that this is the world's first full published review of the IN9 32X MAX
edit: at least in English. Possibly done on a Japanese/Chinese site etc. where I would only be able to look at pretty pictures.
14-02-2007, 12:09:15
Jim
Oooh wasn't aware of that Come on Google, update that Index
Edit: And in that case - Digg It
14-02-2007, 12:22:35
Ares210
Very thorough review like always. Seems like a rock solid board, at stock
Dugg.
14-02-2007, 12:45:02
NickS
Gotta love how 680i gets its butt kicked by 965/975
Great review Kempez. Awesome pictures, using your new camera I'm guessing?
15-02-2007, 03:39:09
FarFarAway
It does in a way...although it seems that in gaming 680i pwns hard...and I'm not quite sure why (linkboost shouldn't work with an x1600Pro)
Thanks and yep with maaa new camera
15-02-2007, 10:58:24
Praxis1452
only going to 440mhz max seems a bit low...
15-02-2007, 10:59:49
FarFarAway
Agreed. I'm talking to abit about that now but the review got published 'cause they'd had over the 24hours to reply
15-02-2007, 11:22:30
BUFF
I've seen a screenie at 525 on 1 of the betas plus it seems to be overclocking Kentsfields better than the Striker/eVGA.
P.S. I put a link to your review in [H]ardOCP's forum IN9 32X thread.
15-02-2007, 11:28:14
FarFarAway
Just waiting to hear back from abit atm but I may give it another go on one of the beta's if they ask me too. May need a dedicated fan on the NB though as it's toasty: which I didn't do for the other boards (I hasten to add)
EDIT: abit said they've had 550FSB in the labs
15-02-2007, 17:47:45
TJS
I'm inclined to believe that if the NB was cooled on the ABIT board like it is on the EVGA board it should do much better than 440FSB. I can't see ABIT putting out the smashing AW9D-MAX and then fall on their faces with the IN9 32X-MAX.
TJS
15-02-2007, 17:56:23
FragTek
The AW9D-MAX does far from smash, I hated that board, and so did 90% of the other poor ripped off owners of it.
15-02-2007, 20:00:05
TJS
Hey, Frag, mine worked like a charm... didn't know so many had problems (other than Herr Schmidt). I thought a lot of people were getting some pretty good clocks compared to the 680i (don't know too much about the RD600 yet).
TJS
15-02-2007, 20:01:14
FarFarAway
The fact is though that the cooler gets very very hot
15-02-2007, 20:17:37
NickS
Passive chipset heatsink + extremely hot running chipset = ?
16-02-2007, 03:17:34
Jim
I find all this passive heatpipe nonsense very annoying personally. It wouldn't surprise me if it's cheaper than adding a fan, and that's the reason so many manufacturers are taking it onboard.
They build a board for enthusiasts, but the first thing enthusiasts do is rip off the nb cooling and replace it with something else (something that isn't aluminium sprayed in a copper colour).
16-02-2007, 03:19:21
FarFarAway
If only they would implement a decent 3rd party solution or even get a decent solution in-house
16-02-2007, 03:24:30
Jim
Yep, something made out of copper with a fan on top. Not too much to ask really when you're paying over £200 for a motherboard.
