Thermaltake Big Typhoon
Performance Cont.
Published: 20th April 2006 | Source: Fry's Electronics (Outpost.com) | Price: |
2.20 ghz, 1.4v core:
2.87 ghz, 1.44v core:
3.01 ghz, 1.52v core:
Wow, some major improvements here, up to 4°C! However, when I placed my hand by the hole, I felt very little air moving; it seems that the fan is not strong enough to fully utilize the available fresh air. That ready supply could be put to good use with the help of a 120mm fan and will probably make a difference. Let's find out shall we...
Yes I've finally gotten it up. See how it performs here...
Rumor has it that lapping the base on those babies is a must for optimal performance.
Great review mate!
Great review mate!
Nice piece of writting WC. Puts everything bar the ninja to shame size wise i think...
Also possibly the Tuniq Tower. I'm debating whether to add results when switchin the fan to med speed Panaflo or not...
why not lap it and rerun the tests to se how big of a change it does ?
Nice review WC
Very thorough testing.
Nick
Nick
Absolutely awesome review WC, you are to be congratulated. Your style was very fluid and the review very comprehensive. Perhaps, if possible, it'd be cool to get the BT lapped and then make a comparison. As per Raven's suggestion. It's definitely a beefy cooler, and worth a look for a well ventilated case
