XSPC Raystorm 750 EX240 Watercooling Kit Review
Search Reviews
This is the second XSPC kit we've looked at here at OC3D, and it has to be said we continue to be impressed.  with the exception of coolant XSPC have included absolutely everything you need to assemble not just a basic water cooling set up, but one with style, substance, and a little bit of bling.  Each of the components used is strong in it's own right, from the classic X20 750 twin bay reservoir with integral pump and interchangeable face plates, through the new EX240 low profile radiator from which the kit gets it name, all the way to the stunning Raystorm CPU water-block.  But XSPC don't stop at just providing you with  these components, they also provide LEDs to light up your work and all the fittings and attachments you could possibly want to get your rig "under water".
So XSPC on paper at least appear to have a winner on their hands.  But that's not where the story ends though is it?  Not at all.  This kit has to perform, and perform well to justify the outlay.
So does it?  Well look at those performance figures and tell me this kit isn't worth the money.  Ok, you're dropping nearly £150 on it, but each of the items is a quality piece of kit in it's own right, and as your experience and confidence grows you're most likely going to be able to re use elements in future builds and perhaps sell on the items you no longer require.  Unlike PC hardware, this stuff won't be redundant and old had in 2-3 years.  Yes there are a few WC kits in the rankings that beat it, but they don't beat it by much and have much larger radiators which are much less likely to fit into your rig, or at the very least take up valuable space or cause you to have to get the dremel out.
Lets take a step back and look at this again.  We have here a slimline 240mm Radiator that is able to pretty much match two other 360mm Radiators.  It gets to within 0.5 of a degree of the Swiftech H20 X20 (which is a pretty noisy bit of kit for the money), and even manages to get within 5 degrees of it's bigger older brother, the XSPC RS360.  That's no mean feat by any-ones standards.  And it manages all this with only 2 very quiet 1200rpm "stock" fans.
Whilst we're talking about noise, lets mention the X20 reservoir/pump combination.  This unit has received criticism in the past for being quite a noisy affair.  We have to say we experienced no such problems.  This may in some part be due to taking a little bit of time to make sure the reservoir is properly mounted and isolated with all the screws done up tightly rather than using the cases "tool-less" design to secure the unit in place.  It's also fair to say that although the supplied fans do a fantastic job at very low noise levels, We think the unit could be capable of even better performance figs should you choose to upgrade the fans.
Upgrade is also a key word when talking about this kit.  Ok so you've bought your kit, but a few months down the line you want to water-cool your GPU.  No problem, just buy your block of choice, a few fittings and add it into the loop.  An extra rad to help with the cooling?  Again no problem, just buy it and add it in.  Try doing that with a sealed system.
Lengthy conclusions are easier to write when the kit reviewed is bad, or at the very least in some way flawed.  Problem is, this XSPC kit is good, very good, which leaves me very little to write about in the way of criticism, and boy do I like to be critical when the need calls for it.  Ok so the price is a bit steep, but then if you're going to buy cheap water-cooling kit then you might as well not bother at all, stick to air and live the easy life.  So XSPC could have included instructions on how to assemble the whole kit down to the minutest detail, but researching how to do this and making your own decisions is something of a right of passage into the world of Water-cooling.  This might be water cooling, but there is no wet nurse.
We'd actually finished with this review and conclusion at this point but then thought we might go a little bit further asnd see how the XSPC kit compares to a custom loop.  So under exactly the same testing conditions the XSPC kit was put up against the following:  Watercool Heatkiller rev 3 Copper, Phobya G-changer v1.2 360 (3.120 double thickness radiator fitted with 3 of the mighty Scythe gentle typhoon 1850 fans), and the Laing DDC-1 + 18W pump with EK X res 140 Pump top.  So how did the XSPC kit perform.  Well i'm glad in some ways to say it was beaten, as I would have thrown the rest of my kit out of the window if it hadn't been, but it wasn't beaten by much, not much at all.  At the all important 4.4GHz at 1.45V test the custom loop returned a Delta T of 48.75, just 5.25 degrees cooler than the XSPC kit.  I think those figures speak for themselves, and leave me feeling nothing if not a little depressed.
In reviewing the equipment and components that come through our hands here at OC3D there are but a few items that stick out as genuinely great.  We're pleased to say the XSPC EX 240 watercooling kit is one of these items. The kit is currently on pre-order from Specialtech with stock dates expected around the end of July.
Thanks to SpecialTech for the kit on test today, you can discuss your thoughts in the OC3D Forums.
«Prev 1 2 3 4 5 6 7 Next»
28-06-2012, 05:51:35
tinytomlogan
http://www.overclock3d.net/gfx/artic...052921351l.jpg
We all know of XSPC as being one of the main players in the watercooling world. The relaease of their new line of water cooling kits, based around the Raystorm CPU block and the new EX series Radiators, along with the classic X20 750 Pump/res combo's see's them make a bid for the throne.
Continue Reading
28-06-2012, 08:15:18
SieB
Not bad at all, worth the extra £50 over the H100 anyway.
28-06-2012, 12:40:28
airdeano
im glad to see the performance comparisons. undoubtably, the thin radiator is growing
and that manufacturers are also improving on their goods.
i know there is really no replacemnet for the standard radiator, but are these newer
revisions of thinner radiators "comparable" to the duties of the standard rads?
2°-5°? 10°? 15°?
with the flow of new cases and their bullet-pointed captions of support for water-cooling
really is making for some interesting questions in water-cooling. plus the crowds
are trying to make water-cooling the band-aid for either a bad over-clock or
wrong system design. i can see where the thin maybe in.. but for serious
usage of water-cooling for looks and function, i can not see the standard
radiator being replaced for the proper way to water-cool a system.
airdeano
28-06-2012, 17:04:15
Master&Puppet
Fantastic results again from XSPC. Some people really hate the idea of "pre-made custom kits" but XSPC have been on to a winner for a good while now and I'm impressed to see that this 240 rad has come so close to the old RS360.
I was an owner of a RS360 kit for a good while as my first WC kit and I couldn't have been any happier. This does the same thing in a smaller package.
For the record I had absolutely no issue with the 750 pump either. For 6 months it ran perfectly and silently. If people are getting noise it's because they are surely failing to bleed properly, or mounting the res poorly. Highly recommended.
28-06-2012, 17:11:27
airdeano
10-4 'dat...
airdeano
28-06-2012, 19:06:40
WillSK
This looks great! definitely the kind of thing i'd wanna try when i first venture into water cooling. I wonder if it'd fit well in a 600T i'll admit i get a bit confused about radiator sizes i.e 240 vs 360 is it the thickness?
Sorry to sound dumb
28-06-2012, 19:12:08
Josh Weston
Sorry to sound dumb
A 360mm rad uses 3x120mm fans - it's the length of the rad.
Rads are also rated in their thickness, i.e. 30mm, 60mm, 80mm
It doesn't matter how thick the rad is, it shall still be, more or less, the same length.
You can get rads that use 120mm fans, 140mm fans and 180mm and 200mm+ fans too
28-06-2012, 19:13:30
WillSK
Perfect! thank you
28-06-2012, 21:27:14
arnzzz
This kits close to £300 over at specialtech, little bit more than the H100
still i know which id prefer
28-06-2012, 23:03:49
airdeano
had you looked here:
http://www.youtube.com/watch?v=jdoW6LFOOd8&feature=plcp
this is Toms 600T water cooling guide....
airdeano
here's the specialtech link for ex240 "raystorm" @ £149.99
http://specialtech.co.uk/spshop/customer/XSPC-Raystorm-750-EX240-WaterCooling-Kit--EX-Series-Kit-pid-16244.html
you might be figuring the D5 RX360 @ £289..
airdeano
