SwiftTech Apogee GT CPU Water Block
Test Setup and installation
Published: 8th May 2007 | Source: SwiftTech | Price: |
Installation was pretty simple on the Apogee GT, as it was on the normal Apogee. Provided are four screws with washers, tensioning springs and caps
Installation as I said is simple and the springs and caps do the business of holding the block in place neatly. Good contact was achieved first time, although I have some experience of mounting the Apogee block before. Shown is test mounting on the IN9 32x Max.
Note that both the Apogee and the Apogee GT did not fit on the DFI iCFX3200 without taking off the stock PWM heatsink and replacing this with some SwiftTech VGA RAMsinks.
Test Setup
For the tests I used the following test setup:
CPU: Intel Core2Duo E6600 @ 3.33Ghz
Motherboard: DFI iCFX3200 RD600 motherboard
RAM: Mushkin XP2-6400 4-4-4-12
VGA: MSI 8800GTX 768mb
Sound: Creative Labs X-Fi fatal1ty FPS
HDD: OS - 160gb Hitachi Deskstar SATA II
Power: OCZ GameXtream 850w
Case: Lian Li PC71b customised
Water Loop:
SwiftTech Mcp655 Pump
Aquacomputer Evo 360 RAD (3 x 65cfm 120mm SilenX fans)
DangerDen Acrylic Bay Res
1/2" ClearFlex Tubing
De-ionised Water + Zerex Coolant + UV Green Dye - exact same mixes were used for each block
Blocks tested:
SwiftTech Apogee Waterblock
SwiftTech Apogee GT Waterblock
The Tests were conducted at the following Ambient Temps (thermal probe):
Apogee: 21.3-5°C
Apogee GT: 21.6-9°C
Arctic Silver 5 was used as the TIM and was given more than the 200 Hours setting in time on each block.
Core Temperatures were measured using CoreTemp beta 0.95. These were double checked using a thermal probe and found to be consistant.
Idle Temperatures were measured after power up for 1/2 an hour and recorded over another 1/2 hour period to gain an average.
Load Temperatures were taken after 1/2 hours load with Orthos Stress Test using small FFT's. Again this was recorded over a 1/2 hour period and average results obtained.
Another slight concern from someone who likes to be "in control" is that the caps on top of the tensioning springs don't allow over-tightening. Personallly I have found that a little extra turn can do wonders for temps on other blocks and maybe SwiftTech should provide some different screws to tighten it up a bit more. Having said this at least this means that over-tightening is never found and you aren't as likely to break anything on the motherboard by being over-zealous.
Test Setup
Water Loop:
Blocks tested:
Apogee: 21.3-5°C
Apogee GT: 21.6-9°C
Wow a blister back for a water block. Good idea i think.
Nice job kemp
Nice job kemp
niiiiiiiiiiceeeeeeeeeee
kemp, you've just made me want to buy this block even more! thanks for making my bank account empty! LOL
lol nps
Nice job kemp |
great review as ever mate....
Really nice review there Kempez!
Nice water block too!
Oh, by the way.. on the graphs isn't it meant to be "Lower is better" instead of Higher? :eh:
Oops
I'll fix that when I get home. Must have had remnants from other graphs
Originally Posted by name='Kempez'
Oops
I'll fix that when I get home. Must have had remnants from other graphs |
Apart from the little mistake awesome review..
How long does it take to makes these review.. for water cooling must be quite a long time!
All of them take quite a while tbh. If you look at methods each block had to have 200hrs curing time with AS5 which took a while
I salute you sir!
Great review, again, Kemp. Some excellent shots too.
I feel we went through a period of blocks having a chrome/shiney look to them - and tbf it helps the manuf abit cos u look inside the case and u can recognize what a dood is using, to an extent.
Be nice to see one of these blocks` chome finished off, by a user, with some design. A flame trim would be tempting fate perhaps
Oh Kemp, dust them LL fans
I just noticed, on the graphs for the results. It says higher is better, isn't it supposed to be lower is better?
Other than that, great review man!
Other than that, great review man! |
Ahh, my bad :P
Cheers fella's - changed
@ rast - I would dust em if I had time
Nice review mate.
200hrs curing time, that's dedication for you!
There was no mention about being able to artificially induce a bow in the GT base plate with the (included?) oversized o-ring for an extra bit of performance. I take it the GT was just tested as shipped (with flat base)?
Is that 1/4" BSPP metal barbs you are using? I take it you had no problems using them in the 1/4" NPSM threaded holes?
@ Ham: I also prefer the new blister-pack style of packaging over the old brown box "Made in Shed" style.
No I didn't test the block with a bowed base as I quite frankly didn't have time
the 1/4" BSPP barbs work fine in the threads for the Apogee and Apogee GT
Link
