Thermalright HR-05 Northbridge Cooler
Test Results
Published: 9th February 2007 | Source: SpecialTech | Price: |
As stated before for the idle temperatures I ran the PC 30minutes from startup and took the temperature at regular intervals for 30minutes. For the load temperature I ran Orthos on blend stress test for 30 minutes, then took the temperature at regular intervals for a further 30minutes.
This procss was repeated three times, as we do in all of our testing to ensure accuracy.
Results
The results were as follows. Please remember the stock cooler had an 80mm fan blowing directly onto it for the duration of the stock heatsink tests as the RD600 got too hot to have the stock cooler passive. Ambient was 22.7°C
The Thermalright performed 9°C better at idle than the stock cooler and a full 11°C better at load. Also bear in mind several factors:
* The RD600 North Bridge is a very hot chip (stock cooler runs at 65°C idle with no fan)
* The Thermalright HR-05 was a passive solution in the testing
* The North Bridge is right next to a very hot 8800GTX
This makes the results very impressive indeed in my opinion.
Update
I used a SilenX 80mm fan on the cooler and immediately the difference was very good. Ambient a slightly lower 22.3°C for the fan test, so factor this in when comparing.
Update
Nice review m8
Another EXCELLENT review. I was really surprised when I opened the box and saw how big mine was.
I also like how they have 2 versions (straight and offset)
Also like you pointed out it is beautifully made (especially compared to other finned Chipset coolers).
good review mate
it could of been better if you also tested it with a decent 70mm fan on it
cheers.
cheers.
Originally Posted by name='Raging'
good review mate
it could of been better if you also tested it with a decent 70mm fan on it cheers. |
good review mate
Originally Posted by name='ai_01'
awesome review as always kemp, we all know ur busy, would be pretty cool to see what temps would be with a fan on it.
Cheers lads
w00t!
...that looks awsome
...that looks awsomevery nice review! you should do a nb heatsink shootout between like 4 models and rule the best of the best.
Look at the drop in temp! Amazing!
Nice review Kemp!
Nice review Kemp!
quite a nice difference in temp,nice one
Read on...
