Thermalright HR-05 Northbridge Cooler
Thermalright HR-05 - Up Close and Specification
Search Reviews
Thermalright HR-05 - Up close
The HR-05 is built to the same solid standards that I had come to expect of Thermalright. Certainly handling the cooler gives you confidence in the build quality of it.
The cooler is very tall for a North Bridge cooler and you may have to beware of this if your case has a problem as far as height is concerned. However it does mean that it is very thin leaving a lot of space either side of it once installed.
thermalright hr05 cooler itself thermalright hr05 side view
The base of the HR-05 does not have a mirror finish but instead has a roughened appearence. This is very flat as I found out when I tested it with a plate of glass, so the contact should be good.
thermalright hr05 base
The base is copper plated with Nickel, like most Thermalright coolers. I have found that the Nickel plate does not affect performance much at all, but the most hardcore enthusiasts amoung us would perhaps lap it to get the 1°C improvement that it would give.
Overall the cooler is great looking and is pretty impressive once installed (see later pages).The build quality is top-notch and I was impressed by the quality of the welds on the heatpipes to the base.
Specifications and Features (taken from Thermalright )
Features:
* Passively cooled heatsink design for no-noise operation (70mm Fan optional)
* Proprietary through holes on fins for effiecient ventilation
* Soldered fins to copper base (nickel plated) to make effective contact
* Light weight and easy installation
Technical Spec.:
Dimension:L77.9 x W19(fin), W30(base)x H105 (mm), without fan
Weight:145g (heat sink only)
Optional FanAny 70x70x15mm fan
Motherboard Compatibility: Intel Pentium-4 LGA775 platform
ATI: Radeon Express 200
Intel: 975X, 955X, 945G, 945P, 945PL, 925X, 925XE, 915G, 915P, 865PE, 848P
nVidia: nForce4 SLI Intel Edition
SiS: SiS 656, SiS 661FX/964
VIA: P4M800, PT880 Ultra Intel Pentium-4 Socket 478 platformIntel: 865, 865G, 845, 845PE, 875
«Prev 1 2 3 4 5 Next»
08-02-2007, 20:01:43
FarFarAway
We take a look at this rather large passive heatpipe North Bridge Solution and see what's what
Read on...
08-02-2007, 20:49:22
NickS
Nice review m8
08-02-2007, 21:05:30
markkleb
Another EXCELLENT review. I was really surprised when I opened the box and saw how big mine was.
I also like how they have 2 versions (straight and offset)
Also like you pointed out it is beautifully made (especially compared to other finned Chipset coolers).
08-02-2007, 22:13:47
Raging
good review mate
it could of been better if you also tested it with a decent 70mm fan on it
cheers.
08-02-2007, 22:28:14
ai_01
Originally Posted by name='Raging'
good review mate
cheers.
awesome review as always kemp, we all know ur busy, would be pretty cool to see what temps would be with a fan on it.
08-02-2007, 22:41:49
FragTek
Thermalright spare no expense when creating their heatsinks, they are definitely of the highest quality without question.
09-02-2007, 04:20:20
FarFarAway
Yep so do I
Yep Thermalright make excellent products
good review mate
cheers.
I don't currently have one but if/when I do I'll update the review
As above
Cheers lads
23-02-2007, 07:17:22
FarFarAway
Right then guys you asked for it...
Click
23-02-2007, 07:43:50
ionicle
w00t! ...that looks awsome
23-02-2007, 07:56:08
FragTek
very nice review! you should do a nb heatsink shootout between like 4 models and rule the best of the best.
23-02-2007, 12:18:15
Toxcity
Look at the drop in temp! Amazing!
Nice review Kemp!
23-02-2007, 13:02:11
Raging
quite a nice difference in temp,nice one
