Xigmatek Utgard Review
Search Reviews
If you have managed to find OC3D then you are obviously a very wise person for starters, but by a process of elimination there is also a very large chance you would fall into the PC Enthusiast catergory. If such a badge is applicable there is no doubt in my mind that you will of heard of Xigmatek. Again, by a process of elimination, it is very likely your Xigmatek encounters have been restricted to the awesome fans they produce. Often companies try to diversify from what they are famed for and have a crack at the case market. One rather large company tried it recently and really should of stayed in bed the morning that project was notioned.
As ever here at OC3D towers we like to give every product that graces the office a clean sheet, and at least give it a chance to show us what it has to offer. Bring forth the Xigmatec Utgard which on face value has a lot of tidy features, but can it really deliver the goods?
Lets stop blathering as I doubt many of you even read this bit anyways and move onto the specifications:
Product Name UTGARD
 Product Number
 CPC-T90DB-U01~U03 / CPC-T90DB-U51~U53
 Dimension
 Utgard-Original / Window: 207(W) x 515(H) x 490(D) mm (8.1*20.3*19.3 inches)
 Utgard-Mesh: 222(W) x 515(H) x 490(D) mm (8.7*20.3*19.3 inches)
 Drive Bay
 5.25" External x 9 with tool-free holders.
 (Including one external 3.5" device adapter and one 4 in 3 3.5" HDD adapter.)
 Expansion Slot
 7 slots (tool-free)
 Motherboard Support
 ATX, Micro ATX (with easy black plant installation window)
 Power Supply
 Standard P/S2 ATX/EPS power supply unit
 1. Intake airflow hole with dust filter.
 2. Available for face upward and downward installation.
 3. Within anti-vibration rubber.
 Cooling System
 Air-cooling
 Front Fan:      Pre-installed 120mm white LED with orange blades x 1
                      (80/90/140mm fan is available)
 Rear Fan:       Pre-installed 120mm white LED with orange blades x 1
                      (80/90mm fan is available)
 Side Fan:       Utgard-Original: 80/90/120/140mm fan *1 (optional)
 Utgard-Mesh: 120mm fan *4 (optional)
                      200/220mm fan *1 (optional)
 Utgard-Window: Not available.
 Bottom Fan:   120/140mm fan x 1 (optional, with 14cm tool-free holder)
 Top Fan: Pre-installed 170mm white LED with orange blades x 1
                      (120/140mm fan x 2 are available)
 Fan Speed Control:
 Six fan speeds are adjustable synchronously by two knobs on top panel.
 Water-cooling
 Water pipe holes x 4 (with rubber cover)
 Available for 12cm*2 or 14cm*2 radiator (thickness under 46mm)
 I/O Panel
 Top Panel: Power On/Off switch, USB2.0 x 4, e-SATA x 2,
Lets move on to our first impressions of the case over the page
«Prev 1 2 3 Next»
01-04-2010, 05:32:01
tinytomlogan
So you have a £100 to spend on a case and it either has to have great airflow or support watercooling? You really need to be reading this review then!
Continue Reading
01-04-2010, 06:13:43
killablade
I've always liked Xigmatek. They make some quality products, and the Utgard is just another great product from Xigmatek!
01-04-2010, 06:43:44
rachaelbrian
We have recently brought home a Xigmatek and I tell you it is fabulous comprising of such excellent features and giving commendable results.
01-04-2010, 13:46:08
BloomerzUK
Tom, you just made my next purchase!
01-04-2010, 16:24:17
Ghosthud1
bye bye antec 1200.
01-04-2010, 17:14:34
thestepster
the midgards a great case and this looks to trump it in every way very hard decision what to choose for my next case!
01-04-2010, 18:17:45
ToeJam
truly shocked by this case, a step in the right direction and of course another brilliant review from ttl
01-04-2010, 21:02:21
Makol
that is a really nice case.
27-04-2010, 16:53:41
BloomerzUK
Ordered this from KustomPCs earlier today, should be here tomorrow! Will post piccars..
30-07-2010, 15:41:42
Fat Tony
I have just received this case and am having trouble fitting in a Asus P6X58D-E mobo ... it seems that the protusions on the motherboard (on the rear side) do not match the cut out on the case. Or is it me? I am a complete novice. Can anyone help?
30-07-2010, 16:22:56
AMDFTW
do the motherboard standoffs match the holes on the mobo?
30-07-2010, 16:49:57
tinytomlogan
You have to use the motherboard standoffs mate, you dont mount the board straight into the case...
30-07-2010, 19:07:15
Fat Tony
OK, please ignore me - new user error! I forgot to add the spacer screws!
Thanks for your help.
30-07-2010, 20:50:48
AMDFTW
hope it boots ok
27-10-2010, 08:25:18
streetgang
A really good case, Iv'e got the standard version with two side fans installed, should mention that the HDD drive caddy is fixed with two small black screws to the rear that are fairly well hidden, I spent 20 minutes trying to pull the damn thing out before I noticed lol, no mention of them in the manual, Hi to all btw
27-10-2010, 09:20:58
J0s3e
I've had this case for a while now, and what really annoys me, is that the front audio jack has reversed R/L channels. Whatever I do, I can not make it work properly. I found a temporary solution, though
http://img836.imageshack.us/img836/7416/dsc00051xg.jpg
However, I am going to receive some new goodies for my PC tomorrow, so I am going to have another look into it.
It's not the soundcard (Xonar DX), because it worked in another two cases just fine.
31-10-2010, 07:26:51
Telltale
I have the exact same problem with my Utgard, my solution was simply to use an extension cable from the port on my soudn card instead. It's very annoying though, let me know if you come up with a solution.
31-10-2010, 14:22:50
AlienALX
Get the solder iron out.
01-11-2010, 12:16:59
Heebs
Exactly, cut the wires and resolder. Done.
01-11-2010, 14:47:11
mayhem
Just ordered one for testing some fluids out. £63.00 from http://specialtech.co.uk mind you im all so getting them to add a window as well which will save me some time.
when i get the time im gonna mod the hell out of it.
01-11-2010, 14:51:47
tinytomlogan
They make a windowed version
01-11-2010, 15:18:41
mayhem
the window is £25 (inc Vat) from the cheapest shops but i got it hand made for £18.00 instead and its larger. Not in a x shape. .
02-11-2010, 07:46:40
Rastalovich
£65/£63 is crazy cheap.
08-11-2010, 18:07:38
mayhem
its is quite cheap but you'll notice it when you start getting to play with it.
on the top section on mine 3 stand off broke with in seconds. The metal is fairly thin on the side panels, how ever these are all minor things to be honest. Another problem though is the Fan spacing on the top for were you fit a rad are not correct they are not 15mm but 17mm how ever you can mess around a little and make it work quite well.
You need to be careful when moving it about as the plastics are a little on the flimsy side but alas what do u expect for the money.
I personally dont like the fans it came with as i found them to be quite low cfm with to much noise so i chucked in a couple of NZXT's which do the job better. How ever its not a complaint in any way cause getting 3 fans at this price is a bonus.
08-11-2010, 18:30:18
tinytomlogan
Didnt get a gold award from me for nothing!
08-11-2010, 18:40:56
AMDFTW
so can u justt fit 1 rad in it
08-11-2010, 18:44:50
mayhem
No if i played i could get a 2 x 120mm in the top, a 3 x 120mm in the front , 1 x 120mm in the bottom and 1 x 120mm on the back.
The reason why only 1 rad is fitted in atm is to check the efficiency of the fluid. As its not only cooling as over clocked CPU quite well but its all so a over clocked chip set and on-board GPU and that double rad with the fluid is handling it easily with out any problems. All so the fans are only running at 1/2 speed though out the whole system so its close to virtually quiet.
This pretty much proves that the case air flow is working very well with its windows side panel but with the 4 x 120mm side panel it would run even cooler.
as for the over clock on a £45 MB , CPU and Ram (thks to stephy for that) well this is it ->
http://valid.canardpc.com/show_oc.php?id=1470565
08-11-2010, 20:07:12
tinytomlogan
But that would look stupid wouldnt it
Also that wont be getting hot...... Its an AMD matey.
09-11-2010, 14:20:37
Jujumonkey
the review states that the xigmatek is the best sub 100 quid case available. Surely its not better than the cm 690 II advanced?? you can fit 2 liquid rads in that and its only 73 quid
09-11-2010, 14:36:34
tinytomlogan
We reviewed this before that came out. But technically you can get a 360mm rad in the front of the Utgard soooooo................
10-11-2010, 00:43:49
Aurus_OC
Wasn't there supposed to be a full tower coming from xigmatek sometime soon? Any news on that? But the utgard surely is a great case
28-11-2010, 10:46:36
Todd
Does it fit a D14? Really considering buying one now
28-11-2010, 11:11:43
AMDFTW
so is the advanced 2 better than the utgard?
28-11-2010, 11:55:35
tinytomlogan
I think a D14 should fit although I never tested it with one it was so long ago.
28-11-2010, 12:04:27
Todd
Thanks, mate. Will compare the sizes of the V8 used and the NH-D14. Your gran getting better?
28-11-2010, 12:08:37
tinytomlogan
Originally Posted by Todd View Post
I know it's probably asking too much but could you test-fit one for me if you've still got the Utgard around?
Your right it is asking too much
28-11-2010, 12:14:40
Todd
2 slow granddad, I edited it already Didn't mean to sound like an arse but now you've quoted me.. I sure hope it fits. Would CCL be willing for me to return it if it doesn't?
28-11-2010, 12:43:55
tinytomlogan
Not if youve used it It should be fine mate.
28-11-2010, 12:50:49
Todd
Thanks. You're too awesome
28-11-2010, 16:21:12
BloomerzUK
I've got one.. what do you need to know?
29-11-2010, 07:01:30
Todd
Does an NH-D14 fit inside. Size is 160 x 140 x 158mm ( H x W x D) .
12-01-2011, 21:08:36
bobkelso
I should have this case in the next week or so for £65 and the fact it has those fans included and the fan controllers sold it for me, I also think it's a good looking case getting the standard non windowed vers (may get the windowed side panel in the coming months). This is for my first pc build ever, making the jump to pc gaming (first ever gaming pc ) I can't wait to start the build rather excited. Anyway that is all oh and thanks for the review.
29-01-2011, 10:20:22
CSB30
Sounds like a good case. I had thought I found the case for me (The cooler master haf 932 black edition)
But I can not find it on any site. Any body help?
So possible the Xigmatek UTGARD (Window version) or the Cooler Master Haf-X will have to do.
But another good review TTL
29-01-2011, 10:47:16
CSB30
One more thought, when buying a new case should a USB3 be considered Vital/Necessary/nice to have?
29-01-2011, 10:48:23
CSB30
One more thought, when buying a new case should a USB3 (in the front panel)be considered Vital/Necessary/nice to have?
29-01-2011, 12:04:33
Zeals
Depends, for me it isn't because I don't have any USB3 devices, even than I don't mind going to the back of my case and plugging it in, since the rear fans illuminates that area
29-01-2011, 12:16:09
Aurus_OC
I would say nice to have. There aren't that many USB3 devices out there yet. So if you don't own one that you are going to carry with you and plug in and out of your computer daily, I wouldn't say it is necessary. Also remember most cases do not have the USB3 header as a connection, just a regular plug that you route to the back of your IO.
29-01-2011, 18:56:18
Tainted
I bought one of these a couple of weeks ago for my new build. Can't wait to get my rig setup in there, it looks like a great case for the money.
Possible build so far...
Case: Xiggy Utgard
Motherboard: Intel P55
CPU: i5 750 (possibly)
Cooler: Xiggy Thor's Hammer (Thanks Tom!)
GPU: HIS 5770 1gb (Again, cheers Tom!)
HDD: Samsung F3 1TB
PSU: Possibly a Corsair TX650
RAM: 4GB Mushkin RAM
I'm going for a nice black and orange theme to go with the inside of the case. I've got some orange SATA cables and I'm looking at some Xigmatek Orange Fans too, possibly some Orange LED's to set it off a little.
Should be nice.
Thanks again, TTL!
29-01-2011, 20:26:14
bobkelso
I've got mine sitting in my bedroom, and I ordered this aria bundle friday on a special offer couldn't resist I was gonna go amd but this being pre built is nice, knabbed my hdd and optical drive while I was there aswell. It's for my first build so it's nice knowing it's been tested and it's all working, I'll be getting the rest over the next 2-3 weeks then hopefully It will be smooth sailing when it's all set up.
29-01-2011, 21:54:56
Squirrel-666
i was looking at that case last year then i won it over at specialtech and used it for a bit not a bad lil case for the money. i recommend it
strangley enough i never used the fan controller lol
30-01-2011, 10:28:46
CSB30
30-01-2011, 10:29:04
CSB30
Thanks Guy’s your views are appreciated.
One thing I have noticed that lot of manufactures are stating/indicating size of motherboards-GPU’s the case will take. Note Xigmatek haven’t done that.
