Thermalright HR-07 Trio Heatpipe Coolers
Search Reviews
Ask any enthusiast worth his salt which manufacturer makes the best air coolers and more often than not, the company that gets the honours is Thermalright. The all conquering Thermalright Ultra Extreme CPU air cooler was widely accepted to be the best CPU cooler for the s775 based motherboards. Along with the TRUE, Thermalright expanded on the successful design with chipset and MOSFET heatsinks. They also made memory heatsinks which worked perfectly for those using two slots.
Problems however were encountered with using the same heatsinks for the latest Intel chipset because the new design heralded the advent of 6 memory slots, all packed closely together meaning the old Thermalright design could not be used successfully with all six ram slots populated. Never ones to stand still, Thermalright have just released the HR-07 Trio pack which consists of either Type H (high) or Type L (low) heatsinks to combat i7 fitment. Should you wish to cool all six modules together then you now can with the latest kits.
Here's what Thermalright had to say about their latest cooling product:
- You won't have to worry about space. Easy installation, no tools needed, able to install 6 DIMMs, high cooling performance and extends life expectancy of your memory module. What more could you ask for?
- Double heatpipes to double heatsinks for fast and efficient cooling
- Proprietary through holes on every fin for efficient ventilation in passive mode
- Vast compatibility across multiple types of memories
- No tools needed for an easy installation keeping manufacturer’s warranty in tact without voiding it
- Supports triple-channel Mode. Option to install on all four memory slots
- Warranty in tact without voiding it
Specification
The following specifications were taken directly from the Thermalright product page:
HR-07 TRIO TYPE H Technical Spec
* Dimension : L128 x W19 x H85.28mm ( High Version)
* Weight :85g ( High Version)
HR-07 TRIO TYPE L Technical Spec
* Dimension : L128 x W19 x H56.28mm (Short Version)
* Weight :80g (Short Version)
Memory module Compatibilities
* DDR1/ DDR2 / DDR3 (only support duble sided memory module)
*without ECC&FB-Dimm memory
Let's take a look at the packaging and presentation of the HR-07 Type H and Type L memory coolers...
«Prev 1 2 3 4 5 Next»
22-06-2009, 17:18:03
mayhem
thats all fine but how much is it over here in the UK in £ ....... Dont bother with currency converters i what to know how much it will be in retail not importing them and then adding duty and vat and delivery and packing on top lol ...
22-06-2009, 18:16:04
w3bbo
I would expect to pay around the £35-40 mark per set. That's just my guestimate though as there are no official pricing figures for the UK market yet.
22-06-2009, 19:36:44
Rastalovich
(top of page 5 I think u mean overlooked instead of overclocked :p )
Good review, would like to have had a 3rd option of just a standard el-cheapo memory fan in the graphs.
23-06-2009, 05:09:14
Saviour
Price is really not too bad. Consider that some people spend just as much on watercooling connections (bitspower?) which are, if we are being totally honest, just for bling then it is not hard to justify spending the same amount on something more usefull that not only looks the part but cools great as well.
yeah but watercooling has moving parts, heavily machined copper etc. these are nothing more than run of the mill heatsinks in a first to market design
then again, thats not exactly a bad position to be in :D
27-06-2009, 01:22:03
denis6902
it it okay for dual channel mem? wouuld it work? or is the spacing only for triple sets?
27-06-2009, 09:46:08
w3bbo
It would work fine for dual channel.
27-06-2009, 13:00:33
sprento
Let's hope it comes out in packs of 2 also.
27-06-2009, 16:33:02
luckybob69
i have been having a small issue with my ram getting hot glad to see this review, anyone know the risk of removing the covers on OCZ Gold Series or how tough it maybe. thanks
found this on Thermalrights site
Disclaimer:
Thermalright or its owners or partners is not responsible for damage or loss of any kind that may occur as a result of using or misusing this or any product we manufacture. Use common sense and review all product details prior to use. Ask a question
27-06-2009, 17:01:42
w3bbo
OCZ Gold sinks are a doddle to remove (just thin sticky pads iirc). Corsair on the other hand are a ***** and could well damage the IC's.
Heat the sticks up slightly with a hairdryer first then give the sinks a 'wiggle' (technical term patent pending).
08-07-2009, 13:54:12
theelusiveyoda
yeah just dont wiggle em to hard or they the sticks might go flying or you might tear of a ic or two did that on a pair of reaper hpx's had to rma good thing they come with a life time warranty. The thermalrights look epic and as others said maybe if the price was a bit lower
