Thermaltake Xaser VI Super Tower Chassis
Installation
Published: 26th November 2007 | Source: Thermaltake | Price: US$274.00 |
I'm happy to report that installing a system in to the Xaser VI Super Tower was dead easy and very quick. Especially with the inclusion of the tool-less features of the case. Whilst some of the metal edges of the case felt a little nippy, I did fail to draw blood. However I did encounter two small issues when installing my motherboard. First off the motherboard tray was missing one standoff hole on the outside edge. Due to me not having a tap and die kit I was unable to insert a threaded hole. Another QA issue here.
Secondly the tray also has two permanently fixed (riveted) standoffs on the rear edge of the case; one of which becomes a problem when using an ATX motherboard. Subsequently, because there isn't a mounting hole in that position on the motherboard, but exposed traces are on the reverse side, it can become a potential shorting issue. A simple 1/8" drill bit and my Makita battery drill solved the issue.
After the initial hiccups I'm pleased to say that I had my system up and running in just under an hour.
There are a couple of other things worth mentioning that I encountered during the installation phase of the review. Firstly, the IEEE 1394 cable and 2 x USB cables coming from the front panel are only just long enough. If your motherboard has the Firwire and USB headers situated further back towards the rear then you may run into problems. Thermaltake could add a couple of extra inches to the length and the problem would be alleviated.
Secondly, due to the increased height of the case, I found that the SATA plugs on my Antec PSU only just reached the HDD when using the top two bays in the HDD cage. As a result I had to use two strands of the loom to power 2 x SATA HDD's. Just something to think about!
I have included a couple of night shots too so you can see how well the case looks in the dark.
Let's head over the page to see how we're going to test the Xaser VI Super Tower...
Nice review as always Matt, still can't help but think that the case looks plasticy and tacky.
I would have considered buying it 2 years ago but no a chance now i've used a V2000 & a TJ07. Sorry TT but you just aint cutting it in my eyes.
Thanks Marcus. Yeah I agree...I love my TJ-07. Tt do target a specific market typically, and I believe that the Xaser VI will definitely appeal to many of the younger and budget conscious generation. Providing the price is right
I like all the functionality it provides, although to me it visually resembles a cheapo X-Blade chassis.
Originally Posted by name='duke'
...although to me it visually resembles a cheapo X-Blade chassis.
I bought a TT case for my first simply because it was black, in the sale from £80 to £20, wasn't particularly flashy and had lots of quiet fans and I didn't know any better
In all fairness it was a decent case and even though my current lili ended up costing £175 with the hole saw cuts and delivery it doesn't seem any better than my old TT, just more expensive - sure it's nice and I don't mind becasue I don't really have a budget...
I think TT designs are getting worse. That is an acheivement right there!
Yuk!
Looks like one of my old design tech projects when i was 12...
i had a tsunami dream, liked it, it did the job, but it was nothing spectacular
i recon this is the same,
it does what it says on the box, nothing more
the attempted cool look, just...no...tbh
Originally Posted by name='Mr. Smith'
LOL - waits for TT user/xblade owner to say heyyy!
lol.. it looks like a chavved up version of the stacker lol
Great review.
The looks aren`t an issue for me as I`d not buy one of these cases that are shrouded in plasticy-looking black/red/silver stuff.
But, if a client wanted one, I know the case is gonna be pretty easy to work in. Things like misplaced stand-offs can be worked around, imo, and are one of the minor things some case manufs can put in ur way during construction.
I`d like included in these reviews how the pci slot clips stand up under their own mechanism, and if they`re too weak for plugging in the likes of dvi cables - have the manufs put screw holes there. U know, the cards move too much when u go to plug stuff in/out.
Seems to me it`d make a solid disk server case too, but with the design, perhaps not the market they`re looking at.
Good to hear there are decent fans in there too. Otherwize people would be looking @ $20-$30 extra to replace them with quiet ones.
Don`t think it`s overly priced either, just not for me, but wouldn`t have sleepless nights if a client wanted one.
Mmm.. i like the sides, just says something about being 15
If i ever got that case, i would prbably have it WITHOUT the front door. As i dont like it's design with the 2 curvy silver bits reminding me of the muse masks.
I would also change it to red lighting o' course, as it just needs to be. Otherwise, nice looking case, but oooooverpriced. The armor is my port of call.
In all black, it could looks a little better perhaps, but damn is it ugly.. Seems pretty good on the features front mind
http://www.overclock3d.net/gfx/artic...121152988s.jpg
Linkage
