XSPC Raystorm 750 EX240 Watercooling Kit Review
Up Close: Raystorm CPU Block
Published: 28th June 2012 | Source: XSPC | Price: £149.99 |
Seen by many as the successor to the RASA CPU water-block (which is a cracking waterblaock and still very much available), the Raystorm offers greater performance and increased CPU compatibility. (a separate AMD version is available so fret not). The Raystom comes in 3 parts, the main block, the acrylic mounting bracket, and the black aluminium trim. This trim can be easily removed should you not wish to use it, or perhaps, if you wish to change it's colour or appearance.
The copper face of the water block is finished to a very high sheen (believe it or not, the picture below right is taken with the protective plastic film still attached. There is decent spacing between the G1/4 threads to allow for the attachment of bulky compression fittings. The outer mounting bracket can be rotated though 90 degrees, not that this matters too much as each of the 4 sides has a hole for a 3mm LED.
and that manufacturers are also improving on their goods.
i know there is really no replacemnet for the standard radiator, but are these newer
revisions of thinner radiators "comparable" to the duties of the standard rads?
2°-5°? 10°? 15°?
with the flow of new cases and their bullet-pointed captions of support for water-cooling
really is making for some interesting questions in water-cooling. plus the crowds
are trying to make water-cooling the band-aid for either a bad over-clock or
wrong system design. i can see where the thin maybe in.. but for serious
usage of water-cooling for looks and function, i can not see the standard
radiator being replaced for the proper way to water-cool a system.
airdeano
I was an owner of a RS360 kit for a good while as my first WC kit and I couldn't have been any happier. This does the same thing in a smaller package.
For the record I had absolutely no issue with the 750 pump either. For 6 months it ran perfectly and silently. If people are getting noise it's because they are surely failing to bleed properly, or mounting the res poorly. Highly recommended.
Sorry to sound dumb
This looks great! definitely the kind of thing i'd wanna try when i first venture into water cooling. I wonder if it'd fit well in a 600T i'll admit i get a bit confused about radiator sizes i.e 240 vs 360 is it the thickness?
Sorry to sound dumb |
Rads are also rated in their thickness, i.e. 30mm, 60mm, 80mm
It doesn't matter how thick the rad is, it shall still be, more or less, the same length.
You can get rads that use 120mm fans, 140mm fans and 180mm and 200mm+ fans too
A 360mm rad uses 3x120mm fans - it's the length of the rad.
Rads are also rated in their thickness, i.e. 30mm, 60mm, 80mm It doesn't matter how thick the rad is, it shall still be, more or less, the same length. You can get rads that use 120mm fans, 140mm fans and 180mm and 200mm+ fans too ![]() |
Perfect! thank you
http://www.youtube.com/watch?v=jdoW6LFOOd8&feature=plcp
this is Toms 600T water cooling guide....
airdeano
This kits close to £300 over at specialtech, little bit more than the H100
http://specialtech.co.uk/spshop/customer/XSPC-Raystorm-750-EX240-WaterCooling-Kit--EX-Series-Kit-pid-16244.html
you might be figuring the D5 RX360 @ £289..
airdeano
We all know of XSPC as being one of the main players in the watercooling world. The relaease of their new line of water cooling kits, based around the Raystorm CPU block and the new EX series Radiators, along with the classic X20 750 Pump/res combo's see's them make a bid for the throne.
Continue Reading
