XSPC Raystorm 750 EX240 Watercooling Kit Review
Performance and testing
Published: 28th June 2012 | Source: XSPC | Price: £149.99 |
To provide continuity the test set up is as always
Gigabyte UD3R V2
Intel i7 950 @ 4GHz 1.25v & 1.35v
Mushkin Radioactive 2000MHz
HIS 6850
Cooler Master Storm Trooper
Corsair AX750w
For the first test we set our i7-950 overclocked to 200x20 @ 1.25v for a clock speed of 4.0GHz. We allow the system to idle for 30 minutes and then run Prime95 'maximum heat maximum stress' setting for a further 30 minutes.
After 30 minutes we note the temperatures of all cores and the ambient temperature of the room. An average of all cores is taken, then the ambient temperature is removed from this figure and this gives us the delta temperature. Delta is the temperature difference above ambient which is a truer reflection of the heat-sink performance rather than mere maximum figures. Testing in an Igloo or the Sahara would give vastly different maximum temperatures, yet the Delta could be the same.
The second test follows all steps from above but with a 200x21 @ 1.35v for 4.2GHz overclock, the extra voltage in this test allows us to see if the heat-sink can cope when extreme loads and overclocks are applied
The last test is at 4.4GHz, 200x22 @ 1.45v and is an extreme test that only extreme coolers will ever pass. Any cooler in this graph is a one of the elite few that has the cooling ability to dissipate the heat created during this grueling test.
and that manufacturers are also improving on their goods.
i know there is really no replacemnet for the standard radiator, but are these newer
revisions of thinner radiators "comparable" to the duties of the standard rads?
2°-5°? 10°? 15°?
with the flow of new cases and their bullet-pointed captions of support for water-cooling
really is making for some interesting questions in water-cooling. plus the crowds
are trying to make water-cooling the band-aid for either a bad over-clock or
wrong system design. i can see where the thin maybe in.. but for serious
usage of water-cooling for looks and function, i can not see the standard
radiator being replaced for the proper way to water-cool a system.
airdeano
I was an owner of a RS360 kit for a good while as my first WC kit and I couldn't have been any happier. This does the same thing in a smaller package.
For the record I had absolutely no issue with the 750 pump either. For 6 months it ran perfectly and silently. If people are getting noise it's because they are surely failing to bleed properly, or mounting the res poorly. Highly recommended.
Sorry to sound dumb
This looks great! definitely the kind of thing i'd wanna try when i first venture into water cooling. I wonder if it'd fit well in a 600T i'll admit i get a bit confused about radiator sizes i.e 240 vs 360 is it the thickness?
Sorry to sound dumb |
Rads are also rated in their thickness, i.e. 30mm, 60mm, 80mm
It doesn't matter how thick the rad is, it shall still be, more or less, the same length.
You can get rads that use 120mm fans, 140mm fans and 180mm and 200mm+ fans too
A 360mm rad uses 3x120mm fans - it's the length of the rad.
Rads are also rated in their thickness, i.e. 30mm, 60mm, 80mm It doesn't matter how thick the rad is, it shall still be, more or less, the same length. You can get rads that use 120mm fans, 140mm fans and 180mm and 200mm+ fans too ![]() |
Perfect! thank you
http://www.youtube.com/watch?v=jdoW6LFOOd8&feature=plcp
this is Toms 600T water cooling guide....
airdeano
This kits close to £300 over at specialtech, little bit more than the H100
http://specialtech.co.uk/spshop/customer/XSPC-Raystorm-750-EX240-WaterCooling-Kit--EX-Series-Kit-pid-16244.html
you might be figuring the D5 RX360 @ £289..
airdeano
We all know of XSPC as being one of the main players in the watercooling world. The relaease of their new line of water cooling kits, based around the Raystorm CPU block and the new EX series Radiators, along with the classic X20 750 Pump/res combo's see's them make a bid for the throne.
Continue Reading
