Thermaltake iFlash 12 120mm Fan
Published: 22nd April 2006 | Source: Thermaltake | Price: |
If you are looking for a high CFM fan with just a touch of 'bling' then these are the fans for you. They won't light up your case like other LED fans, but watching them is certainly more interesting.
Pro's
- High CFM
- Low Noise
- Funky light show!
Con's
- Won't light up your case.
- Black plastic casing is ugly.
Discuss this review in our Forums
After my recent review of the AC Ryan Blackfire range which scored a miserable 0, i thought it was time to look for an alternative. Enter the Thermaltake Iflash 12.
Those fans look pretty nice imo. Will these be given away ina draw anytime soon?
They are a nice looking fan mate, except for the black shroud you mentioned in the review, I think it detracts from the look. On page 4 (bottom left pic) it looks fairly bright where you tested these in your rig, did you check the fans in a more dimly lit area? Perhaps they may be ok and better suited in a dark LAN party. Great and professional review anyway mate...awesome
Those look pretty sweet, I need to replace a couple of loud fans in pc really.
