Thermaltake Big Typhoon
Performance Cont.
Search Reviews
Performance: Stock Fan, 120mm fan in hole
2.20 ghz, 1.40v core:
120mm fan in hole, 2.20 ghz, 1.40v idle 120mm fan in hole, 2.20 ghz, 1.40v load
2.87 ghz, 1.52v core:
120mm fan in hole, 2.87 ghz, 1.44v idle 120mm fan in hole, 2.87 ghz, 1.44v load
3.01 ghz, 1.52v core:
120mm fan in hole, 3.01 ghz, 1.52v idle 120mm fan in hole, 3.01 ghz, 1.52v load
Amazing! Adding the 120mm fan for a solid supply of fresh air seems to be very beneficial, dropping the temperature once again up to 4°C!
«Prev 1 2 3 4 5 6 7 8 9 Next»
23-04-2006, 06:56:19
WC Annihilus
Yes I've finally gotten it up. See how it performs here...
23-04-2006, 07:41:26
FragTek
Rumor has it that lapping the base on those babies is a must for optimal performance.
Great review mate!
23-04-2006, 08:30:46
Ham
Nice piece of writting WC. Puts everything bar the ninja to shame size wise i think...
23-04-2006, 08:32:25
WC Annihilus
Also possibly the Tuniq Tower. I'm debating whether to add results when switchin the fan to med speed Panaflo or not...
23-04-2006, 10:36:36
Raven
why not lap it and rerun the tests to se how big of a change it does ?
23-04-2006, 13:18:40
NickS
Nice review WC
Very thorough testing.
Nick
24-04-2006, 05:55:24
PV5150
Absolutely awesome review WC, you are to be congratulated. Your style was very fluid and the review very comprehensive. Perhaps, if possible, it'd be cool to get the BT lapped and then make a comparison. As per Raven's suggestion. It's definitely a beefy cooler, and worth a look for a well ventilated case
